8.8 Question - TCCoA Forums
post #1 of 8 (permalink) Old 04-01-2004, 06:13 PM Thread Starter
8.8 Question
Are all SC 8.8 pumpkins cast iron with aluminum backk plate?
Bill
2coupes is offline
post #2 of 8 (permalink) Old 04-01-2004, 08:23 PM
yes and no
All of the stock SC ones are that way and have traklok.
MarkVIII & Cobra also have 8.8 and the whole housing is aluminum.
The Mark doesn't come with traklok but both will fix our MN12s.
Good Luck
vancouverBC is offline
post #3 of 8 (permalink) Old 04-01-2004, 09:03 PM Thread Starter
Thanks vancouverBC.
2coupes is offline
post #4 of 8 (permalink) Old 04-02-2004, 04:12 PM
Jimmy 2Coupes's Avatar
Actually not all SC's came with trac-lok. All 89-93 auto's and 5 speeds came with trac-lok. 94 & 95 5 speeds came with trac-lok. 94 & 95 auto's came with an open differential.
1995 SC (five speed)
Best E.T. [email protected]
Best MPH [email protected]
Best 60' 1.7489
1994 SC (automatic) [email protected]
On a stock long block with bolt on's
Sweet SC, lower13's coming.
Jimmy 2Coupes is offline
post #5 of 8 (permalink) Old 04-02-2004, 11:34 PM
I stand corrected, thanks
post #6 of 8 (permalink) Old 04-07-2004, 12:04 AM
Ok,
Open differential, Trak lock.. wait a minute! how do you keep the oil from spilling, in the open differential? :p
Seriously though, I never did understand which is better.
Digital Oxygen is offline
post #7 of 8 (permalink) Old 04-07-2004, 02:32 AM
open differential-one wheel peel (side with LESS traction)
trak lok, positraction, locker-diff. ways to transfer power EQUALLY to both wheels
as for which ones better-some posi, or lockers mainly cause your rear to hop around corners b/c the inside wheel can't spin slower. but all in all, any form of locker or posi is better.
charkly is offline
post #8 of 8 (permalink) Old 04-07-2004, 11:46 AM
"Posi"
No "Posi" ever came in ANY Ford product. However Eaton does make an aftermarket "Posi" unit for the 8.8" Ford housing now. Trac-Loc is what SC's have (except as noted above).
A Trac-Loc does NOT hop the inside wheel in a turn. The clutch plates in the diff. allow each wheel to rotate at a different speed, once the bias pressure is overcome by the TQ difference from each wheel.
A Detroit Locker remains locked to each axle EXCEPT during the time that is actually ractheting. During that time, power is only applied to the axle that is still locked.
68COUGAR
68COUGAR is offline
