eliminating all cats - TCCoA Forums
post #1 of 36 (permalink) Old 10-31-2007, 12:02 AM Thread Starter
i am looking for a setup that will eliminate all my cats, i have the 95 4.6 and im rebuilding top half of motor. i want to still run single pipe all the way back but i cant find anyone to make me the same setup without cats. any ideas?
mackenziet is offline
post #2 of 36 (permalink) Old 10-31-2007, 03:06 AM
It's illegal for any certified shop to do that for you, so either shop around until you find one that will or punch out the cats yourself. Maybe you can tell them it's for offroad or something.
post #3 of 36 (permalink) Old 10-31-2007, 05:32 AM
Awaiting E-Mail Confirmation
tinman_72's Avatar
The reason they won't do it is that it is illegal to remove them. It is not illegal for them to run pipe without putting on cats. Try removing them yourself and just having them run new pipe.
tinman_72 is offline
post #4 of 36 (permalink) Old 10-31-2007, 12:06 PM
That might be a state to state type of law, I don't know. In Illinois, we were told (8 years ago) a car that had a convertor from the factory had to leave the shop with a convertor on it if we did ANY exaust work. This was a Midas and they were pretty uptight about that stuff. Try a mom & pop shop and remember, cash is king. If they don't issue a recipt they never did it haha.
Lorne
Speedracer_m5 is offline
post #5 of 36 (permalink) Old 10-31-2007, 03:33 PM
twin turbo 281's Avatar
actually legallly even if a shop removes a off road exhaust to say pull a tranny they cannot replace the exhaust system after the work without installing a convertor(s) before it leaves the shop. but some shops really dont follow along
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #6 of 36 (permalink) Old 10-31-2007, 03:43 PM
There's your answer, Cash is King, No Reciepts, and the less law abiding the shop owner is the better...
Southpaw is offline
post #7 of 36 (permalink) Old 10-31-2007, 08:51 PM Thread Starter
well i have the front part of the exhaust off from where it conects to the exhaust manifolds to just after the third cat. im just wondering if it would be possible to take that piece to a shop and have them cut the cats off and replace with pipe? and if i did have to punch out the cats how do i do that? they seem to be on an awkward angle and as for the third cat (y-pipe) how would i tackle that?
post #8 of 36 (permalink) Old 10-31-2007, 09:17 PM
Why do you want to eliminate your cats? Just get some high flow cats. I don't even think that they are that great of a restriction.
Natheo is offline
post #9 of 36 (permalink) Old 11-01-2007, 08:11 AM Thread Starter
well the one on the drivers side looks pretty clogged and i want a better sound from my exhaust. i have flowmaster original 40's on the car and i know if i take the cats off it will really give it that good rumble.
post #10 of 36 (permalink) Old 11-01-2007, 08:38 AM Thread Starter
post #11 of 36 (permalink) Old 11-01-2007, 11:34 AM
jco1385's Avatar
when i did my engine install, i just cut the downtubes off behind all the cats but before the resonator. called a shop to see if they'd run pipe w/o cats. they said they will not. drove to the same shop. they did it w/o a problem. they just cant tell you that because there is like a 10,000 dollar fine. at least thats what i was told. so just drive to a shop and ask. they'll tell you no on the phone everytime.
jco1385 is offline
post #12 of 36 (permalink) Old 11-01-2007, 10:27 PM
94fastbird's Avatar
Send a message via MSN to 94fastbird
thats what i did to my exhaust, i took the cats off, brought it into the exhaust shop they ran all the pipe, told me that as long as i take them off they'd do the exhaust they can't get in trouble for that i could though, but here in iowa we dont have to worry about much. dont have state inspections
Current Mods:
balanced & blueprinted block. by my dad & I @ (The Engine Shop INC.) i'm running manley forged i beam rods, forged manely .020 16cc dish pistons, forged 8 bolt crankshaft thats been polished, corba high volume oil pump, block has been align bored & decked. ported and polished early production heads, heads have been milled, 3 angle valve grind, ported exhaust manifolds, gasket matched intake, dual inlet dual outlet dynomax turbo muffler underseat with 3inch turndowns. transmission heavy duty clutches, b&m shift kit, frrp t lock with 373.
Future Mods:
pi swap with some comp cams and the new trickflow intake, high stall torque converter and mark 8 drive shaft, kooks 3/4 lenth headers and xcal2
94fastbird is offline
post #13 of 36 (permalink) Old 11-02-2007, 05:27 AM
just gut them if you want. Just go to home depot and find some angled tools to get at the rough angles.
post #14 of 36 (permalink) Old 11-02-2007, 07:04 PM
Beerdog80's Avatar
I just gutted the two up top, put them back in place for 'legal looks' and removed the resonator from the middle. Easy, far cheaper than high flow cats and even those will still clog up at some point in time. Had some on my stang, hit some water..and that was all she wrote.
Beerdog80 is offline
post #15 of 36 (permalink) Old 11-02-2007, 07:37 PM
Theoretically all cats should last forever, but because there are always rich/lean running conditions (even for less than a second before the PCM adjusts the A/F ratio) and eventual problems with a sensor or two (like a wearing oxygen sensor or dirty/faulty MAF), they will enivitably be destroyed.
post #16 of 36 (permalink) Old 11-02-2007, 07:42 PM Thread Starter
how did you gut them?, they seem almost impossible to get into
post #17 of 36 (permalink) Old 11-02-2007, 10:26 PM
dwinthrup's Avatar
use a cut off tool and cut the shield off and then cut in in half the long way and cut that section off punch them out with a hammer and a pry bar weld the side back on and the heat shield. ware a dust mask too!
dwinthrup is offline
post #18 of 36 (permalink) Old 11-03-2007, 03:39 PM
Beerdog80's Avatar
Thats about it. I undid the flange bolts and then cut the weld. Was not really all that hard and didnt take much time since I had access to a car lift.
post #19 of 36 (permalink) Old 11-03-2007, 05:15 PM
i just used some angled tools and ti took the better half of a day to do it
post #20 of 36 (permalink) Old 11-04-2007, 07:46 AM Thread Starter
how can i ensure that the angles that the cats are on will be welded exactly where they need to be after i cut it off?
post #21 of 36 (permalink) Old 11-04-2007, 07:51 AM
BLittle500's Avatar
Last year, when I gutted the cats out, I just drilled a big enough hole to get my punch straight through the cat (like going from the engine to the rear), then once I got it all knocked out, I just welded a small piece of steel to patch the hole.
This year, I took my Y-pipe down to the local midas, told them what I wanted, and that it was going on a race car (which mine honestly was, but I guess you could fib if you wanted) and they made me up two down pipes to the length I wanted.
Brandon
BLittle500
2008 Racing Shirts Are In!!!
1995 Ford Thunderbird LX 4.6L (Race Car)
1994 Ford Thunderbird LX 4.6L (2009 Race Car)
2003 Ford F-250 Superduty 5.4L (Daily Driver) FOR SALE
2004 Honda CBR600RR uhhh 0.6L (Sh!ts & Giggles)
1995 LX Dirt Oval Race Car
BLittle500 is offline
post #22 of 36 (permalink) Old 11-04-2007, 08:37 AM
Traveler's Avatar
I just took my cats off of the manifolds along with the exhaust pipe to where it reaches the bottom of the car. Then I took both of them to an exhaust shop and asked them to use them as "templates". Bend new downtubes with the same angles and bends as the downtubes with cats, just no cats. Then I put the new downtubes on myself. There isn't any law about exhaust shops bending pipes.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #23 of 36 (permalink) Old 11-04-2007, 08:55 AM
V8ThunderCat's Avatar
After taking my y-pipe off I had no problem gutting the first 2 cats but the 3rd one is another story. Luckily someone had already replaced that with a strait pipe so I had it easy. When I gutted the 2 cats all I used was a long pry bar and a good sized hammer. Once in a while I got the pry bar jammed in there and I had a hard time pulling it out but after about 45min of whacking the cats seemed to be empty. Now all I wish I could do now is replace the resonator with a strait pipe but that can wait until I find a job.
-Randy-
V8ThunderCat is offline
post #24 of 36 (permalink) Old 11-04-2007, 12:26 PM Thread Starter
so could i use a metal cutting wheel and score a line in the pipe on two sides so i know exactly where it need to go back together and then cut the cat off and split with the metal cutting wheel and gut and reweld back together?
post #25 of 36 (permalink) Old 11-04-2007, 12:59 PM
i would go with the idea of cutting a hole on top and then welding a panel on to cover it up.
post #26 of 36 (permalink) Old 11-04-2007, 01:36 PM Thread Starter
hmmmmm so i should maybe cut a whole in the pipe between the cat and flange that meets the exhaust mani and punch out the cat that way? i still will need to separate the third cat from the whole setup in order to get all the ceramic out correct? why does ford have to make everything so freakin hard lol!
post #27 of 36 (permalink) Old 11-04-2007, 02:03 PM
BLittle500's Avatar
Mackenziet, I'll grab some pics of my old Y-Pipe, I think I still have it, I'll show where I drilled through and re-welded. Once you get the cat knocked out enough (small enough pieces) you should be able to dump most of it out of the pipe where it meets the manifold.
Brandon
BLittle500
post #28 of 36 (permalink) Old 11-04-2007, 04:19 PM Thread Starter
much appreciated thank you
post #29 of 36 (permalink) Old 11-04-2007, 05:41 PM
That makes a hell of a lot more sense then trying to gut them and reuse the shells...
Southpaw is offline
post #30 of 36 (permalink) Old 11-05-2007, 08:29 AM
jco1385's Avatar
if you have no inspections (such as AL, and FL) just get downtubes made w/o cats. it's fairly cheap enough, and not a pain in the a$$
jco1385 is offline
