v6 exhaust manifolds - TCCoA Forums
post #1 of 7 (permalink) Old 09-24-2007, 07:08 PM Thread Starter
fl96thunderbird's Avatar
Send a message via Yahoo to fl96thunderbird
Searching brought nothing for what I'm looking for. Is there somewhere other than Ford to buy regular manifolds? My driver side has a big crack on the engine side next to the collector. Like its been bent towards the wheel. Its throwing the flange for the y-pipe off on that side a little bit, not sitting flush. JB Weld didn't help. My only other idea is to try and pry it back then JB it again.
I was reading the Mustang forums to see if I could use those, but the O2 sensor is in the collector not y-pipe, so I don't think they would work.
Thanks In Advance.
SOLD the 96 in favor of a 97 ABS, TC, Sunroof
OEM E46 Bi-Xenon D3S
XBox 360 gamertag: POPIMP96
fl96thunderbird is offline
post #2 of 7 (permalink) Old 09-24-2007, 07:18 PM
jco1385's Avatar
i have some, but they need studs
edit: nm i left them at the exhaust shop. my bad man. may have one of them. i'll look
jco1385 is offline
post #3 of 7 (permalink) Old 09-24-2007, 08:32 PM
nickmckinney's Avatar
I think the 96-97 are different.
nickmckinney is offline
post #4 of 7 (permalink) Old 09-24-2007, 08:33 PM Thread Starter
96-97 are different from earlier year mn12's supposed to be tubular iirc.
post #5 of 7 (permalink) Old 09-24-2007, 11:04 PM
Resident Line Creator
th3subtl3on3's Avatar
Correct. I just grabbed a pair out of the yard last week to be put on my car during the new engine build. Here are what they look like.
And in this picture below, from supercoupeperformance.com, you can see the earlier style on the left.
-Brian
th3subtl3on3 is offline
post #6 of 7 (permalink) Old 09-24-2007, 11:14 PM
jco1385's Avatar
didn't notice the '96.... whoops. thats what i swapped my old manifolds for.
jco1385 is offline
post #7 of 7 (permalink) Old 09-29-2007, 01:31 PM Thread Starter
The junkyard had one for me, but after searching no one has posted sizes for the studs. Does anyone know the size(s)?
