Will this setup be fine? - TCCoA Forums
post #1 of 11 (permalink) Old 07-01-2007, 08:51 PM Thread Starter
2.25 true duals with a mid mounted Dual In/Dual Out PowerFlow (built in X-Pipe) muffler and then ran out back to 18x3 chrome tips.
Birdman23489 is offline
post #2 of 11 (permalink) Old 07-01-2007, 09:05 PM
justin case's Avatar
thats very similar to what alot of people have on thier 4.6's so yes.Thats also roughly what im going to be doing with my exhuast too.
-Doug
95 T-bird, purple python,i'll drive it again.........someday.
http://www.facebook.com/home.php#/pr...73&ref=profile
justin case is offline
post #3 of 11 (permalink) Old 07-01-2007, 09:31 PM
The Great Obucina's Avatar
will the CARB like it?
"Booyah". Stu Scott.
The Great Obucina is offline
post #4 of 11 (permalink) Old 07-01-2007, 09:36 PM
Oh yeah hes from california
Your car wont mind it,but like he said,CARB might
-Doug
post #5 of 11 (permalink) Old 07-01-2007, 09:40 PM Thread Starter
how much hq or tq would i gain?
post #6 of 11 (permalink) Old 07-01-2007, 09:40 PM
not a whole lot....i would be more concerned about getting the car passed.
post #7 of 11 (permalink) Old 07-01-2007, 09:57 PM Thread Starter
what would be a better alternative to get good hp/tq and get passed?
post #8 of 11 (permalink) Old 07-01-2007, 09:57 PM
a set of mufflers. you arent going to gain a lot by modifying the system after the convertors.
post #9 of 11 (permalink) Old 07-01-2007, 10:59 PM
as long as you leave the cats the carb will like it
**** this cali smog
krazy4 is offline
post #10 of 11 (permalink) Old 07-02-2007, 04:28 PM
biggest restriction on almost every single 4.6 equipped car is the mid pipe (be it a y pipe or an h pipe). rule to passing emissions is to 1 have a set of catalytic convertors placed int eh stock locations. even the slightest movement of them on that mid pipe and cali smog testers will flake out (unless ur introducing them to ur best friend ben franklin usually). if ur going to go with true duals i say go for it, use that true x piece u were talking about but slap some mufflers on where the tips go. just make sure with the pipes leading to the x you put some carsound catalytic convertors (made by magnaflow) in the factory locations and u should be set.
good luck
Travis
blue95lx is offline
post #11 of 11 (permalink) Old 07-02-2007, 11:20 PM Thread Starter
good luck
Travis
thanks trav
