power steering pump - TCCoA Forums
post #1 of 10 (permalink) Old 10-13-2003, 08:27 PM Thread Starter
Send a message via AIM to rzimmerl
power steering pump
power steering pump on my sc is whining horribly, has plenty of fluid. priced new one at autozone and was about 60 bucks. how hard are they to get out and dont you need a special tool to pull of the pulley?
thanks
ryan
1990 SC AOD 1.7L AR....11.75 @118
441 RWHP 435 RWTQ
rzimmerl is offline
post #2 of 10 (permalink) Old 10-14-2003, 10:33 AM
Jeff Bratton's Avatar
Send a message via AIM to Jeff Bratton
They are not hard to take out... just make sure you are careful when taking your line offnot to strip the nut. As far as taking the pulley off, it has a hex(allen screw) you need to remove. Lots of them get so rusty it is very hard to remove them. I would sugguest to taking it with you to Autozone to have them try to remove the pulley for you. They usually have an impact wrench to do this.
Hope this helps...
Jeff B
'89 Black SuperCoupe
Louisville, Ky.
260 RWHP / 349 RWTQ
Email me: [email protected]
Powered By Magnum Powers MPIII & other Bolt-On's
Check out My SuperCoupe
Jeff Bratton is offline
post #3 of 10 (permalink) Old 10-14-2003, 10:38 AM
They are not hard to take out... just make sure you are careful when taking your line off not to strip the nut. As far as taking the pulley off, it has a hex(allen screw) you need to remove. Lots of them get so rusty it is very hard to remove them. I would sugguest to taking it with you to Autozone to have them try to remove the pulley for you. They usually have an impact wrench to do this.
Hope this helps...
Jeff B
Louisville, Ky.
260 RWHP / 349 RWTQ
post #4 of 10 (permalink) Old 10-14-2003, 10:45 AM
5.0 Chero's Avatar
It is a pretty easy job to replace th pump. The Pulley is pressed on and yes it uses a special puller that auto zone has and will lend you to do the swap. On my 5.0 i was able to remove the pulley while the pump was still in the car. That let me pull the pump with out removing the bracket that mounts the pump to the motor. Dont know if you can do the same on your Super Coupe or not! hope this helps!
THE PYL !
91 Tbird lx 5.0 swap
GONE 93 5.0 Stang vert
86 F250 Diesel 4x4
GONE 89 Aerostar
2003 F350 Super duty
1996 Exploder
5.0 Chero is offline
post #5 of 10 (permalink) Old 10-14-2003, 10:46 AM
I don't recall any type of set screw on my pullies, but you will need a PS pump pulley puller and install kit. Also the bracket between the PS and Water pump is kind of a ***** and most people to not reinstall it. Remember the new pump will take ATF not power steering fluid and don't hammer the new pulley on, use the install tool.
SCrazy is offline
post #6 of 10 (permalink) Old 10-18-2003, 12:25 AM Thread Starter
went to buy a new pump today but how do i find out if my power steering is variable assist or not. i thought all tbirds had assist or am i wrong
441 RWHP 435 RWTQ
rzimmerl is offline
post #7 of 10 (permalink) Old 10-20-2003, 07:46 AM
All SC's have variable assist. I don't know about other models.
SCrazy is offline
post #8 of 10 (permalink) Old 10-20-2003, 10:59 PM
You can also buy the non variable assist and just transfer your old one onto the new. I know the non variable is a little cheaper.
onebad35thsc is offline
post #9 of 10 (permalink) Old 10-27-2003, 12:45 PM
Lightbulb
Have you tried flushing the pump and refilling with good quality synthetic PS fluid? (pretty much all Ford PS pumps whine at one time or another). Give that a try before spending money on a new pump that will probably end up whining just as bad.....
LJGriggs is offline
post #10 of 10 (permalink) Old 10-29-2003, 07:43 AM Thread Starter
found out had a leaking line that conveintly dumped the fluid into the bumper cover, so i added a jusg and and half of fluid as shes all good. and sitting in her winter home till spring
441 RWHP 435 RWTQ
rzimmerl is offline
