M90 rebuild kit.... - TCCoA Forums
post #1 of 7 (permalink) Old 05-11-2004, 07:22 PM Thread Starter
AEDM8's Avatar
M90 rebuild kit....
How hard is the M90 to take apart. The M90 on my AED is eating its oil.....must be a bad seal in between the oild and housing.
Where do I purchase the seals at.
Thanks guys......I figured you SC owners would have a better idea where to find these parts than most people.
Mike
AEDM8 is offline
post #2 of 7 (permalink) Old 05-12-2004, 10:45 AM
Jeff Bratton's Avatar
Send a message via AIM to Jeff Bratton
Here is a thread that will be real helpful...http://www.sccoa.com/forums/showthre...0+rebuild+info
Also here is a person who is really good to do business with.... and has what you need to rebuild your SC. (tbird88) aka Wynn.
www.texasthunderbirds.com Scroll down til you see sectio #3: "Supercharger parts"
Good luck!
Jeff B.
'89 Black SuperCoupe
Louisville, Ky.
260 RWHP / 349 RWTQ
Email me: [email protected]
Powered By Magnum Powers MPIII & other Bolt-On's
Check out My SuperCoupe
Jeff Bratton is offline
post #3 of 7 (permalink) Old 09-14-2004, 01:08 AM
I have rebuild kits. The kit contains the seal, 2 bearings (for the snout), a solid coupler, & instructions. I also have the 2 bearings that go in the rear of the case to support the rear of the routers. U can email me at [email protected]
KARDOKTER is offline
post #4 of 7 (permalink) Old 09-14-2004, 09:35 AM
far as I know nobody has the center bearings and they are sealed units
mannysc is offline
post #5 of 7 (permalink) Old 09-14-2004, 11:00 AM
I can get them. The problem is getting the bearings out. Special tools and timing of the rotors is the problem.
post #6 of 7 (permalink) Old 09-24-2004, 10:11 PM
AEDM8 I keep all of the parts in the pic below on the shelf.
Originally posted by mannysc far as I know nobody has the center bearings and they are sealed units
Manny...the center bearings (front rotor brgs) are not sealed, they are open.
'bird
tbird88 is offline
post #7 of 7 (permalink) Old 09-25-2004, 03:11 PM
my Idol now I can compleatly rebuild these blowers in porting.
mannysc is offline
