Recharging The Supercharger???? - TCCoA Forums
post #1 of 14 (permalink) Old 08-01-2003, 02:44 PM Thread Starter
My SC is a 94 with 117,xxx miles on it now. When is the "Average" time the supercharger "dies", or so I've heard it called. Is their anything you can do to lengthen it's life or "recharge" the system? Any thoughts???
HHHthegame is offline
post #2 of 14 (permalink) Old 08-02-2003, 06:59 PM
Our superchargers don't die, they will last as long as the car. The only thing you have to do is make sure that there is enough SC oil in it to keep the bearings lubed. If the seal behind the pulley leaks, you lose the oil and the bearings will start to rattle but they are easily replaced. A couple of companies upgrade them to produce more HP but its still the same basic supercharger. Good luck
vancouverBC is offline
post #3 of 14 (permalink) Old 08-03-2003, 12:20 AM Thread Starter
What are the companies that upgrade them? Is there any other "Performance" Parts you can use, besides porting, etc: Any thoughts???
post #4 of 14 (permalink) Old 08-03-2003, 02:11 AM
tony8470's Avatar
magnumpowers.com
supercoupeperformance.com
mn-12performance.com
in order of relevance......
1990 35th anniversary T-bird SC
1993 Mercury Cougar 3.8
tony8470 is offline
post #5 of 14 (permalink) Old 08-03-2003, 10:38 AM
JJanney is offline
post #6 of 14 (permalink) Old 08-10-2003, 11:14 AM
I was told that if you remove the super charger plate (the top cover I beleive) that there is 400 horses at the crank. Is this true?
birdmandan is offline
post #7 of 14 (permalink) Old 08-10-2003, 11:42 AM
What? What do you mean? You mean this thing?
400 at the crank?
JJanney is offline
post #8 of 14 (permalink) Old 08-11-2003, 12:04 PM
supercharged95's Avatar
Send a message via Yahoo to supercharged95
I dont think so. Whoever told you that either doesn't know a think about supercoupes or was yanking your chain
supercharged95 is offline
post #9 of 14 (permalink) Old 08-11-2003, 07:11 PM
I think what they might have meant (sorta) is that you can replace that top cover with a better one. The stock one kinda flattens out the air passage, and the revised one (aka the "raised supercharger top") is less restrictive. It also increases the plenum volume.
See this link at magnumpowers:http://www.magnumpowers.com/tbrd_classic_top.html
As for 400 at the crank, uh, I doubt it. 265 I would believe. (on a 94-95)
Anyway, whoever said that coulda been talking about something completely different, but that's what I think they probably meant.
Steve
S_Mazza is offline
post #10 of 14 (permalink) Old 08-11-2003, 07:21 PM
That's what the stock top looks like. Pretty small area. It measures 3.31 sq inch. Normal aftermarket areas run from 4.1-5.2 sq inch.
Stock 94-95 Supercoupes are 230 at the crank
JJanney is offline
post #11 of 14 (permalink) Old 08-13-2003, 05:58 PM
Yes, that's what I was talking about. Thanks for the pic.
BTW: I meant, I believe you could increase the stock 94-95 output to about 265 with the top. Maybe not ... but I meant those numbers as possible totals with the raised top.
Steve
S_Mazza is offline
post #12 of 14 (permalink) Old 08-13-2003, 07:12 PM
35hp from a raised top? Not likely on a stock car. Advertised is 1-14hp depending upon setup.
JJanney is offline
post #13 of 14 (permalink) Old 08-13-2003, 10:45 PM
Cool. Thanks for the correction. Sorry if I got anybody's hopes up! (Mine never were up; I have a lowly 140hp, hahaha!)
Steve
S_Mazza is offline
post #14 of 14 (permalink) Old 09-11-2003, 07:44 PM
Send a message via AIM to Bacondoggy
I think whoever was telling you about removing the supercharger "plate" your engine would make more horsepower in a sense, but not have as much. What I mean is the SC actually uses some of our engine's HP to give us alot more.... if you had 300 hp at the crank I would say you have a damn good SC though...
91 sc - put the stockgears back on, underdrive pullyes, rear air hydraulics, headers, no cats or resonator, lowered 1 1/2", 10% pulley, cam, 70k, rebuilt engine bored .30 over, finally fixed!
Bacondoggy is offline
