Exhuast set up - TCCoA Forums
post #1 of 28 (permalink) Old 09-26-2008, 11:36 PM Thread Starter
justin case's Avatar
Exhuast set up
I'll be finally getting my exhaust done soon and I'd like some opinions. First off i know the restriction from cats is minuscule but since my car is a 95 and i don't have to worry about emissions anymore i figure ill go catless. I had just planned on getting a magnaflow di/do 2.5'' x pipe(the one alot of guys use here,where it just looks like a normal muffler,you dont actually see the x) and running 2.5'' pipe throughout and just dumping it after the diff (i like the way the car looks with no tailpipes) Now, is this going to most likely be obnoxious and raspy? i dont care much about it being too loud,in fact i prefer it, I just dont want it to be raspy and sound like ass.
either that or should i just do that same set-up but with 2 mufflers in the back?
any suggestions are welcome.
-Doug
95 T-bird, purple python,i'll drive it again.........someday.
http://www.facebook.com/home.php#/pr...73&ref=profile
justin case is offline
post #2 of 28 (permalink) Old 10-06-2008, 06:39 PM
trial and error, wouldn't hert to do the x pipe. if it sounds like ass, add mufflers in the rear.
40th Chicken is offline
post #3 of 28 (permalink) Old 10-06-2008, 06:47 PM
ChiTownTBird815's Avatar
wait....you dont have to use cats in illinois if your car is 95 or earlier?!?!
i didnt know this....
Matt W.
ChiTownTBird815 is offline
post #4 of 28 (permalink) Old 10-06-2008, 11:44 PM
Blade Runner's Avatar
http://forums.tccoa.com/showpost.php...1&postcount=32
Blade Runner is offline
post #5 of 28 (permalink) Old 10-06-2008, 11:49 PM
you have to use cats in any car that came with them, but will illinois check a 95 or ealier car anymore? no.
post #6 of 28 (permalink) Old 10-07-2008, 03:19 PM
wow i didnt know that....so when you get emissions testing they dont check for cats anymore?
Matt W.
post #7 of 28 (permalink) Old 10-07-2008, 04:49 PM
Links432's Avatar
I don't believe they test 95 and older anymore.
Nick
2015 Ford Fusion SE 2.0 EcoBoost
2006 Ford Five Hundred SEL- Traded In
1994 Ford Thunderbird- Sold
1994 Mercury Cougar- RIP
1981 Ford Granada- Pride and Joy-Looking for 81-82 Parts.
1957 Ford Ranchero- Parted Out
Links432 is offline
post #8 of 28 (permalink) Old 10-07-2008, 09:41 PM
I'm still far off from getting to the exhaust but heres the muff I have waiting in the wings
DI-DO 2.5" dynomax tru-x ultra flow. This is supposedly too quite for some people so no risk for drone or rasp.
post #9 of 28 (permalink) Old 10-07-2008, 10:24 PM
The cats are a huge restriction, but when you take them off you car will sound like do-do and lose a lot of torque which is what you need to get this car to move when you punch the throttle at the stop light. If you have a stock car and want to remove the cats then put the Flowmaster Resonator and cat back system on and you will see more torque and HP. The sound is great through the whole RPM range. The price is right and it is mandrel bent. Trying to cook up a home brew does not work well unless you have a ton of money. When you lose torque your foot is on the throttle to make up for it at the stop lights. That will cost you about 2 miles per gallon on average.
Hollywood Ed is offline
post #10 of 28 (permalink) Old 10-10-2008, 12:20 AM
Slowride's Avatar
Send a message via Yahoo to Slowride
I've thought about using the dual in and out X-muffler from dynomax....just courious as to how it sounds and performs. I'm personally running true dual 2.5"catless exhaust with and H-pipe and two Dynomax Ultra Flow mufflers in the stock locations...all for about $300 bucks. Couldn't be happier with the sound ...get all kinds of looks.
Of course, like stated earlier by Hollywood Ed, you'll loose alot of bottom end torque with out the cats, especially if you're running with a stock motor--even with bolt ons. And if you go to 2.5" pipes, catless, the drop in torque would be even greater. Now do a serious engine build or SC it, and you'll be able to get away with it better. I would say keep the cats but cut the Y section out and go duals from there with that muffler....it'll sound good and still have enough back pressure for the car to "go" when you want it to. Thats how I did my first exhaust..cut the Y out, ran 2 .25" pipes from there with an H-pipe back to my Flowmasters....until they went bad and then added my Ultra Flos.
The only thing I'll say NOT to do is get the Flowmaster cat back system. Yeah, Flowmasters have a great and unique sound...but the performance isn't as great as what people think. I DID have their system once...and the mufflers lasted about 2 years, then a baffle came loose and blocked the exit of the muffler, killing my HP...down to about 75 HP. And when the guy who developed the "J-Mod" for our trannys says they're junk....there's something to it. He was doing the first tune on my car when the baffle issue happened....he thought he broke my car at first. That was quite an experience.
Good luck with what ever you decide to do.
The early bird may get the worm, but the second mouse gets the cheese!!!
Slowride is offline
post #11 of 28 (permalink) Old 10-10-2008, 11:47 AM Thread Starter
Thanks for the responses guys. My engine is farrrrrr from a stock 95 (see sig )
i may just get the di/do magnaflow with the built in x (does anyone have a part number,my work is a "magnaflow dealer" but i couldnt find this muffler in the catalog) and see how it is,and if it is too raspy i may just put two high flow cats on because 1. go environment! haha and 2 im sure it'll cut down on the raspy-ness.
-Doug
post #12 of 28 (permalink) Old 10-14-2008, 09:50 PM
i have a thrush setup its not to bad really
97grnbird is offline
post #13 of 28 (permalink) Old 10-15-2008, 01:15 PM
twin turbo 281's Avatar
i think the dynomax would be better but thats just be i rather hear the blower
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #14 of 28 (permalink) Old 10-15-2008, 10:01 PM
SignofTheCat94's Avatar
Send a message via MSN to SignofTheCat94 Send a message via Yahoo to SignofTheCat94
Justin, I have the di/do magnaflow, but it's got 2.25 pipes from the front cats to the back. It's not raspy; in fact, it's quite mellow.
Mods? Do the ones in the garage waiting to go on the car count?
Many thanks to my fellow Veterans; I am honored to be a part of your ranks.
SignofTheCat94 is offline
post #15 of 28 (permalink) Old 10-16-2008, 10:10 PM
Listening on 141.850 mHz!
Gonzalo Duque's Avatar
I have the same setup as SignofTheCat94 and with 2 high-flow 94004 Magnaflow cats. It does sound mellow and not too droney. It doesn't have that Mustang growl though.
Two hi-flow Magnaflow 94004 cats going into a mid-mounted Magnaflow 11385 and then back out to "believe-it-or-not" NAPA chrome tips that are 2 1/8 inch diameter for $13 each! 2.25 pipes all the way through.
Click on the pics to make them larger:
Gonzalo Duque "Gonzo"
1997 Lincoln Mark VIII LSC 4.6L Cobra V8
1997 Thunderbird Limited Edition 4.6L V8 - gone.
Might be a 2005-2007 Jaguar XJ-8 L in my future.
Westland, Michigan - but I'm from central New Jersey!
http://www.hoodliners.net - My hoodliners I make!
Gonzalo Duque is offline
post #16 of 28 (permalink) Old 12-06-2008, 12:28 AM
Slowride's Avatar
Looks good, the metal gas tank plate looks alittle rough thought.
Slowride is offline
post #17 of 28 (permalink) Old 12-06-2008, 08:09 AM
Thanks Slowride - yeah that thing needs to be replaced!
post #18 of 28 (permalink) Old 12-10-2008, 12:38 AM
Slowride's Avatar
Those are hard to find un-corroded
Slowride is offline
post #19 of 28 (permalink) Old 12-10-2008, 08:10 AM
Great, just what I need now, a challenge to find one in "new" condition!
post #20 of 28 (permalink) Old 12-10-2008, 03:34 PM
Originally Posted by Slowride View Post
Those are hard to find in the midwest un-corroded
fixed that
post #21 of 28 (permalink) Old 12-11-2008, 10:28 AM
SuperNewbie
supergordo's Avatar
Not out west.
1995 Cougar XR7 4.6
1997 Thunderbird LX 4.6
1977 Country Squire 460
1985 Capri RS 5.0, 5spd
1997 Thunderbird 4.6
1984 Capri RS 5.0,5spd
supergordo is offline
post #22 of 28 (permalink) Old 12-11-2008, 10:49 AM
I am about to drop my gas tank.....and get rid of it....interested in the metal plate?
I can get pics if need be.
post #23 of 28 (permalink) Old 12-11-2008, 10:57 AM
Any consequences of not using it? If I need it I could use it, but right now I have no green paper with those dead guys on them - and won't for a while unless something changes.
post #24 of 28 (permalink) Old 12-11-2008, 12:32 PM
I'm sure it serves some purpose....maybe keep heat away from the tank.
The tank is plastic.
Just cover shipping and it is yours.
Give me a few days, and I can get you a quote....only if you want.
post #25 of 28 (permalink) Old 12-11-2008, 03:44 PM
i always guessed to protect the PLASTIC tank from rocks, road debris, ect
post #26 of 28 (permalink) Old 12-11-2008, 03:46 PM
Ya, I'm guessing the same. My main concern now are valve stem seals - got some blue smoke when I accelerate after idling. Oh well.
post #27 of 28 (permalink) Old 12-11-2008, 03:49 PM
if it ain't one thing, its a mother fu........you get the rest
post #28 of 28 (permalink) Old 12-11-2008, 03:57 PM
And that just started!
