vaccuum hose on intake tube? - TCCoA Forums
post #1 of 4 (permalink) Old 07-16-2003, 07:05 PM Thread Starter
Matt C's Avatar
I am working on my brothers 89 xr7 and after having it tore down for 2 months I am finally putting it all back together. The only problem I am having is where the vaccuum hose from the intake tuibe goes. When I removed the tube the hose stayed attached and I can't find where the other end attaches. Any help would be appreciated.
1997 LX Sport..Eibachs & KYBs...245/50s on Eagle Alloy 16x7s...SC rear sway bar...94 SC seats...Mark VIII ds...SCT tuned by Lasotta Racing ...Dirty Dog Marauder converter... Trans by Supergordo
Matt C is offline
post #2 of 4 (permalink) Old 07-16-2003, 11:20 PM Thread Starter
Matt C's Avatar
I found an answer while I was sluming on sccoa It is supposed to hook to the drivers side valve cover via a tube that runs by the sc.
Matt C is offline
post #3 of 4 (permalink) Old 07-17-2003, 04:02 PM
BlownMerc's Avatar
Send a message via AIM to BlownMerc
Yeah I left mine unhooked its just a crank case breather.
BlownMerc is offline
post #4 of 4 (permalink) Old 07-18-2003, 02:51 PM
Lightbulb
You may want to plug the fitting on the intake tube if you aren't going to connect the hose from the valve cover elbow. Leaving the intake fitting open will allow unmetered air (airflow not measured by the MAF) into the intake and can cause performance issues (a lean condition for example). It doesn't take much to "fish" a flexible vacuum line from the valve cover to the intake and connect them up.
LJGriggs is offline
