Exhaust manifold - TCCoA Forums
post #1 of 13 (permalink) Old 03-03-2008, 06:08 PM Thread Starter
Exhaust manifold
How do you take these off a 1994 Thunderbird to put on some shorty headers? Seems like there is no room to get to the bolts.
azzano15 is offline
post #2 of 13 (permalink) Old 03-03-2008, 06:11 PM
95xbird's Avatar
Engine hoist,or remove the lower crossmember.
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #3 of 13 (permalink) Old 03-03-2008, 09:52 PM
Moderator & Teksid Whore
guitar maestro's Avatar
guitar maestro is offline
post #4 of 13 (permalink) Old 04-02-2008, 01:20 PM
the shop had to plasma cut mine...pain in the ass to get too
joshdford is offline
post #5 of 13 (permalink) Old 04-02-2008, 03:19 PM
twin turbo 281's Avatar
it can be donw without lowering the frame or pulling the motor but you will have unbolt the motor mounts and raise the motor with a jack an inch to gain access to some of the bolts. My .02 waste of time for a header thats not much better than the stock manifolds.
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #6 of 13 (permalink) Old 07-24-2008, 12:21 AM
when i had to put the new set of npi heads in my 95 due to blown valve seals my stock manifolds were in pretty bad shape due to my grandfather living in maryland (rusted badly). the bolts just busted off with the air gun to get them off. I snagged a set of stock manifolds from a 99 mustang gt long tube swap for free and bought an off road H pipe for a 99+ gt.
I'm in the process of putting these true duals together right now. the manifolds bolted right up with no clearance issues. the H pipe seems to bolt up close. I do expect to do a little bit of fabrication. I haven't had much time to put it all together but when all is said and done i'm setting two 1 chamber flowmaster mufflers dumped near the axle. from the looks of everything ill have to change the h pipe hooks and weld them so they will fit into the stock location of the Y pipe. and if i dont bump out the floor panel int he back seat area i will probably lose a couple inches of ground clearance, but i live on paved flat country roads and i'll never lower the car. Upon measure I most likely will still have enough clearance to fit a coke can under.
once i get a chance to actually finish it ill try to snap some pics. should sound good too as i did this same set up on a 98 gt and it sounded wicked good.
blue95lx is offline
post #7 of 13 (permalink) Old 08-05-2008, 01:59 PM
JNT
JNT's Avatar
The Mustang manifold fit on your car ok? I didn't think the Mustang manifolds or headers would fit without modification.
1997 Thunderbird 4.6L LX (out of commission for now)
SCT XCAL 2 From Lonnie, 02 Mustang MAF and air box, Dynomax Cat Back Exhaust, Steeda U/D Pulleys, 70MM FRPP TB, Dual Piston Calipers, KVR Rotors, Alpine CD, Polk Speakers
1996 Thunderbird 4.6L LX Stock
1994 Thunderbird SC (Needs Work, for sale)
1996 Bronco XL - 2003 Escort ZX2 wrecked - 1996 Bronco XLT Sport
Project Car: 69 Lincoln Continental
JNT is offline
post #8 of 13 (permalink) Old 08-05-2008, 09:58 PM
Kooks or nothing.
post #9 of 13 (permalink) Old 08-05-2008, 11:50 PM
the manifolds bolt right in. passenger side is snug though. but no rubbing. I did have to lift the motor out of the car a few inches to get it all the way in.
i did figure out, which i wish i knew before, the off road H pipe for 99+ stangs will bolt almost directly up to the stock tbird manifolds. the drivers side bolts up. but to get the passenger side up you'll need a cutter and some welding. after that, you will lose some groudn clearnace to dump at rear as this set up will not follow the standard Tbird exhaust channel in the underbody. yet if you use the right kind of mufflers you can still fit a coke can under them to gauge clearance. a coke can will get you over most speed bumps and pot holes.
blue95lx is offline
post #10 of 13 (permalink) Old 08-06-2008, 12:22 AM
There are only 2 options that work on these cars. Kooks are by far superior to anything else. The JBA and SSA headers are worse than the OEM manifolds. Porting of the OEM manifolds will produce minor gains. The kooks will require a complete exhaust change.
Supercoupe Performance is the only supplier of the kooks for our cars.
http://www.supercoupeperformance.com
I highly suggest Braincoating for ported manifolds.
http://www.braincoating.com
Installation is easiest to do IMO by removing the subframe. Use some cahins and supports to hang the engine and drop the subframe out the bottom.
post #11 of 13 (permalink) Old 08-06-2008, 04:01 PM
or do it when you do a headswap like I'm doing Speaking of braincoating have you heard from preston lately alan? I haven't heard from him in a couple of weeks. getting closer to mods time
FunktasticLucky is offline
post #12 of 13 (permalink) Old 08-06-2008, 04:10 PM
95xbird's Avatar
Ya,Kooks or nothing.I put JBA's on my car years ago and felt no gains.Still need to get them bastards out of there.Maybe this winter I'll pick up some Kooks to complement some new mods the car is getting.
Its slow, Really.
LS1 KILLER
95xbird is offline
post #13 of 13 (permalink) Old 08-06-2008, 05:21 PM
Talked to him for all of 8 seconds today.
