name that gasket - TCCoA Forums
post #1 of 10 (permalink) Old 10-20-2003, 06:09 PM Thread Starter
Geek w/Gearhead Complex
Fubarian's Avatar
name that gasket
plain and simple. Where do these go??
oh, and do I need to use oil on the water pump gasket or the timing chain gasket? I want to be sure.
Thanks as always
Fubarian is offline
post #2 of 10 (permalink) Old 10-20-2003, 06:24 PM
Tazer999's Avatar
Haha i duno, i had those left over also after my rebuild
Minus the waterpump one that is
1990 Red Thunderbird SC
SCCOWC Member
Tazer999 is offline
post #3 of 10 (permalink) Old 10-20-2003, 06:32 PM Thread Starter
Fubarian's Avatar
ah no way. They gotta be for something ....right??
Fubarian is offline
post #4 of 10 (permalink) Old 10-20-2003, 09:34 PM Thread Starter
Fubarian's Avatar
got it answered for the most part::
A - Drain plug gasket
B- O-ring for the SC top throw it out you'll never need it
C- I have no idea I've never seen that gasket in a kit before?
D- Oil pump gasket.
http://www.sccoa.com/forums/showthre...738#post215738
96 Mark VIII [email protected] :: 03 radiator/fan - j-modded trans - BBK UD pulley kit - dual gauge pod - 28,000 B&M transcooler (w/ AN fits) - 3.73 locker (with speedo gear) - 180' thermo - 8.5mm wires - colder plugs
soon to install : "fixed" heads and a damn tune. Project snaked8 continues...
Fubarian is offline
post #5 of 10 (permalink) Old 10-20-2003, 09:45 PM
Tazer999's Avatar
Good to know they weren't important,
SCCOWC Member
Tazer999 is offline
post #6 of 10 (permalink) Old 10-22-2003, 09:56 PM
Blue one is the water pump I know.
93SC is offline
post #7 of 10 (permalink) Old 10-23-2003, 12:39 AM
A--could also be the distributor gasket o ring...maybe
B--
D--Oil pump gasket
Blue-water pump gasket
White--timing cover gasket
there also appears to be a rear main seal in the picture.
RobinCali is offline
post #8 of 10 (permalink) Old 10-27-2003, 11:36 AM
dugweed's Avatar
Send a message via AIM to dugweed Send a message via Yahoo to dugweed
A- drain plug gasket
B-oil cooler to block gasket
C-cam sensor o ring, or distributor o ring if you dont know what a cam sensor is
D-oil pump o ring
Mike
2009 Harley-Davidson Road Glide
1996 F350 CCLB 7.3 5 speed 4x4
dugweed is offline
post #9 of 10 (permalink) Old 11-08-2003, 08:09 AM
The "distributor" is a very rare option on a SUPERCOUPE!
LMAO!!!!!!!!!!!!!
68COUGAR
68COUGAR is offline
post #10 of 10 (permalink) Old 11-15-2003, 07:25 PM
After just rebuilding a complete motor myself....here goes.
a) oil pan drain plug seal
b) seal for the oil cooler to the oil pump
c) not too sure
d) oil pump to the timing cover
check with who you got the kit from for (c) and go from there.
yyc_tbird_sc is offline
