Inject me with knowledge - TCCoA Forums
post #1 of 6 (permalink) Old 08-09-2003, 09:20 AM Thread Starter
My freind just bought a 95' supercoupe with 83,000 miles for 2,000 dollars. It is a nice car, great car actually. We found a cracked fuel injector and the injector was blue. We have a redish oarnge injector that came of anouther super coupe, will this injector work, and what usually goes wrong first on super coupes?
birdmandan is offline
post #2 of 6 (permalink) Old 08-09-2003, 10:22 AM
supercharged95's Avatar
Send a message via Yahoo to supercharged95
To my knowledge Ford color codes the injectors, and I do not believe the orange one will work. As far as what goes wrong on supercoupes everybody will tell you something different. When I purchased my car two years ago I had sensors going out right and left. Next up was the transmission and now my radiator sprung a leak and my headgaskets are on their way out. From what I've seen these are common things that go out, so hopefully when I get these things repaired I will be in the clear for a little while. Good luck with your buddies 95, just out of curiousity is it a manual or automatic?
and he did get a steal of a deal on it. My car, at time of purchase had 72,000 miles on it and booked at 13k. The dealer was asking 9 and I talked him down to 7.
supercharged95 is offline
post #3 of 6 (permalink) Old 08-09-2003, 11:02 AM
JustinH's Avatar
The 89-93 SC and 89-90 XR7 use 30lb injectors.
These are red in color.
The 94-95 SC uses 36 lb injectors.
These have a dark blue color.
JustinH is offline
post #4 of 6 (permalink) Old 08-09-2003, 11:23 AM
This link may help you. A red injector is a 30lb, and the stock 95 SC injectors are 36lb. Mixing different injector ratings is a very bad idea. If you put a 30 lb injector in with 5 other 36 lb ones, the cylinder with the 30 lb injector will definitely be running lean.
-Rod
post #5 of 6 (permalink) Old 08-10-2003, 12:45 AM Thread Starter
The car is an automatic, i wish is was manual, but you can't win them all. Another question, how bad will he beat my V8 in the 8th mile.
post #6 of 6 (permalink) Old 08-10-2003, 01:48 PM
VA Chapter Director
Jason Miller's Avatar
Send a message via AIM to Jason Miller
If you race him and everything else is equal (ie. reaction time, traction etc...) the SC is gonna pull out in front from the start with all the low end torqe it makes. I saw my friends Stock 90 SC dyno 290 ft/lbs at the wheels at about 2500rpm. I think the V8's put out about that much torque at the crank. His 95 SC will put out a little more torqe than my friends 90 so if I were you I would take advantage of him getting practice not spinning his tires. If/when he breaks them loose on the launch you have a chance of beating him then.
Member MAMN12 Drag Racing team Best ET 12.44 @109mph
Click here to check out the Mid Atlantic chapter
Jason Miller is offline
