what longtube - TCCoA Forums
post #1 of 4 (permalink) Old 12-21-2008, 11:16 AM Thread Starter
what longtube
i am putting a 5.0 in my 89 cougar with a 5 spd m5r2
what is the best lomgtube that i can use with the least amount of modding required?
thanks guys
mike
1990 ford f150 5.0
1989 cougar xr-7 5spd 5.0 --249hp/[email protected]
1989 mustang gt [email protected]
1984 tbird 5.0 auto
1999 chevy tracker...wtf!!!!!
joker77_2005 is offline
post #2 of 4 (permalink) Old 12-24-2008, 10:46 AM
There are no LTs that don't require modding. There is a really good thread detailing the Mac Long tubes installation.
http://forums.tccoa.com/showthread.php?t=75182
cougar9150 is offline
post #3 of 4 (permalink) Old 12-24-2008, 12:01 PM
Those MAC's are the best bet for the least amount of modding required. You can either raise the motor a bit, or take the stock steering shaft and cut out the section that goes through the header and weld a thinner shaft back in its place, and then everything will clear and you will keep the collapsible steering shaft. Your other option is to do the steering mod where you add another U-joint and a support bearing, and have the steering shaft go around the headers instead of through them.
Also, one minor thing to note, if you are putting this in an 89, you have to get the positive battery cable and starter for a 91-93. The headers don't clear the larger old style starter, and the newer style has the solenoid built into it instead of on the firewall so the cable is different.
post #4 of 4 (permalink) Old 12-24-2008, 02:54 PM Thread Starter
cool,thanks for the input guys.i knew that the macs were the way to go ,i was just wondering if anybody else had a tried and true lt that work,looks like i am going with the macs
mike
1990 ford f150 5.0
1984 tbird 5.0 auto
