5.0 and 3.8 downpipes the same? - TCCoA Forums
post #1 of 4 (permalink) Old 12-24-2007, 10:17 PM Thread Starter
Pedal Faster
Josh_Keady's Avatar
I'm swapping a '93 5.0L in to my '90 3.8. I haven't gotten the motor out of my '90 yet, but I noticed that the down pipes on the 5.0 looked a lot like the setup on my 3.8. Are they the same? That is, will the V6 exhaust bolt up to the V8 manifolds? I have a pretty nice 2.5" exhaust system on the '90 already, I'm hoping to reuse as much (all?) of it as possible.
Also, the passenger side O2 sensor on the 5.0 is in the exhaust pipe instead of the manifold. I can't remember if it's like this on the V6 or not. Anyone remember?
Josh Keady
Josh_Keady is offline
post #2 of 4 (permalink) Old 12-24-2007, 10:34 PM
ClintD's Avatar
Yup, even the cat's are the same. usually the V6 only has 2 cat's. But you will have to weld in a bung for the O2 unless you remove the EGR tube on the exhaust manifold and put the O2 in there.
ClintD is offline
post #3 of 4 (permalink) Old 12-25-2007, 10:59 AM
jk69cat's Avatar
put the dual exhaust on it or you'll choke it
mn12 less!
jk69cat is offline
post #4 of 4 (permalink) Old 12-25-2007, 12:01 PM Thread Starter
Pedal Faster
Josh_Keady's Avatar
My car's got duals.
Josh Keady
