How to Test DIS.. - TCCoA Forums
post #1 of 3 (permalink) Old 03-12-2004, 08:53 PM Thread Starter
How to Test DIS..
Hi.,.
How i know if my DIS is working good or i need to replace it..
sevilla is offline
post #2 of 3 (permalink) Old 03-13-2004, 06:17 PM
Hi,
Just replaced mine yesterday. I didn't have the test equipment - to check it so my mechanic came down and did it.
He put a test meter on one of the wires going into the DIS and found current going in when you turned the engine over. When he checked the "out" side of the DIS (the side towards the coil pack) there was nothing.
With a bad DIS you'll have electrical pulse to the injectors, but not to the coil pack. If the crank sensor is bad, there won't be pulse to the injectors or the coil pack.
Eddie D.
1990 5-speed SC
1997 4.6 LX
BlackThunder is offline
post #3 of 3 (permalink) Old 03-14-2004, 01:10 AM
I'm an SC mechanic in Houston Texas. I have bought a tool that tests the DIS modules. If you send it to me with $10 and return shipping I will test it for you and send it back with the results.
Yo soy un mechanico SC de Houston Tejas. Compre un instrumento que pude examinar los componentes de DIS. Yo puedo hacer los examines y mandar los resultos si puedes mandar diez pesos y los gastos de embarque. Va ser un dia para regresar los resultos.
Vernon Cradier
Email: [email protected]
Current record holder for fewest posts by a Houston Area Thread regular! Vernon says, "We all do what we can."
Vernon C is offline
