VMM display wrong? - TCCoA Forums
post #1 of 6 (permalink) Old 10-31-2003, 02:33 PM Thread Starter
Question VMM display wrong?
On my 90SC, The VMM is indicating that I need to change the oil, which I will be doing, but the OIL Level on the VMM shows LOW. It has been doing it on and off for a three days now.
I've checked the oil level and it's just fine. Is this coming on because the OIL CHANGE is displaying NOW or is it just an error? How is the oil level measured with this thing? Is it by pressure or a sensor that picks up the level in the pan or what?
Thanks for the help.
soop is offline
post #2 of 6 (permalink) Old 10-31-2003, 03:18 PM Thread Starter
Nevermind. Apparently these are junk after the sensors get gunked or worn and display inaccurate info.
soop is offline
post #3 of 6 (permalink) Old 11-02-2003, 11:25 PM
suprchgdbird's Avatar
You can go to your local junk yard and find them but be careful pulling them out. They break very easy. You can also go to www.supercoupekuhn.com Gary has them for $40.00
suprchgdbird is offline
post #4 of 6 (permalink) Old 11-03-2003, 01:52 PM
projectmayhem021's Avatar
Send a message via AIM to projectmayhem021
mine does that too, i checked the oil and its fine so i pay no attention
-Brendan
"So far, this is the oldest I've been"-George Carlin
1994 Black Thunderbird SC
projectmayhem021 is offline
post #5 of 6 (permalink) Old 11-04-2003, 10:40 PM
It's a level sensor, as far as I know, threaded into the block or oil pan on the passenger side.
You probably know how to reset the oil change indicator, but for those who don't, you have to insert a paperclip or other metal object into the little hole beside the VMM and then turn the ignition key to ON. I think you just hold it for a couple seconds, it blinks, and then you go on your way. Correct me if I'm wrong.
Steve
S_Mazza is offline
post #6 of 6 (permalink) Old 11-08-2003, 04:05 PM
You are 100 percent correct.
