Engine Wiring Harness Questions - TCCoA Forums
post #1 of 2 (permalink) Old 12-29-2003, 07:32 AM Thread Starter
joshbea6's Avatar
Does anyone know if the 95 4.6L engine wiring harness will work for the SC? if not, what is different?
I have a 95 LX 4.6L wiring harness, and I need to replace the wiring harness in my 90 SC and I am doing the interior upgrade to the 95 interior. I have also added the airbag seensors to my 90 SC so that I can use the dash and steering column properly.
Any help on this is very welcome!
joshbea6 is offline
post #2 of 2 (permalink) Old 12-29-2003, 11:32 AM
jk69cat's Avatar
no engine control harnesses are different. i have reserched this for a few people, and the engine harnesses are different for each year car and each engine.
mn12 less!
jk69cat is offline
