leak on a water hose. - TCCoA Forums
post #1 of 4 (permalink) Old 03-13-2004, 11:47 AM Thread Starter
Hi guys..
I noticed i have a leak on a water hose.. this is the hose..
But i have problems to remove it..it have some kind of secures..
how can i remove it?
sevilla is offline
post #2 of 4 (permalink) Old 03-13-2004, 03:09 PM
That looks like the hose going to the heater core. The part you have circled in red is just a hose clamp. You should be able to replace the hose with standard heated hose. Good luck
vancouverBC is offline
post #3 of 4 (permalink) Old 03-13-2004, 06:11 PM
Hi,
That's a molded hose that goes to the heater core. When I did my roller rockers, I replaced it with a new one from Dan Newman.
I'm not sure if regular heater hose will make the right bends without it crimping or going up against the valve cover or cylinder head.
It's easier reaching the heater core end of that hose if you remove the windshield cowling.
Eddie D.
1998 4.6 LX
1990 5-speed SC
BlackThunder is offline
post #4 of 4 (permalink) Old 03-17-2004, 01:23 PM Thread Starter
thanks for the help...
sevilla is offline
