supercoupe rearend - TCCoA Forums
post #1 of 20 (permalink) Old 09-13-2003, 11:52 PM Thread Starter
supercoupe rearend
just wanted to get something straight about supercoupes
did they come with an 8.8 rearend or 7.5? and what kind of gears did they have? the halfshafts are stronger than an LX, correct? is it different for each year? i am wondering mostly about a 91 5 speed supercoupe.
well thanx guyz
rossf83+1 is offline
post #2 of 20 (permalink) Old 09-14-2003, 03:13 AM
They all came with 8.8"s. The 5-speeds had 2.73's, the 89-93 autos had 3.27's and the 94-95 autos had 3.31's. The 5-speed passenger side halfshaft is the largest factory halfshaft for MN12's.
If I'm incorrect on any of this, feel free to correct me. I'm pretty certain that my info is correct.
-Rod
post #3 of 20 (permalink) Old 09-14-2003, 03:37 AM
TCCoA Bachelor Club Pres.
92CougLS's Avatar
Are the halfshafts interchangeable, like, can I run two pass side halfshafts, on on duh the passenger side, and one on the driver side?
-Kurt
1995 Mercury Cougar XR7
4.6L Bone Stock.
Undergoing a light refurbish
92CougLS is offline
post #4 of 20 (permalink) Old 09-14-2003, 08:26 AM
Exclamation
The 1994 & 1995 autos had 3.27s as well.
Thundersteel is offline
post #5 of 20 (permalink) Old 09-14-2003, 11:42 AM Thread Starter
well what about the n/a 3.8's
are they also 8.8?
post #6 of 20 (permalink) Old 09-14-2003, 12:59 PM
92CougLS,
Yes, they are interchangeable from side to side.
Thundersteel,
I'm pretty sure that the 94-95 SC autos had 3.31's, not 3.27's.
rossf83+1,
The N/A 3.8's came standard with the 7.5", with the 8.8" as an option.
-Rod
post #7 of 20 (permalink) Old 09-14-2003, 01:44 PM Thread Starter
'preciate it
your the man
post #8 of 20 (permalink) Old 09-14-2003, 07:42 PM
Question
Maybe it's both?
In the service manual, one place lists four different ratios (2.73, 3.08, 3.27, & 3.31), while elsewhere it lists only three (all but the 3.31).
post #9 of 20 (permalink) Old 09-14-2003, 11:58 PM
VA Chapter Director
Jason Miller's Avatar
Send a message via AIM to Jason Miller
My friends 95 SC auto came with the 3.31 gears but my 94 SC auto came with 3.27's. I know mine had the 3.27's for sure as I just wapped out the pumpkin not too long ago and that was on the tag.
Member MAMN12 Drag Racing team Best ET 12.44 @109mph
Click here to check out the Mid Atlantic chapter
Jason Miller is offline
post #10 of 20 (permalink) Old 09-15-2003, 04:05 PM
Jimmy 2Coupes's Avatar
Smile
All 95 auto's came with 3.31's I believe. From what Jason Miller posted it sounds like some 94 auto's came with 3.27's and some with with 3.31's. I know for a fact my 94 auto came with 3.31's which is represented by axle code 9 on the vehicle certification label located on the driver side door piller. Actually Jason is the only 94 owner I know of with 3.27's as all others I've talked to about this have 3.31's. Any more 94 automatic owners with 3.27's?
1995 SC (five speed)
Best E.T. [email protected]
Best MPH [email protected]
Best 60' 1.7489
1994 SC (automatic) [email protected]
On a stock long block with bolt on's
Sweet SC, lower13's coming.
Jimmy 2Coupes is offline
post #11 of 20 (permalink) Old 09-15-2003, 11:41 PM
T-bird4vr's Avatar
Send a message via AIM to T-bird4vr
I have a 95 auto with 3.31's that I swapped for a t-lock 3.27's.
Everyone needs a t-lock and money for new rear tires.
I have heard there are some 3.27's stock though.
-Julian
T-bird4vr is offline
post #12 of 20 (permalink) Old 09-16-2003, 02:46 PM
Smile
I here you T-bird4vr. I also switched to a trac-lok differential in my 94 auto but for gears I went with 3.55's. Can you say smoke'm at will boy's and girl's???
Best 60' 1.7489
post #13 of 20 (permalink) Old 09-16-2003, 11:03 PM
T-bird4vr's Avatar
Jimmy, are 3.55's the way to go, or would you say get the 73's? I couldn't make up my mind and was getting tired of 1 leggers so just rebuilt the t-lock and put it in. Diff was from an older auto.
-Julian
post #14 of 20 (permalink) Old 09-18-2003, 04:04 PM
Smile
Julian, for a 94 or 95 SC with the 4R70W transmission I believe 3.55's to be the best choice. For an 89-93 SC with an AOD transmission 3.73's seem to be the best choice. The transmission gear ratios from 1'st to 4’Th for the 4R70W are 2.84, 1.55, 1.00, and 070. For the AOD they are 2.40, 1.47, 1.00, and 0.67. With the lower 1'st and 2'nd gears of the 4R70W you will still have a higher final drive ratio with 3.55's than an AOD SC with 3.73's...especially 1'st gear which would be 10.082 final drive for the 4R70W vs. 8.952 final drive for the AOD to be exact. It's my opinion that 3.73's are TOO much gear for a 4R70W equipped (94/5) SC.
Best 60' 1.7489
post #15 of 20 (permalink) Old 09-18-2003, 10:02 PM
T-bird4vr's Avatar
Thanks Jimmy. I might have to make this a winter project. I should be able to borrow the tools to align the gears. Maybe.
-Julian
post #16 of 20 (permalink) Old 09-19-2003, 03:24 PM
VA Chapter Director
Just to throw in my 2 cents, I have the 3.73 gears in my 94 SC and with me in the car it weights over 4200 lbs. That's alot of weight to get moving. Thoes extra low gears realy help get the car moving off the line.
post #17 of 20 (permalink) Old 09-22-2003, 01:08 PM
13's or Mildly Broken
Jason - what kind of gas mileage are you getting with 3.73's? Just curious if you have an idea since I'll be going with 3.73's in the future - just looking for an idea of what the gas mileage will be.
-Andy "Melon"
1999 Crown Victoria P71 4.6
2000 Explorer 5.0
Melon is offline
post #18 of 20 (permalink) Old 09-22-2003, 02:04 PM
With my splitport tbird (which has 3.73's), I've been averaging 22-24 MPG on the highway (cruising around 75-80 MPH) as long as I take it easy on the throttle. Around town, I've been getting between 15-20 MPG. It really depends on how often you "get on it".
-Rod
post #19 of 20 (permalink) Old 09-22-2003, 05:17 PM
VA Chapter Director
I think around town I lost about 1-2 mpg. But you're talking to a guy who likes to take off from the light quickly. On the highway I haven't noticed any change at all. I suppose if I kept it out of the boost around town I would get back thoes 1-2 mpg but, where's the fun in that.
post #20 of 20 (permalink) Old 09-22-2003, 11:36 PM
Thanks guys.. doesn't sound like my mpg will hurt too bad as long as I don't play with it. I'll be running with a 3.27 rear end for a while. Got a few other things I want to do first.
I just figure the 3.73's will be good enough for the track, but still give me decent gas mileage when I feel like driving my 'Bird around.
-Andy "Melon"
2000 Explorer 5.0
Melon is offline
