I want a new exhaust - TCCoA Forums
post #1 of 2 (permalink) Old 08-04-2007, 04:37 AM Thread Starter
Ok so I'm thinking of redoing the exhaust on my 96' v8 bird. I love flowmasters but I'm looking for more flow and not having the mufflers hanging down. Right now after the manifolds I have down tubes running into a y pipe into one pipe and then into another y pipe splitting out running to two mufflers out the back. I was wondering, if I were to put a glass pack between the two y pipes and then run pipes out the back would that work for flow and such?
TBirdsRMachismo is offline
post #2 of 2 (permalink) Old 08-04-2007, 11:54 AM
Bradone's Avatar
If you want flow you need to go to True Duals. There are threads on it in this section.
Brad
[email protected] (engine/trans is stock)
Bradone is offline
