For all you catless people - TCCoA Forums
post #1 of 21 (permalink) Old 12-16-2007, 11:21 AM Thread Starter
Gcline's Avatar
http://forums.evolutionm.net/showthread.php?t=215795
This was posted on a local forum im apart of, seems like a good, cheap idea. Hell if it dont work its only 5 bucks.
/discuss
Daily Driver, 38mpg!
Gcline is offline
post #2 of 21 (permalink) Old 12-16-2007, 07:29 PM
V8ThunderCat's Avatar
I think that's a much better idea than wiring in a resistor or spending big bucks on a mil eliminator. I hope that the threads are the same for ours but I don't see why they wouldn't be. If I had my drill I would do that tomorrow but I'll have to wait until I come home after X-Mas. I'm sick and tired of seeing that CEL.
-Randy-
V8ThunderCat is offline
post #3 of 21 (permalink) Old 12-17-2007, 06:35 AM
94fastbird's Avatar
Send a message via MSN to 94fastbird
yes i heard of alot of ppl doing this a have had very good resutls. better than spending the 60 buck on th mil eliminators through dallas mustang or summit. theres only 2 different thread sizes for o2 sensers 14mm and 18mm for older cars newer ones are coming out with 12mm and the 14 18's again. but yes it does work.
Current Mods:
balanced & blueprinted block. by my dad & I @ (The Engine Shop INC.) i'm running manley forged i beam rods, forged manely .020 16cc dish pistons, forged 8 bolt crankshaft thats been polished, corba high volume oil pump, block has been align bored & decked. ported and polished early production heads, heads have been milled, 3 angle valve grind, ported exhaust manifolds, gasket matched intake, dual inlet dual outlet dynomax turbo muffler underseat with 3inch turndowns. transmission heavy duty clutches, b&m shift kit, frrp t lock with 373.
Future Mods:
pi swap with some comp cams and the new trickflow intake, high stall torque converter and mark 8 drive shaft, kooks 3/4 lenth headers and xcal2
94fastbird is offline
post #4 of 21 (permalink) Old 12-17-2007, 12:59 PM
jco1385's Avatar
would this help my gas hog problems? i have no CEL but it seems like this v6 is suckin juice like a v8. also my odometer doesnt work so i cant tell really. there was a CEL before i put the chip in. the guy i bought the chip from (JMS Performance in Lucedale, MS) said it would eliminate all CELs. the light isn't on, like i said but it seems to use a lot of gas. i have no cats, and i just bought new (Bosch) o2s when i had my exhaust done (about 6-8 months ago).
sorry for the essay, but input would help a lot. i may make a thread about it.
jco1385 is offline
post #5 of 21 (permalink) Old 12-17-2007, 02:02 PM
No, the rear 02's have nothing to do with fuel consumption or economy.
post #6 of 21 (permalink) Old 12-18-2007, 05:26 PM
When my car throws the 0430 code, it starts to run terribly prior to the cel turning on, and my gas mileage is horrible. Is the computer getting signals from the rear 02's that tell it the cats are bad? The car seems to run terribly when that light is on, then it runs fine after I reset the cel with a codereader.
My cats make no rattle, but they smell like rotten eggs.
s.milosevic is offline
post #7 of 21 (permalink) Old 12-18-2007, 06:06 PM
Yes, that code means the computer has detected the cat on the driver's side isn't working right. More often than not when the cat fails, it breaks apart and clogs the exhaust. This makes the car run bad. The fact that the code itself is triggered bears no weight on how the computer runs the car.
The rotten egg smell can be either the cat, the air/fuel mixture, or the gas (ethanol can contribute to that smell).
post #8 of 21 (permalink) Old 12-27-2007, 09:02 PM
why not pull the rear O2s out, hang em outside the exhaust, then plug the hole?
hinertrucker is offline
post #9 of 21 (permalink) Old 12-28-2007, 12:22 AM
Because then the sensor will be seeing way too much oxygen and will be pegged out lean, setting a code.
post #10 of 21 (permalink) Old 12-30-2007, 04:21 AM
uh, aren't the optimum exhaust emissions the equivalent of water? you got hydrogen, oxygen, and NOx.
post #11 of 21 (permalink) Old 12-30-2007, 04:23 AM
also, you could buy one set of plug non-foulers and plug the hole with JB Weld.
post #12 of 21 (permalink) Old 12-30-2007, 11:00 AM
Refrigerator Raider Hater
GreenBird's Avatar
exhaust has very little oxygen in it. you'd want to seal up the sensor to keep it from being exposed to air.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #13 of 21 (permalink) Old 01-01-2008, 11:42 PM
so, put a non-fouler between the sensor and the exhaust and fill the hole in the non-fouler with JB Weld.
post #14 of 21 (permalink) Old 01-09-2008, 09:34 PM
Very little not no oxygen.
1996 sport 4.6 130k and still strong.
1991 SC 3.8 project and toy.
ncoop23 is offline
post #15 of 21 (permalink) Old 01-09-2008, 09:39 PM
Nativedetroiter's Avatar
Now that is an excellent idea. One that I am going to have to look into. That is a nice option.
Nativedetroiter is offline
post #16 of 21 (permalink) Old 02-10-2008, 07:26 AM
mikemelancholic's Avatar
Awesome idea, but I don't think there's enough room for it where the stock bungs are.
mikemelancholic is offline
post #17 of 21 (permalink) Old 02-12-2008, 03:41 AM Thread Starter
Gcline's Avatar
No, then your just completely blcoking it off. He was saying if you dont want to run o2's at all, that would be a way to plug up your hole.
Gcline is offline
post #18 of 21 (permalink) Old 03-10-2008, 07:13 PM
will this stop the cel from coming on even if the cat are bad
bigjohn68 is offline
post #19 of 21 (permalink) Old 03-10-2008, 11:10 PM
Yes. A bad cat is a missing cat as far as the computer is concerned.
post #20 of 21 (permalink) Old 03-15-2008, 02:08 PM
im going to try this mod soon
post #21 of 21 (permalink) Old 03-21-2008, 04:02 AM
Has anyone tried this on a bird yet?
Rah4002 is offline
