shifter box - TCCoA Forums
post #1 of 19 (permalink) Old 02-02-2004, 03:23 AM Thread Starter
Lightbulb shifter box
Will the " MN12 Performance Inc. Shifter Box Extension Kit for T5 and T45 " from Mn12performance.com, fit a T-56 6 speed transmission ? It only says t5 and t45... I beleive that it would fit, but I would like to know for sure... also, does anybody know how the bellhousing would work ? What should I do about that... I would love to throw a T-56 6 speed in my M-5 1995 T-bird SC... Thanks Guys,
David.
95SC is offline
post #2 of 19 (permalink) Old 02-08-2004, 01:14 PM
M-5 Supercoupe??????
Can you explain what an "M-5" Supercoupe is? That's a "model" I've never heard of.
About Rich's shifter extension. The best thing to do is post your question over on his forum. I doubt it will work for what you want to do. It was designed to put a T-5 in the T-bird. It does use a T-56 shifter though.
68COUGAR
68COUGAR is offline
post #3 of 19 (permalink) Old 02-08-2004, 04:43 PM
If your trying to put a T-56 in, your shifter location won't be much of a problem. It will be about a 1.5" ahead of the stock location. The flywheel will hit the bellhousing, so some fabbing will be nessasary. There's a lot of other stuff that will have to be special built, so good luck man.
93SC is offline
post #4 of 19 (permalink) Old 02-08-2004, 05:42 PM
MarksM's Avatar
Send a message via AIM to MarksM
*sigh*
It can't be done. Forget about using anything other than the M5R2 transmission.
2007 Buell XB9S
MarksM is offline
post #5 of 19 (permalink) Old 02-08-2004, 05:54 PM
Originally posted by MarksM
It can't be done.
Not True!!!!! At least one SC Guy has done the T-56 conversion.
68COUGAR
68COUGAR is offline
post #6 of 19 (permalink) Old 02-08-2004, 06:27 PM
96bird's Avatar
Here you go. Don't ever say that something can't be done. 6-speed SC
Russell
96bird is offline
post #7 of 19 (permalink) Old 02-08-2004, 10:01 PM
MarksM's Avatar
Yeah.. he went through a lot of unnecessary trouble too.
I guess no one has actually researched putting in a T56 besides reading that fella's article. Fact is, it isn't hard at all. I have all the pieces needed and it will get done eventually. I was going to create my own article but I've decided not to.
2007 Buell XB9S
MarksM is offline
post #8 of 19 (permalink) Old 02-08-2004, 10:53 PM
96bird's Avatar
Why's that? Too much work? It would be nice to have another article to refer to besides that other guy's article. I like to see people do things that weren't supposed to work and making it work well.
Russell
96bird is offline
post #9 of 19 (permalink) Old 02-09-2004, 01:03 AM Thread Starter
Hey 68COUGAR, " M-5 " is ( manual 5 speed... ) sorry for the confusion....
Thanks for the reply guys, I will think about doing it... It seems too much trouble though....
David.
95SC is offline
post #10 of 19 (permalink) Old 02-18-2004, 01:52 AM
MarksM's Avatar
OK, want a T56... No cutting and pasting of bellhousings. Choose the LS1 to Ford bellhousing to keep the shifter close to stock location. Any other model of T56 moves it forward. Mod motor bellhousings are on page 7.
http://www.mcleodind.com/catalog_htm/PAGE8.HTM
Then, to adapt the GM VSS signal to Ford...
http://www.dakotadigital.com/Detail....rtNumber=SGI-5
2007 Buell XB9S
MarksM is offline
post #11 of 19 (permalink) Old 02-18-2004, 09:20 AM
96bird's Avatar
Here is a GM tranny that uses the mechanical speedo (bottom of page). Link
I was thinking that it wasn't the case that made the GM tranny longer, it was the bellhousing. So...if you change the bellhousing then you would lose the advantage of the extra length. It has been a while since I looked into this, but I think that is right. Other than that it will work. This can be done, and if I had a little bit more money I would do it.
Here is another idea if you are going to upgrade the whole car to a performance oriented stage. You could buy a mild-steel kmember (when they come out from AJE) and get them to move the engine mounting spot back 1.5-2in., then you could use the ford t-56 and be in the right spot. If I do it, that is what I will do.
Russell
96bird is offline
post #12 of 19 (permalink) Old 02-18-2004, 07:26 PM
MarksM's Avatar
No... the case is identical. The input shaft is longer on the LS1 tranny than it is on the LT1. The length difference in shifter location is the tailhousing casting. Look at them and it's easy to see that the LS1/LT1 shifter is farther back than the Ford/Viper trans.
2007 Buell XB9S
MarksM is offline
post #13 of 19 (permalink) Old 02-18-2004, 08:46 PM
96bird's Avatar
Alright. I just wasn't sure. I can probably get a hold of an LS1 t56 pretty cheap, but I don't know about spending almost 500 on a bellhousing.
Russell
96bird is offline
post #14 of 19 (permalink) Old 03-23-2004, 11:37 PM
CaifanSC's Avatar
Send a message via AIM to CaifanSC Send a message via Yahoo to CaifanSC
So is anybody going to start this project? Im really curious about it.
1993 SC 5.0L V8 Auto Red
1994 SC 5-speed Teal
1995 SC 5-speed Chameleon Blue
1992 Feature Mustang Convertible 5.0L 5-speed Vibrant Red
1991 BMW 850i 5.0L V12 6-speed Red
1994 BMW 850CSi 5.6L V12 6-speed Red
Sold: 89 SC stick Titanium, 90 35th stick, 92 Sport 5.0L stick, 94 SC stick Black, 1994 SC Auto Teal Totaled: 89 SC auto Twilight Blue
www.mamn12.com for your mid-atlantic mn12 needs!
CaifanSC is offline
post #15 of 19 (permalink) Old 03-23-2004, 11:56 PM
96bird's Avatar
Whenever I get my suspension complete I will start on putting the T-56 in my car. Donations welcome!
Russell
96bird is offline
post #16 of 19 (permalink) Old 03-24-2004, 12:06 AM
Someone's already done it.
93SC is offline
post #17 of 19 (permalink) Old 03-24-2004, 07:45 AM
CaifanSC's Avatar
93sc, i know...i've actually read the walk-through from that guy a long time ago but as far as I know, he's not too active on the website(s) so like everybody else, i'd like to see some one else do it for further reference.
CaifanSC is offline
post #18 of 19 (permalink) Old 03-24-2004, 10:45 PM
T-56 Gear Ratios. What exactly are the T-56 gear ratios? Since the T-56 is avail. from different car companies, it's probably also avail. with different gear ratios. Next, how do T-56 gear ratios compare to M5R2 (early AND late) gear ratios? Are there custom T-56 OD ratios available, maybe from aftermarket vendors? Hmmmmmm? The whole T-56 question opens up more questions than it answers.
68COUGAR
68COUGAR is offline
post #19 of 19 (permalink) Old 03-24-2004, 10:58 PM
96bird's Avatar
There are different ratios, but the one I am looking at is 2.66, 1.78, 1.3, 1, .74, .5. All of the T-56s are either Borg-Warner(Tremec bought them out) or Tremec.
Russell
96bird is offline
