Harmonic balancer - TCCoA Forums
post #1 of 2 (permalink) Old 08-02-2003, 08:39 PM Thread Starter
Harmonic balancer
Could a bad harmonic balancer sound like a rod knock? I have a 93 SC 5 speed and I read somewhere that if you pulled the plug wire off of the plug in the cylinder with the knock it should stop. If this is true I either have mutiple rods knocking or another problem. Can someone maybe shed some light on this for me?
Also i have not tried to remove any belts (vehicle at work) and the factory gauge says I still have oil pressure.
lgeninchrg is offline
post #2 of 2 (permalink) Old 08-07-2003, 10:59 PM
Try removing the belts, sc first. I thought mine was making the very same noise but it was a tensioner (new one at that!).
talon660 is offline
