cutting the 70mm maf - TCCoA Forums
post #1 of 5 (permalink) Old 11-24-2003, 10:20 PM Thread Starter
Send a message via AIM to rzimmerl
is it safe to cut the bridge out of the 70 mm maf. the drilling think dont sound like a good idea but my buddy has a extra one from a 4.6 and was just think of some cheap ponies
1990 SC AOD 1.7L AR....11.75 @118
441 RWHP 435 RWTQ
rzimmerl is offline
post #2 of 5 (permalink) Old 11-24-2003, 11:48 PM
Silver95Bird's Avatar
It's not worth it. you won't really gain anything and it will throw off the transfer function of the maf.
Silver95Bird is offline
post #3 of 5 (permalink) Old 01-10-2004, 10:54 AM
cut it out flush with bottom and as flush as you can at base of sample tube .
then after removing the sensor drill a 15/32 hole in existing sample tube hole this will correct the flow thru to sensor .
dont replace the blockopff plate at back side of tube leave it off . this trick is good for 2-5 hp on a sc stocker,
mines been like this for three yrs now and i passed smog in socal twice with it.
mannysc is offline
post #4 of 5 (permalink) Old 02-11-2004, 09:38 AM
do you happen to have any pictures? Will the ecu need calibration?
96Sprintz is offline
post #5 of 5 (permalink) Old 02-11-2004, 12:43 PM
this setup passed smog in so calif in oct this yr ,
its not done this is one im doing for a friend,
i cut post out and will blend it and remove nub left at bottom of tb drill it 15/32 and it works great
mannysc is offline
