What muffler to go with - TCCoA Forums
post #1 of 15 (permalink) Old 04-28-2008, 12:05 PM Thread Starter
greenmachine's Avatar
What is a decent sounding muffle for my 96 4.6 Tbird. I stock pipes. I want to get a muffler that will make the car sound better. I am looking for some growl but nothing real loud. Any idea's folks?
Tim
2005 Magnum 5.7 Hemi (93k)
1997 Jaguar XK8 CONV (80k)
1996 Tbird (120k, V8)
"The older I get the smarter I was"
greenmachine is offline
post #2 of 15 (permalink) Old 04-28-2008, 12:05 PM Thread Starter
I dont care about quality as I typically sell a car be4 a muffler would rust out.
Tim
post #3 of 15 (permalink) Old 04-28-2008, 01:23 PM
shaken, not stirred
stangboy7's Avatar
Well a "decent souding" muffler is purely opinionative. But if you want to listen to some clips with what mods people have done go here http://forums.tccoa.com/showthread.php?t=78905
Also the search button will help you out.
C.Hill
'97 Laser Red T-bird w/ Option 66S - 125,000 miles, stock except for 3.73s Best ET 15.6 @ 88.3
'94 Electric Red T-bird LX V-8- 212,000 miles- SOLD
2005 Ebony Black Excursion Limited 6.0 Diesel STUDDED
"Thinking is the hardest work there is, which is the probable reason so few engage in it."
- Henry Ford
"Opportunity is missed by most people because it is dressed in overalls and looks like work."
- Thomas A. Edison
http://www.tailofthedragon.com <---- A test of driving ability and nerves.
stangboy7 is offline
post #4 of 15 (permalink) Old 04-28-2008, 02:18 PM
bad93bird's Avatar
I have a Dynomax Bullet muffler. I took off the resonator and rear 2 mufflers. I had it welded on in place of the resonator. It sounds about the same as my buddies 99' Z28 with SLP exhaust. I like it better. It doesn't drone and can be heard inside the car. Not too loud. Just right!
QUADSQUAD MEMBER
bad93bird is offline
post #5 of 15 (permalink) Old 04-28-2008, 04:51 PM Thread Starter
My 96 with the 4.6 does not have a resonator, does it? ALl I see are the two cats up front, a 3rd at the Y and two mufflers at the rear. I was assuming those two in the back jsut get cut off and louder muffs get installed.
Tim
post #6 of 15 (permalink) Old 04-28-2008, 04:58 PM
MidnightSleeper's Avatar
I have magnaflow on my car and it's not that loud but has a good sound to it.
You might try just chopping off the stock muffs and see if you like it. Its a bit more ratty than a muffler but its cheap.
The Jersey Shore is a stereotype, we're not all morons.
MidnightSleeper is offline
post #7 of 15 (permalink) Old 04-28-2008, 05:13 PM
shaken, not stirred
stangboy7's Avatar
The 3rd at the Y is your resonator. And you need true duals instead of one pipe all the way untill it splits. That will give you the osund you need.
C.Hill
- Henry Ford
- Thomas A. Edison
post #8 of 15 (permalink) Old 04-28-2008, 05:19 PM Thread Starter
I was told (here) that that thing at the Y is a 3rd cat. It looks like one to me.
As for a true dual, well I aint Mr money bags, ha ha ha. Just trying to make the ride sound a little better with out putting big jack into it.
Tim
post #9 of 15 (permalink) Old 04-28-2008, 05:22 PM
rbrown's Avatar
Yeah it's a cat.
Just cut off the mufflers and put 2 dynomax on and be good to go.
91 Festiva 1.3L baby 5 speed
10 Flex Brick Twin Turbos
*Rodney*
rbrown is offline
post #10 of 15 (permalink) Old 04-28-2008, 05:22 PM
95xbird's Avatar
That is the Third cat.Normally there is a small looking muffler right after the third cat that would be the resonator.
Sounds like you do not have one.
I have true duals with Xpipe, high flow cats and Dynomax mufflers.It sounds really good but the Dynomax mufflers are too quiet for my taste,My father has a Mid mount Magnaflow with no cats on his 94 SVO car.It sounds insane.
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #11 of 15 (permalink) Old 04-28-2008, 05:24 PM Thread Starter
I will check again but I do not recall anything between that 3rd cat and the muffs.
Tim
post #12 of 15 (permalink) Old 04-28-2008, 05:50 PM
beano1ill's Avatar
It should be there. It is practically right behind the third cat and looks like a small muffler. If you flick it with your finger it will give off a nice ping.
No one could make a greater mistake than he who did nothing because he could do only a little.
beano1ill is offline
post #13 of 15 (permalink) Old 04-28-2008, 06:06 PM
jnk3846's Avatar
96/97 Didn't come with a resonator.
jnk3846 is offline
post #14 of 15 (permalink) Old 04-28-2008, 06:20 PM
shaken, not stirred
stangboy7's Avatar
My bad, i was picturing my full exhaust of my 94 in my garage. You are totally right.
C.Hill
- Henry Ford
- Thomas A. Edison
post #15 of 15 (permalink) Old 04-29-2008, 09:46 AM
bad93bird's Avatar
If you put a BULLET muffler on it is kinda loud. I think it will be exactly what you are looking for. FRom what you have written on here.
QUADSQUAD MEMBER
