Improve flow w/o increasing noise... - TCCoA Forums
post #1 of 7 (permalink) Old 04-02-2009, 01:29 PM Thread Starter
The_Ghost's Avatar
Ok, forgive the n00b thread on this but I'm kinda sensitive about noise.
The last car I had was all flowmaster'd out and the noise was really annoying-- but the REAL problem was all the unnecessary attention it drew to the car.
I want to improve flow but I'm not sure how much is there to be gleaned off of a stock 4.6L NPI engine or if it's even a restriction.
What would be the best option for keeping noise down while improving flow? The closer to stock Db levels the better...
Should I just have the piping replaced with bigger diameter pipes and leave the stock things in place? Should I remove the resonator chamber thing in the middle?
Your input is really helpful.
I've been ticket free for several years and I'd like to keep it that way, and having quiet mufflers helps me skirt around under the public eye... With this particular car I try very hard to keep up a stock appearance externally.
Best,
Ghost
96 Laser Red 4.6L - Custom
Custom Nascar-Inspired Bodykit - 55* Rear Spoiler - J-modded Trans - 80mm MAF - One-Off Diablosport Chipmaster Revolution Chip/Tune W/Toggle - ScanGaugeII Diagnostics & Data Readout - PBR Brakes - Drilled/Slotted Rotors - SC Wheels & Springs - Falken Tires - KYB GR-1 Shocks/Struts - FSTB - RSTB - RTLB - LECB - 60/40 Split Rear - SC Seats - SC Vac/Boost Gauge
The_Ghost is offline
post #2 of 7 (permalink) Old 04-02-2009, 05:21 PM
shaken, not stirred
stangboy7's Avatar
You may try putting an X pipe or a magnaflow in place of the resonator, and then run true duals out the back to the stock mufflers (if you still have em) because stock is really pretty quiet. But you would still get good flow with the X and true duals ans quietness with stock muffs. just a thought.
C.Hill
'97 Laser Red T-bird w/ Option 66S - 125,000 miles, stock except for 3.73s Best ET 15.6 @ 88.3
'94 Electric Red T-bird LX V-8- 212,000 miles- SOLD
2005 Ebony Black Excursion Limited 6.0 Diesel STUDDED
"Thinking is the hardest work there is, which is the probable reason so few engage in it."
- Henry Ford
"Opportunity is missed by most people because it is dressed in overalls and looks like work."
- Thomas A. Edison
http://www.tailofthedragon.com <---- A test of driving ability and nerves.
stangboy7 is offline
post #3 of 7 (permalink) Old 04-02-2009, 06:33 PM
I had a cat back I had done that was easily as quiet as stock.
Dual in and out 2.5" Magnaflow muffler replacing the third cat setup. Into an X pipe.
Then Dynomax superturbos at the back with Magnaflow 2 1/4" resonator tips.
Its breathed easier for sure but was like stock sounding.
All totalled it cost $600 to do.
Don't use the stock mufflers, they are so restrictive its crazy.
RichardM is offline
post #4 of 7 (permalink) Old 04-02-2009, 06:41 PM
bowez's Avatar
Borla.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #5 of 7 (permalink) Old 04-02-2009, 08:24 PM
Buckcreekbilly's Avatar
Mine is pretty much stock and for duals, i went with stock cats up front, 2 1/4" pipes, took out third cat and resonator into stock mufflers at rear. Not bad and i'm sure that removes more than enough restriction on a fairly stock 4.6 and still is fairly peaceful.
95 Thunderbird LX 4.6
K&N cold air intake. True 2 1/4" duals, Xenon GFX. 3:55 Trac loc. Beefier trans, 2800 stall convertor, MkV111 aluminum driveshaft.
Buckcreekbilly is offline
post #6 of 7 (permalink) Old 04-02-2009, 09:01 PM Thread Starter
The_Ghost's Avatar
C.Hill
x pipe it is with duals.
Best,
Ghost
post #7 of 7 (permalink) Old 04-05-2009, 08:51 PM
I was running true duals with a magnaflow mid mount muffler and dynamax mufflers out back last time I visited u nick. I have since ditched the rear mufflers to increase sound. If you liked how they sounded we could arrange a deal.
