my SC 92 began to run strange.. - TCCoA Forums
post #1 of 11 (permalink) Old 09-24-2003, 09:10 PM Thread Starter
Hi..
Today, i started to drive my SC 92 and when i stop my car, the needle of the vacum/boost cluster went from 15lb to 10lb, the needle of the RPM cluster start to down the rpms and after raise and low again, and the car began to move some strange, and the car feel like it want turn off.
And i dont got any Check engine light!
Anyone have any idea of what can be the problem.???
thanks
sevilla is offline
post #2 of 11 (permalink) Old 09-24-2003, 11:45 PM
talon660 is offline
post #3 of 11 (permalink) Old 09-24-2003, 11:54 PM
Sounds like a vacuum leak if your vac gauge started fluctuating. I'd check out all your lines.
JJanney is offline
post #4 of 11 (permalink) Old 09-25-2003, 12:47 AM Thread Starter
Thanks..
Anyone have the vacuum diagram?
sevilla is offline
post #5 of 11 (permalink) Old 09-25-2003, 12:56 PM Thread Starter
Bad news..
My friend put their Scanner on my Tbird and the scanner show the Air temp Intake sensor is High or is Open..
Whats the Air temp Intake sensor?
sevilla is offline
post #6 of 11 (permalink) Old 09-26-2003, 11:44 AM
Tim Groth's Avatar
Send a message via AIM to Tim Groth Send a message via Yahoo to Tim Groth
I think your refering to the IAC or the Idle Air Control...It sounds about right as to how you portray your problems compared to other posts on bad IAC's that's I've read.
As for its location it is the Diamond shaped sensor on your throttle...next to your TPS (throttle positioning sensor). You'll see what I mean when you look on your throttle body.
Give it a go and see if it fixs your symptoms...it's a fairly cheap sensor...say 80-100 perhaps less (this is what I was told by a firend).
Let me know if it helps.
-Tim
Current Collection
1994 Thunderbird SC - Auto
1994 Thunderbird SC - 5spd
1995 Thunderbird SC - Auto
1997 LX - Auto - Parts Car
Tim Groth is offline
post #7 of 11 (permalink) Old 10-07-2003, 02:21 PM
You have a vacuum leak as JJ stated.
Vacuum Leak Article by Vernon Cradier at SCCOA
Calvin
FearThis SC is offline
post #8 of 11 (permalink) Old 10-10-2003, 12:08 PM Thread Starter
I car Is done!
The mechanic needed to remove the supercharger and he told me the car had a "air entrance" somewhere of the engine, because the injectors are putting a lot of fuel
(more than 3V on idle).
I rememeber he told me the problem was on the manifold or some like that..
And well, after the repair, i test my car on a highway and my car now is puttng 12 psi.. after only put 10 or 11.
What u think guys?
sevilla is offline
post #9 of 11 (permalink) Old 10-10-2003, 12:11 PM Thread Starter
Ups.. I mean "My Car is Done"
sevilla is offline
post #10 of 11 (permalink) Old 10-11-2003, 06:13 PM
You had a vacuum leak. Sounded like it was at the intake manifold.
You may want to reset the computer (disconnect the battery) & see if that code for the intake air temperature sensor still appears. The sensor could still need replacement, and not manifest its symptoms in an obvious manner.
digitalchaos is offline
post #11 of 11 (permalink) Old 10-11-2003, 09:21 PM Thread Starter
Yep.. The Air Intake Sensor was remplaced too because it was broken. I belive the problem only was that sensor, but he problem dont fixed when they change the sensor..
So, i think it was a vacumm leak.. maybe!!
Thanks a lof for the help.
sevilla is offline
