Vacuum Leak??? Bad.. - TCCoA Forums
post #1 of 4 (permalink) Old 12-21-2003, 09:49 AM Thread Starter
SC UL8R1990's Avatar
Send a message via AIM to SC UL8R1990
Question Vacuum Leak??? Bad..
posted this for a buddy-------
well the car is up and running ... for now.. had to rebleed the clutch...next week if all goes as planned.. exhaust.. so now the TECHNICAL question is..... What is this "whooooooo" i hear when i let off the gas.. seems whenever the vacuum goes below 22lbs .. sounds like a drunk owl. WHHHOOOOOOOOOOOOOOOOO... i dont think its normal.. and when i floor it the boost goes off the gaug and the car kinda bucks around. back and forth back and forth its like a driver who cant drive stick but while accelerating hard. any input to these new bugs??????
any and all help appreciated
walter
-Walter
Big Bad Boston Bruins Fan!
SC UL8R1990 is offline
post #2 of 4 (permalink) Old 12-23-2003, 09:28 PM
When I swapped out my blower a couple of weeks ago, I forgot to put the vacum line back on the back of the manifold. Got that same sound. Very loud. My brother came over and put it back on, told me alot of people forget that one.
onebad35thsc is offline
post #3 of 4 (permalink) Old 12-24-2003, 12:45 AM
pearl95sc's Avatar
The whole bucking thing could be plug related. I had to change my plugs in leiu of all my upgrades. NGK uridiums rule. No problems at all now. As for the whooooooo, is it lower or higher pitched? I had forgotten to tighten the bypass valve clamps and had a boost/vac leak that I couldn't hear or see.
pearl95sc is offline
post #4 of 4 (permalink) Old 12-25-2003, 04:36 AM
tony8470's Avatar
<-----whistle tips
I'm thinkin loose lines as well. Try the propane trick.
1990 35th anniversary T-bird SC
1993 Mercury Cougar 3.8
tony8470 is offline
