NASTY rumble after changng cats - TCCoA Forums
post #1 of 5 (permalink) Old 02-19-2009, 01:17 PM Thread Starter
Okay, my cats went about a month ago so i swapped them out with Magnaflow high flow cats. Unfortunately the direct fit were not so direct fit and i needed to weld thread from my old pipes onto the new ones for the downstream O2 sensor on the drivers side. Not a big deal. Sealed up the thread with a bolt that i got with the new cats and welded a seal. After i put the cats on i was getting a much deeper sound when i started up and drove but NOW i have a nasty rumble!! Whats weird is that it only happens when i turn the wheel. WTF?? Any ideas??
FatCat96 is offline
post #2 of 5 (permalink) Old 02-19-2009, 02:05 PM
loose exhaust hanger?
post #3 of 5 (permalink) Old 02-19-2009, 05:03 PM
RCReevesPhotography's Avatar
I had a nasty rattle on my 89. It started after I had a new muffler installed and after all kinds of WTF's it turned out to be the heat shield for the pipe.
RCReevesPhotography is offline
post #4 of 5 (permalink) Old 02-19-2009, 06:30 PM
SuperNewbie
supergordo's Avatar
Only happens when you turn the wheel? Well check and see if the exhaust is rubbing on anything.
Also though it may be unrelated you may want to check the ball joints, If they make noise when you turn it could be a whole other problem.
1995 Cougar XR7 4.6
1997 Thunderbird LX 4.6
1977 Country Squire 460
1985 Capri RS 5.0, 5spd
1997 Thunderbird 4.6
1984 Capri RS 5.0,5spd
supergordo is offline
post #5 of 5 (permalink) Old 02-20-2009, 05:25 PM Thread Starter
Yeah thats what im thinking. I checkd and they dont rub on anything.. its like one problem after another...
FatCat96 is offline
