97 LX Exhaust Question - TCCoA Forums
post #1 of 8 (permalink) Old 04-12-2009, 12:35 AM Thread Starter
I have a stock 97 LX and planning to get it to breathe better. I'm planning on getting the Mandrel Bent Tubing Kit, but for the X-pipe...should I go with the Magnaflow Tru-X pipe found here >http://www.autoanything.com/exhausts...A2672A0A0.aspx
and will that fit with the Tubing Kit? Or should I assume the shop will have to custom weld the X pipe to the pipes themselves?
If there are any suggestions I'd greatly appreciate them,
Andrei
GagiuThunder27 is offline
post #2 of 8 (permalink) Old 04-16-2009, 01:03 PM Thread Starter
bump, sorry if it's a boring/dumb question but i AM a newbie and wanting to learn more
post #3 of 8 (permalink) Old 04-16-2009, 01:32 PM
Buckcreekbilly's Avatar
Probably better flowing and may sound a bit better than the mandrel bent one. As far as being a direct fit to the mandrel pipes, i doubt it, the exhaust shop will have to make everything come together. Just make sure you order the same size inlet/outlet openings as the pipes your getting.
95 Thunderbird LX 4.6
K&N cold air intake. True 2 1/4" duals, Xenon GFX. 3:55 Trac loc. Beefier trans, 2800 stall convertor, MkV111 aluminum driveshaft.
Buckcreekbilly is offline
post #4 of 8 (permalink) Old 04-19-2009, 11:36 PM Thread Starter
okay cool, so make sure that all inlets/outlets are the same size? (2.5in.)
post #5 of 8 (permalink) Old 04-19-2009, 11:45 PM
Traveler's Avatar
Just a thought... but the Magnaflow dual in/dual out muffler has an X-pipe built into it, it flows well, sounds good, and eliminates the need for two mufflers at the rear. You might look into that instead of the X-pipe itself.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #6 of 8 (permalink) Old 04-20-2009, 04:12 PM
thunderchikin97's Avatar
Send a message via AIM to thunderchikin97
OR, the di/do Flowmaster which i can say from experience...sounds amazing! That's my opinion of course.
thunderchikin97 is offline
post #7 of 8 (permalink) Old 04-20-2009, 04:25 PM
13's or Mildly Broken
I've had both Magnaflow and Flowmaster - if you want some sound, Magnaflow is the way to go. It sounded great cruising around town and at idle, but quiet at highway speeds. The flowmaster is much more noticeable, but not overbearing either. It's got a little bit of drone, but very tolerable.
Both setups were true dual 2.5" pipe. The difference - Magnaflow was midmount with no mufflers in the rear... Flowmaster has an X pipe and mufflers at the rear.
-Melon
1999 Crown Victoria P71 4.6
2000 Explorer 5.0
Melon is offline
post #8 of 8 (permalink) Old 04-22-2009, 02:52 PM
Listening on 141.850 mHz!
Gonzalo Duque's Avatar
<< Just a thought... but the Magnaflow dual in/dual out muffler has an X-pipe built into it, it flows well, sounds good, and eliminates the need for two mufflers at the rear. You might look into that instead of the X-pipe itself. >>
I have this same setup on my Limited Edition. Sounds great and flows well. Two hi-flow Magnaflow 94004 cats going into a mid-mounted Magnaflow 11385 and then back out to "believe-it-or-not" NAPA chrome tips that are 2 1/8 inch diameter for $13 each! 2.25 pipes all the way through. An exhaust shop will supply the pipes and bending.
Click on the pics to make them larger:
Gonzalo Duque "Gonzo"
1997 Lincoln Mark VIII LSC 4.6L Cobra V8
1997 Thunderbird Limited Edition 4.6L V8 - gone.
Might be a 2005-2007 Jaguar XJ-8 L in my future.
Westland, Michigan - but I'm from central New Jersey!
http://www.hoodliners.net - My hoodliners I make!
Gonzalo Duque is offline
