sixers with true duals - in here - TCCoA Forums
post #1 of 9 (permalink) Old 07-23-2007, 11:24 AM Thread Starter
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
does anyone with a 3.8 have a true dual setup with some kind of crossover midmounted and two aftermarket mufflers mounted at the rear? any drone? i cant think of anyone with such a setup and was curious how it sounds.
2014 GT
1990 300ZX TT
big mike is offline
post #2 of 9 (permalink) Old 07-23-2007, 01:31 PM
jco1385's Avatar
i don't have true duals, but mine is -from the front- 97 tubular manifolds, custom downtubes w/ no cats, no resonator y'd before the tank, y'd bak out after the tank into 2 si/so 40 series flows. there's a drone at highway speeds but my stereo drowns it. also it almost sounds like a riced honda at around 3k
jco1385 is offline
post #3 of 9 (permalink) Old 07-23-2007, 02:00 PM Thread Starter
Motorboatin' SOB
big mike's Avatar
i would get cats if i were you. do you have tips or turndowns?
2014 GT
1990 300ZX TT
big mike is offline
post #4 of 9 (permalink) Old 07-23-2007, 02:05 PM
jco1385's Avatar
tips. why should i get cats?
jco1385 is offline
post #5 of 9 (permalink) Old 07-23-2007, 02:07 PM Thread Starter
Motorboatin' SOB
big mike's Avatar
no cats makes the exhaust more raspy.
2014 GT
1990 300ZX TT
big mike is offline
post #6 of 9 (permalink) Old 07-23-2007, 02:23 PM
jco1385's Avatar
cats are more expensive than no cats......which is why they are still at the exhaust shop. i should've gotten advice before i went to get mine done. i had just installed the new engine and had to cut the old down-tubes out so it was running open all the way there (quite loud!) this is what the exhaust guy recommended so here it is. i wish i could go back now, cuz it'd be completely different.
jco1385 is offline
post #7 of 9 (permalink) Old 07-23-2007, 06:01 PM
That would be dual exhaust, not true duals.
One of the 89 XR7's that I parted out had dual 2.25 with an X-pipe run back to 3" Flowmasters. It sounded great at idle, but as soon as you opened the throttle you would swear the namebadge said Honda.
These V6's simply need a midmounted muffler/resonator to sound anywhere near decent.
-Rod
post #8 of 9 (permalink) Old 07-23-2007, 06:27 PM
jco1385's Avatar
Thumbs up
jco1385 is offline
post #9 of 9 (permalink) Old 07-25-2007, 03:35 PM
Send a message via AIM to Red97Tbird
I have a 97 t-bird with true duals. I have True 2 in dual on mine with Flowmasters. Every one says it sounds good. There is some resignating sound when I drive but not to bad. I usally drive with the windows down so I never hear it . I like it and it made a good difrence in HP.
Red97Tbird is offline
