4.6 header install? - TCCoA Forums
post #1 of 24 (permalink) Old 09-28-2007, 11:43 PM Thread Starter
94fastbird's Avatar
Send a message via MSN to 94fastbird
4.6 header install?
when installing kooks 3/4 length headers is there any clearance issues? as far as starter and engine bay?
94fastbird is offline
post #2 of 24 (permalink) Old 09-29-2007, 07:42 AM
Chapter Director Coordinator
jamesD's Avatar
they fit pretty tight
not recommended to do in car
I bust ARP bolts by hand...
If Guns kill people, then...
...pencils miss spel werds
~Gun Owners of America
jamesD is offline
post #3 of 24 (permalink) Old 09-29-2007, 09:41 PM
drop the k....
or
disconnect the motor mounts and lift the motor about 2 inches and fight the whole time
or
pull the heads... connect them with stage 8 locking fasteners.... be done reinstall heads... enjoy
there really is no easy way
post #4 of 24 (permalink) Old 09-30-2007, 03:05 PM
Refrigerator Raider Hater
GreenBird's Avatar
I put mine on while the engine was out. If I didn't have a mark 8 oil pan it would have gone in like butter.
Dropping the K member is probably the easiest way.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #5 of 24 (permalink) Old 09-30-2007, 08:40 PM Thread Starter
94fastbird's Avatar
well i was thinking about pulling the motor again. when i do the pi swap or i was wondering when doing the pi swap if just putting them on with the motor still in. just pulling heads. but i think it would be easier to pull motor and do it that way. while i build the motor up more than what it is .
post #6 of 24 (permalink) Old 09-30-2007, 09:57 PM
jamesD's Avatar
if you are gonna do a pi motor swap, then just wait and do it all at once
jamesD is offline
post #7 of 24 (permalink) Old 10-01-2007, 12:37 AM Thread Starter
94fastbird's Avatar
no i just gonna swap out the heads and put 234/238 duration comp cams and trickflow intake. the bottom end of my motor is already built up. but i think it would be easier to just pull the motor again and do the swap on the cherry picker. then put it back in. you think that would be the easiest?
post #8 of 24 (permalink) Old 10-01-2007, 01:49 AM
Fry Rice Specialist
Casper's Avatar
instead of cherry picker put it on an engine stand so when you retorque the head the engine won't swing everywhere to make your life easier and get enough leverage for accurrate torque spec.
CarDomain Page
Casper is offline
post #9 of 24 (permalink) Old 10-01-2007, 06:22 AM
jamesD's Avatar
really, it's only another half step..
jamesD is offline
post #10 of 24 (permalink) Old 10-01-2007, 02:30 PM
If your pulling the heads.... why bother with the picker???? Just pull the heads, bolt up the cams and headers on a bench, and reinstall.... no messing with the motor mounts or tranny bolts, or flex plate. Just be sure to get a bag of rubber bands for the head to block bolts on top of your cylinder head swap kit from ford, and stage 8 locking washers for the headers. This is one of those things to do right the first time.
post #11 of 24 (permalink) Old 10-04-2007, 07:05 PM
TGJ
Baddest N/A NPI in Canada
TGJ's Avatar
When re-installing the heads, do not just bolt everything up and go. I would degree the cams to see that they are timed where they are supposed to be.
TGJ is offline
post #12 of 24 (permalink) Old 10-04-2007, 08:20 PM
I always seem to forget to recommend that... but yes you must degree your cams
post #13 of 24 (permalink) Old 10-31-2007, 12:07 AM
by degreeing your cams what do you mean? i had a broken intake valve spring on my stock heads. i picked up some stock 96 style heads and had them rebuilt, im just about to reinstall in the car. those heads should be a direct swap correct? suggestions......
mackenziet is offline
post #14 of 24 (permalink) Old 10-31-2007, 12:20 AM
The Great Obucina's Avatar
the cams dont need to be degreed.
"Booyah". Stu Scott.
The Great Obucina is offline
post #15 of 24 (permalink) Old 11-01-2007, 10:12 PM Thread Starter
94fastbird's Avatar
most ppl only degrees the cams for full on race motors, for the most accurate cam timing, like great obucina said u dont need to degree them, i didn't degree mine when i rebuilt the motor and it run perfectly fine.
Current Mods:
balanced & blueprinted block. by my dad & I @ (The Engine Shop INC.) i'm running manley forged i beam rods, forged manely .020 16cc dish pistons, forged 8 bolt crankshaft thats been polished, corba high volume oil pump, block has been align bored & decked. ported and polished early production heads, heads have been milled, 3 angle valve grind, ported exhaust manifolds, gasket matched intake, dual inlet dual outlet dynomax turbo muffler underseat with 3inch turndowns. transmission heavy duty clutches, b&m shift kit, frrp t lock with 373.
Future Mods:
pi swap with some comp cams and the new trickflow intake, high stall torque converter and mark 8 drive shaft, kooks 3/4 lenth headers and xcal2
post #16 of 24 (permalink) Old 11-01-2007, 10:22 PM Thread Starter
94fastbird's Avatar
just get the marks lined up follow the chiltons, or hayes manual and u'll be fine, degree consist of dial indicator with 4 inch extention, screw inpost for dial indicator, positive stop tool solid vavle adjuster, timing wheel, pointer, camshaft lock tool, racker arm installation tool. you dont need this to put your 4.6 in time. it's nice to have your cams degreed while doing intall but it's not required.
Current Mods:
Future Mods:
post #17 of 24 (permalink) Old 11-01-2007, 10:23 PM
degreeing a set of cams SHOULD be done on any aftermarket camshaft...period.
post #18 of 24 (permalink) Old 11-01-2007, 10:34 PM Thread Starter
94fastbird's Avatar
i've know guy's that didn't degrees theres with aftermarket and didn't have any problems they weren't as high as lift as most cams are, i know i'm going to degree mine when i do my pi head swap
Current Mods:
Future Mods:
post #19 of 24 (permalink) Old 11-01-2007, 11:05 PM
i dont care what others fail to do, its their lost power. I also dont care what requires less effort...lift doesnt matter, if its an aftermarket grind, degree it.
post #20 of 24 (permalink) Old 11-01-2007, 11:24 PM Thread Starter
94fastbird's Avatar
i know what u mean, i'm just saying what i've seen, they didn't want to spend the extra money to have the shop do it or spend the time to do it them selfs, when i put mine in i'm gonna do it, cause ever little bit of power helps. i didn't degree mine cause there stock cams.
Current Mods:
Future Mods:
post #21 of 24 (permalink) Old 11-01-2007, 11:26 PM
David_viny's Avatar
Well if the cams are off, is there even a way to bring them into spec? I would imagine that a full tooth adjustment would be too much and the Fidanza adjustable gears from what I’ve read are crappola unless you maybe modify them.
1995 T-bird 4.6l - Eibach lowering springs, Cobra R hood, One 12" sub woofer, Alpine type-R front speakers. 16.249 @85.11mph 1/4 mile
2001 Pontiac Trans Am WS6 - Cam, headers, HPtuned by me.
David_viny is offline
post #22 of 24 (permalink) Old 11-01-2007, 11:32 PM
the OEM gears. Hack the tooth, adjust where necessary and the torque the bolt.
post #23 of 24 (permalink) Old 11-02-2007, 05:44 AM
twin turbo 281's Avatar
even the motors assembled by ford have been found to have some sloppy cam tolerances. I didnt degree mine I just made sure to turn the motor over a few times by hand to check for clearance. Im running low lift stage 2s
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #24 of 24 (permalink) Old 11-02-2007, 10:11 AM
Fry Rice Specialist
Casper's Avatar
CarDomain Page
Casper is offline
