two problems... - TCCoA Forums
post #1 of 6 (permalink) Old 01-02-2004, 04:53 PM Thread Starter
SCsmo's Avatar
Question two problems...
my car seems to have to problems, first is a rough idle. when ever my car is just sitting there running or when i'm driving slow and turn the wheel the rpm's drop a bit, not much, but its noticable. and when it does it when i slow down, i loose the power steering a bit. but when the car is sitting there, they go up and down and if i hit a button such as the window button, it does the same.
my second problem is overheating. when the car sits in place for and amount of time, the temp starts to rise quickly, but i can control it using the ac. but i noticed that the electric fan won't come on to cool it down, so i hooked up an eec tester, and the fan worked when it tested it.
01- mustang cobra- lazer red -bbk o/r x pipe w/ 40 series, JLT, waiting to install 4.10's
04 ram- ya, its a hemi- [email protected] -sold!!
92 tbird sc- sold!!!- almost made it to the 60ft mark
newest sales rep at Herb Chambers Ford in Braintree, MA, pm me for info
SCsmo is offline
post #2 of 6 (permalink) Old 01-02-2004, 04:55 PM Thread Starter
SCsmo's Avatar
o, and for a bit more info, the car doesn't have a coolant leak or anything of that sort, so i don't think it is the head gaskets
SCsmo is offline
post #3 of 6 (permalink) Old 01-02-2004, 07:03 PM
For the fan problem you can cut the #14 wire coming out of the ICRM. It's orange/white I think. That will make the fan run all the time. As far as the idle dropping when turning the wheel, that sounds normal. When you go to roll down the window doesn't though. If theres a problem, maybe the alternator? But I'm not sure about that one.
93SC is offline
post #4 of 6 (permalink) Old 01-03-2004, 09:58 AM Thread Starter
SCsmo's Avatar
ok, cool. but would u happen to kno where that wire would be located?
SCsmo is offline
post #5 of 6 (permalink) Old 01-03-2004, 03:05 PM
In front of the air box there is a little box like thing that has a bunch of wires rinning into it. They are all numbered on hte harness that bolts into the box. Make sure to take the harness of the box and then make sure that it's the #14 wire.
93SC is offline
post #6 of 6 (permalink) Old 01-08-2004, 01:09 PM
Sounds like your LOW on coolant, plus you may have air trapped in your system.
Calvin
FearThis SC is offline
