Can you pass inspection with true duals - TCCoA Forums
post #1 of 7 (permalink) Old 07-28-2007, 02:57 PM Thread Starter
I have true duals on my bird and I was just wondering if I would need to put the old exhaust on to pass inspection? I have the cat and resonators, no muffs
TBirdLXNewbie is offline
post #2 of 7 (permalink) Old 07-28-2007, 04:02 PM
visual? or sniff? if you have both upper cats, you should be fine
post #3 of 7 (permalink) Old 07-28-2007, 07:53 PM
MarknKellie's Avatar
Send a message via AIM to MarknKellie Send a message via MSN to MarknKellie
Alot of it depends on what state you reside in & what the standards are. In the state of Virgnia, if you have a Converter & 1 muffler itll pass. Some states require just Converters, some none at all. I'd check first. I know here when they inspect a car, they put it in a car lift & look at the brakes & exhause at the same time. so Visual will be a dead give away since a muffler or cat wont be there.
MarknKellie is offline
post #4 of 7 (permalink) Old 07-28-2007, 09:10 PM
thunderbirdlver's Avatar
Send a message via AIM to thunderbirdlver Send a message via Yahoo to thunderbirdlver
yea i am supposed to have a muffler too.
If your exhaust tip is larger than your cylinder bore, then you are a Ricer.
thunderbirdlver is offline
post #5 of 7 (permalink) Old 07-29-2007, 11:13 AM
It depends on who you know and where you are. I got my car inspected and I've got a busted windshield. I used to be able to get a car inspected without it ever leaving the house.
ipsd1 is offline
post #6 of 7 (permalink) Old 08-05-2007, 11:20 PM Thread Starter
I have no camera so this picture i found is the closest I can get...
http://www.dnperformance.com/images/gto_exhaust3.jpg
post #7 of 7 (permalink) Old 08-05-2007, 11:28 PM Thread Starter
oh btw, it isnt true duals its just one from the cat and is welded into two with resonators near tips.
