Flex exhaust tubing - TCCoA Forums
post #1 of 8 (permalink) Old 08-05-2007, 09:22 PM Thread Starter
Flex exhaust tubing
I saw some flexibl exhaust tubing today. Since sometimes it's such a pain in the ass to do exhaust on these cars it got me thinking. Has anyone ever used this stuff before?
TBirdsRMachismo is offline
post #2 of 8 (permalink) Old 08-05-2007, 10:28 PM
Bradone's Avatar
Please be more specific. Can you post a link? That would help answer your question.
Brad
[email protected] (engine/trans is stock)
Bradone is offline
post #3 of 8 (permalink) Old 08-05-2007, 10:50 PM Thread Starter
I have no link to it but its the same diameter as exhaust tubing but is crimped every inch or so to allow it to bend. The guy said ppl use it for turbos and such but it looks like it would work.
post #4 of 8 (permalink) Old 08-05-2007, 11:00 PM
Traveler's Avatar
The kind you describe isn't as good as the woven kind. I've seen 10"-12" sections of the woven kind at O'Reillys. It would be great for making difficult joints in the exhaust system, or getting two sections to line up better.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #5 of 8 (permalink) Old 08-05-2007, 11:07 PM Thread Starter
So in theory I could use some of this stuff from O'Reillys to make the bends I'd need to run true duals?
post #6 of 8 (permalink) Old 08-05-2007, 11:08 PM
Traveler's Avatar
Yes... In Theory
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #7 of 8 (permalink) Old 08-05-2007, 11:50 PM
Bradone's Avatar
Thank you. I couldn't remember the name of the semi ok kind to use. W-o-v-e-n.
Brad
Bradone is offline
post #8 of 8 (permalink) Old 08-06-2007, 12:51 AM
the braided steel "woven" couplers are ok but when you said flex tubing and crimps I instantly thought of that nasty ribbed tubing that they sell in every autoparts store I've ever been in, I think chevy used something similar on old trucks but ewwww NO!... exhaust is not something to skimp out on I'm afraid.
