difference in exhaust? - TCCoA Forums
post #1 of 10 (permalink) Old 11-04-2007, 10:04 PM Thread Starter
I recently replaced the motor in my 95 3.8 with one out of a 93 and everything lined up and bolted up fine except the exhaust. The passenger side cat wants to hit against the body and not bolt up flush/tight to the manifold. Is there a difference in the manifolds or exhaust set up in the two years? I used the 93 manifolds since they were already bolted on to the motor, if needed i might replace them with the others. Any help would be great, i just had to go thru inspection and I told dude i would take care of it asap since it played deaf to the leak. Worse come to worse I will just do a full custom exhaust.
bubbaking is offline
post #2 of 10 (permalink) Old 11-04-2007, 10:17 PM
Yes, the angle of the collector on the 3.8L's changed after 93.
-Rod
post #3 of 10 (permalink) Old 11-05-2007, 05:23 PM Thread Starter
you refering to the collector on the manifold side or the cat side?
post #4 of 10 (permalink) Old 11-05-2007, 07:17 PM
The angle of the collector on the manifold changed, which necessitated a change in the angle of the downtube to mate up to it.
Basically, if you're still running your stock 95 y-pipe, you'll need to switch the passenger side '93 exhaust manifold out for the '95 piece from your old engine.
-Rod
post #5 of 10 (permalink) Old 11-06-2007, 04:26 PM Thread Starter
yea, lets pretend i didnt make that last comment. my brain was on vacation last night and as soon as i posted that last question i realized.
post #6 of 10 (permalink) Old 11-06-2007, 05:02 PM
Sounds like a very important piece of MN-12 trivia. No one has ever mentioned that fact as far as I know.
Hollywood Ed is offline
post #7 of 10 (permalink) Old 11-06-2007, 05:10 PM
Never asked.
-Rod
post #8 of 10 (permalink) Old 11-19-2007, 12:33 PM
LOLA's Avatar
Did the angle change again with the tube exhaust manifolds on the 96-97 engines or is it the same?
I'm going to be puting '96 exhaust manifolds on my '92 so I'm trying to figure out what all I will need to modify.
LOLA is offline
post #9 of 10 (permalink) Old 11-19-2007, 04:23 PM
Yes, it changed there also.
post #10 of 10 (permalink) Old 11-19-2007, 04:27 PM
LOLA's Avatar
Would this be fairly simple to fab up? SCP has down tubes but at $349 for a pair with cats is way more than I want to pay.
LOLA is offline
