not a good idea... - TCCoA Forums
post #1 of 16 (permalink) Old 01-20-2008, 06:23 PM Thread Starter
not a good idea...
so i had high flow cats magnaflow midmounted muffler di/so.....and the drone was getting to me really bad. so i decided to take out the muffler and put in a y pipe so now its high flow cats single pipe midbody, then y's off at diff to tips.
well that may have been a bad idea lol it got rid of SOME drone but i was expecting to have less.
all i know is as soon as i can im putting some mufflers out the back under the trunk, just dont know what kind yet. i dont care much on sound as i used to, i just want to get rid of this terrible drone.
anyone have any recommendations for mufflers out the back? preferably some cheap(price) ones.
Dean
1993 3.8L Tbird----sold
1994 4.6L Tbird----sold
1995 Mark VIII----sold
2004 Mustang GT----sold
2003 Mach 1----current
smitty2919 is offline
post #2 of 16 (permalink) Old 01-20-2008, 06:24 PM Thread Starter
ohh forgot to add this was all on a 93 3.8L
post #3 of 16 (permalink) Old 01-20-2008, 06:26 PM
Dynomax is quiet!
post #4 of 16 (permalink) Old 01-20-2008, 06:45 PM Thread Starter
any style? obviously other than the bullets. id like to have some sound to it to justify buying the cats and having them put on lol
post #5 of 16 (permalink) Old 01-20-2008, 06:50 PM
I have the cat back system on mine, came with turbos.
post #6 of 16 (permalink) Old 01-20-2008, 07:07 PM
Looks good Joe. Fixing to get the same kit for my bird Pretty good price as well
post #7 of 16 (permalink) Old 01-20-2008, 07:11 PM Thread Starter
how does it sound? do you have the stock cats on it? id like it to sound like i have exhaust on it
post #8 of 16 (permalink) Old 01-20-2008, 07:22 PM
Go to dynomax .com .There is a link there to hear like they sound
post #9 of 16 (permalink) Old 01-20-2008, 07:42 PM Thread Starter
Joe, i looked up on dynomax the part number of the mufflers that came with your cat back and they were $98 off of summit. but i did find these
http://store.summitracing.com/partde...5&autoview=sku
post #10 of 16 (permalink) Old 01-20-2008, 08:20 PM Thread Starter
any opinions? i wanna order something ASAP lol
post #11 of 16 (permalink) Old 01-20-2008, 08:58 PM
IMO, you're heading in the wrong direction by removing mufflers. If you wanted to decrease drone on the setup that you had, it would have made more sense to stick a pair of rear mufflers on the car (leaving the mid-mounted one in place) than to remove the only muffler that you had.
-Rod
post #12 of 16 (permalink) Old 01-20-2008, 09:04 PM Thread Starter
ahah yes i realize that now. i figured the muffler was causing all the resonance and drone because of the location. but now ill be going back to a more stock setup with mufflers out the back so it should fix the drone problem. as i remember correctly mine only came with 2 cats and a muffler out the back.
post #13 of 16 (permalink) Old 01-21-2008, 12:23 AM
jk69cat's Avatar
its a 3.8 it needs a resonator to not drone
mn12 less!
jk69cat is offline
post #14 of 16 (permalink) Old 01-21-2008, 06:47 AM Thread Starter
what the main differance between a resonator and a muffler, they look quite similar. also do you have any suggestions on resonators? are you saying 1 midmounted or 2 out the back?
post #15 of 16 (permalink) Old 01-26-2008, 06:46 AM
Dean,
RockAuto has them,
WALKER Part # 17679 {Dynomax}
LH; T-304 Stainless Steel Spout
$78.79
WALKER Part # 17680 {Dynomax}
RH; T-304 Stainless Steel Spout
$78.79
Check in the Miscellaneous forum, someone has a discount code for them.
post #16 of 16 (permalink) Old 01-27-2008, 10:08 PM
SplitPortBird's Avatar
screw the resonator,,, I dont have one and have no drone at all.
Ford did a trick with the stock 5.0 and almost most cars with a duel exhaust and thats not to use the same muffler on each side.
Use either a slightly longer or larger or smaller type muffler.. each will produce a different note at a different rpm and not cause the harmonics thats common when each side is exactly the same.
SplitPortBird is offline
