buying an sc - TCCoA Forums
post #1 of 27 (permalink) Old 10-18-2003, 08:25 PM Thread Starter
JoeyICU's Avatar
buying an sc
when looking to buy a superoupe is there anything to look for to give away if it will have problems.....and what kind of consistant problems do sc's have....like blowing head gaskets and such....?
JoeyICU is offline
post #2 of 27 (permalink) Old 10-19-2003, 08:48 PM
Send a message via AIM to rzimmerl
another problem to look for is the ABS light or the brake light that stays on bad abs accumulator i think its about 400 for a rebuilt, and trannies seem not to last long either
1990 SC AOD 1.7L AR....11.75 @118
441 RWHP 435 RWTQ
rzimmerl is offline
post #3 of 27 (permalink) Old 10-19-2003, 09:06 PM
blowing head gaskets are notorious. also broken motor mounts(oil pan sagging below the cross member). also if the crankshaft pulley is wobbling the crank dampener is on it's way out. that is also pretty common. oh yeah, AOD transmissions SUCK. but i love my car, i really do! new ABS accumulators are $100 and an easy self fix.
NMxr7SC is offline
post #4 of 27 (permalink) Old 10-19-2003, 09:08 PM
JustinH's Avatar
alot of electrical gremlins with these cars, and for the most part they are not easy to work on. I replaced pretty much every sensor on the 89sc in about 6 months that my brother owned it.
But it was a neat car when it ran right.
Honestly, the only sc I would buy would be a 95 with the auto or the stick, prefer the auto though over the dump truck m5r2.
JH
JustinH is offline
post #5 of 27 (permalink) Old 10-19-2003, 10:04 PM
tony8470's Avatar
yeah the sc is the car you cant live with sometimes and cant live without. Its true that the AOD sucks in these cars, I would get a 94-95 sc. I hope you arent looking for a too dependable car, if you are then stick with the V8. Or an extremely low mileage SC. Yes there are people that have good sc's but you hear about more problems with the sc than the other ones for the mn-12's. But.......I wouldnt buy any other car than an SC. I would go to SCCOA.com and browse the forums for common problems on our cars.
1990 35th anniversary T-bird SC
1993 Mercury Cougar 3.8
tony8470 is offline
post #6 of 27 (permalink) Old 10-19-2003, 10:57 PM
Like they said basicly....Dont forget to turn firm ride on and off to see if its working right, if you turn it off and it flashes in the dash the shock accumlators are sticking or somethings wrong. Also, if you can take it up to highway speed and slow down to like 30 and see if overdrive slips...thats the first thing that likes to go. Also, take it to full throttle all through first and see how much boost its putting out. If its below about 12 the blower has some issues or thiers a vaccum leak somewhere. I would also look in the coolant resvoir, radiator and check the oil for any choc milk shake lookin oil or coolant.
But, if you want this as a daily driver I would suggest a v8, but if its a 2nd car thier fun to have. Good luck, Justin
RedBirdSC is offline
post #7 of 27 (permalink) Old 10-19-2003, 11:45 PM
I found this artilce helpful, SCCOI - Buying an SC.
Tazer999 gave me a few pointers too. I've had mine for 2 weeks. It's wicked. Too easy to break the tires loose.
An SC'd 4.6 would be sweet though.
soop is offline
post #8 of 27 (permalink) Old 10-20-2003, 09:28 AM Thread Starter
JoeyICU's Avatar
im shooting to keep my old car.....just making it look like an sc.....i was thinking about an sc but i know they arent very dependable so i dont think i wnana journey into them.....maybe a few years down the road as a 2nd car
JoeyICU is offline
post #9 of 27 (permalink) Old 10-20-2003, 11:52 AM
T-bird4vr's Avatar
Send a message via AIM to T-bird4vr
Dude, don't be scared. I haven't had a single problem with mine, knock knock. But I have only had it for 9 months. They are too much fun to drive, and can be had pretty cheaply.
-Julian
edit: oh ya, they handle much better too. A v-8 of similar year t-bird was messing around with me on a curvey road. All of a sudden I hear this awful screaching noise and he about loses it. I was shocked as I could have gone a lot faster around that corner. Maybe just swaybars and better wheels would fix it though.
T-bird4vr is offline
post #10 of 27 (permalink) Old 10-20-2003, 01:44 PM
rustyul's Avatar
Yeah, I'll second the handling. I'm driving my 95 XR7 right now due to a leaking clutch slave cylinder on my SC. The SC way outperforms the 94-97 XR7's in the handling area.
Oh, yeah, and the slave cylinders on the 94-95 5-speed SC's are known to leak. About $110 list from the dealer and a tranny removal (drop gas tank and remove driveshaft first) to install.
Glen "RustyUL" Weldon
95 Thunderbird LX - 4.6
rustyul is offline
post #11 of 27 (permalink) Old 10-20-2003, 03:58 PM
Just to add my .02 on reliability, I've got 2 '95's. One is my daily driver & has 126k on it. Doesn't burn a drop of oil, nor leak anything. I bought it at 93k, & I've replaced the usual stuff for a higher mileage car: battery, water pump, tires, etc... It's been a very good car, & I intend to keep on maintaining & driving it. I would avoid the earlier ('89-'92') SC's as the ABS brake system on them can be tough to find parts for.
mcate is offline
post #12 of 27 (permalink) Old 10-21-2003, 07:18 AM Thread Starter
JoeyICU's Avatar
i was looking at a 90 SC with 205k on it......so i think it may have some relibilty problems.....but the headgaskets were done at 145k so im fine there.....and there no other problems with the car......i just dont know if its worth a grand......everything is in working order......and its a 5spd
JoeyICU is offline
post #13 of 27 (permalink) Old 10-21-2003, 03:28 PM
Just look it over closely, & go with your instincts. Sometimes it's not the mileage as much as how the miles were put on that counts. If it's in good shape & hasn't been driven too hard it's worth a grand.
mcate is offline
post #14 of 27 (permalink) Old 10-23-2003, 03:41 PM
I don't really know why the SC gets so many dings on the reliabilty scale. I've owned a 1995 for going on the 7th year and almost 50,000 miles and normal maintenance has provided me with what I consider a VERY reliable car. Over that time I've had the radiator replaced (under warranty), replaced the front rotors after warping with crossdrilled ones ($210), cam sensor went bad ($60), power antenna mast ($40), right rear shock was making noise but still worked well so I replaced with Tokico's and Eibachs ($6XX), brake pads (all around) ($?), and engine mounts (were bad) plus transmission mount (wasn't bad but replaced anyway) ($110). Everything plus labor = just under 2K. Divided over 6 years = a little over 300/year. Or divided over 50,000 miles = .04 cents/mile. Not too bad in my book. But, I've not owned anything as long as my car except my motorcycle. Just my .02.
Mike
955spdSC is offline
post #15 of 27 (permalink) Old 10-23-2003, 04:38 PM Thread Starter
JoeyICU's Avatar
in 7 years with only 50k....thats alot of problems....well my 94 LX V8s repairs all consisted of are 2 tranny flushes....and the regular matience....and no problems anywere close to those kind of problems you had with your sc and only 50k....id get an SC as a 2nd car but i doubt id want one as my only car
JoeyICU is offline
post #16 of 27 (permalink) Old 10-24-2003, 07:36 AM
No it's not. And my SC had been my only car for 5 out of the 7 years. I would own another SC as my only car in a heartbeat. If you wouldn't, then it's your loss, because I love owning 1 of 574 SC's made that year with a manual transmission. Drive one and you'll see. And what are you considering "those kind of problems"? The only "real" problems that existed (if you read it) that are NOT normal maintenance were the engine mounts, power antenna, and the cam sensor. All together, a little over 200 bucks in parts. That's probably the same price as the head unit you have installed. And if you're looking for a car with 205,000 miles, how dependable do you think it's going to be?
955spdSC is offline
post #17 of 27 (permalink) Old 10-24-2003, 09:51 AM Thread Starter
JoeyICU's Avatar
im not looking for a SC anymore i drive alot and i cant ever not have a car....it just seems like thats to much for a car with that little amount of miles thats all im saying...because the 94 at 50k didnt have any problems...i just the V8s are more durable....and the way i drive an SC wouldnt hold up....it would probably be broken every other week
JoeyICU is offline
post #18 of 27 (permalink) Old 10-24-2003, 12:40 PM
If you think that is a lot for 7 years, then you should definitely not get an SC.
JJanney is offline
post #19 of 27 (permalink) Old 11-02-2003, 01:08 AM
suprchgdbird's Avatar
I agree JJanney. Thats nothing.
suprchgdbird is offline
post #20 of 27 (permalink) Old 11-02-2003, 09:36 AM Thread Starter
JoeyICU's Avatar
well im not.....im shooting for a 96 sport....i looked for mark 8s for under 5k....couldnt find a good deal on one of them.....i looked for SC's with low miledge for cheap.....couldnt find one of those either.....and all this info on them made me think....ill get one down the road.......to mess around with.........b/c if i had one as a daily driver.....id kill it alot.....and i need 100% dependability.....so the v8 it is...thanks for all the info
JoeyICU is offline
post #21 of 27 (permalink) Old 11-02-2003, 12:33 PM
Hey man in reference to the "sexi" link in your signature, I live in Carroll County (Sykesville), MD and I was looking at that same car on ebay a few days ago! It looks nice. I don't think we're too far from each other.
Matt
iwannanSC is offline
post #22 of 27 (permalink) Old 11-02-2003, 12:40 PM Thread Starter
JoeyICU's Avatar
hmm i guess your new around the area.....u need to chill with the tbird crew...theres 3 of us so far....a 96 LX v8 and a 97 Sport and i was a 94 LX v8 till my car died
JoeyICU is offline
post #23 of 27 (permalink) Old 11-03-2003, 11:00 AM
I'm a member of the Mid-Atlantic MN12s (mamn12.com), you should check us out for Tbird meets in the area, we've got a few more than 3.
post #24 of 27 (permalink) Old 11-03-2003, 01:45 PM Thread Starter
JoeyICU's Avatar
i mean in the very close area to me...ive met a few of the mamn2 people at carlisle last year.....there cool but i dont really have the time to do a dedicated organized club....ill be working 5 days a week or more to pay off the new bird im buying....not alota room for mods.....and i still go to high school....im gonna be a little tight...
JoeyICU is offline
post #25 of 27 (permalink) Old 11-03-2003, 08:46 PM
I hear you man. I'm a freshman in college fulltime and I'm starting a new job next week. Just figured I'd let you know about the club.
Matt
post #26 of 27 (permalink) Old 11-03-2003, 09:25 PM Thread Starter
JoeyICU's Avatar
ye they kinda know me....proly forgot about me but its all good.....ill join it once im out of high school and working full time......cuase then ill have way more free time
JoeyICU is offline
post #27 of 27 (permalink) Old 11-03-2003, 10:12 PM
T-bird4vr's Avatar
So did you get the sport?
