Cheap Exhaust - TCCoA Forums
post #1 of 35 (permalink) Old 06-20-2009, 05:21 PM Thread Starter
sdavis872's Avatar
Cheap Exhaust
I'm looking into throwing together a cheap exhaust set up and I have a few questions.
What would be the difference in a mid mount exhaust and a rear mount exhaust if I have the exhaust dump in the same spot (stock location, but probably dual exit using a 1 into 2 muffler)?
With a 3.8 NA unmodified MN12 is there any need to change to a bigger than stock exhaust? Would the different be noticeable?
How much would it cost to have a muffler shop cut out the old cats and put high flow cats in that are slightly further along in the exhaust so that 90 degree bend can be smoothed out a bit (I figure that is where most of the restriction is). And how much should I expect a scrap metal place the pay for the cats (since they contain platinum or what ever)
What would be a good muffler for a set up like this. I think the biggest mod I might do is underdrive pulley's, but that probably it.
EDIT:
If I bought a Thrush Turbo, what would be the best configuration? These are what I thought about.
1) in place of the resonator and just had it dump there, maybe side exhaust it later
2)in place of the stock one, but then I don't know what to do about the resonator.
At Advance they only have a single in single out, but I'd like to do dual exhaust, especially if I go with the side exhaust. Thoughts?
sdavis872 is offline
post #2 of 35 (permalink) Old 06-21-2009, 07:59 PM
Well... Maybe it's easier for you to find a show to install high flow cats but I had the hardest time finding a shop to even take off the 3rd cat and run true duals.
I would recommend finding some already made downtubes with high flow cats. They will be mandrel bent and then you can have an exhaust shop fab up the rest of the exhaust all the way back. I just don't see a purpose of making some pinch bent down tubes and throwing high flow's on... Granted a Unmodified 3.8 doesn't flow as much as a 4.6 but... I like to only do things once if I can. Which means I think about where I wanna go with the car in the future and plan accordingly. So it may be overkill for the time being but it will suit the future mods.
As for mufflers, I suggest just youtubing 3.8L Tbird exhausts or something to see what mufflers you like and don't like. Or listening to the sound clips here.
FunktasticLucky is offline
post #3 of 35 (permalink) Old 06-22-2009, 08:45 PM
hotrodseanxx's Avatar
Send a message via AIM to hotrodseanxx
as for the old cats and how much they go for at scrap yards... if they're the oem stock cats then they should be about $80 a piece... when i was working at a shop in nj thats how much we would get for them. If they aren't the original ones then they are not worth as much.
-Sean
1993 3.8 LX
cold air intake
Rebuilt AOD w/ Transgo shift kit
8.8 T-Lok w/ 4.10s
custom gauge set/custom dash
hotrodseanxx is offline
post #4 of 35 (permalink) Old 06-22-2009, 11:15 PM
ZackG's Avatar
mid mounts tend to have less drone also.
97 Tbird 4.6
Vortech at XY psi
4.10's, KB boost a spark.
Yummy.
ZackG is offline
post #5 of 35 (permalink) Old 06-23-2009, 11:19 PM
Tbird1997's Avatar
with my 3.8 bird i cut the muffler and resonator then Y piped it like the stock v8 birds and i loved the sound of that. theres a kid on youtube that did that to his red Tbird if you want to see how it sounds.
-Patrick
Tbird1997 is offline
post #6 of 35 (permalink) Old 06-24-2009, 07:15 PM
CDW6212R's Avatar
You can gain quite a bit if you reprogram the PCM, which means a flasher. Those are not cheap, but they do help a bunch. They do as much as any of the other little things, they actually make the most of the other stuff. So if the budget permits, plan for a tuner and programming after the other stuff.
In that case a larger exhaust is better than a mild exhaust. You read all the time about the "best" size of (name a part) in the exhaust. All of that is crap if the combinations are really tuned, PCM programmed for the exhaust. The programming needs to change for big changes, and the exhaust is a huge restriction for all vehicles. If you don't do programming, than don't buy nice big exhaust parts, the PCM can't take advantage of them. If you do the programming, always selec the largest exhaust that will physically fit. The headers need to be sized for the engine, sized/tuned for the flow of the heads. That sizing matters, but after headers, it's all restriction. All restrictions past the headers cost power, at all rpm's. That is why straight pipes always make more power, when tuned. Regards,
_________
Don
91 Mark VII LSC SE, Griggs and MM suspension soon
98 Mountaineer, A4WD, Big brakes - 12.75" x 1.25" rotors
CDW6212R is offline
post #7 of 35 (permalink) Old 06-25-2009, 07:55 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
To make your exhaust cheaper, I would just stay with stock cats unless they are bad/clogged. You wont notice any performance gains from removing them/replacing them with something that flows just as good. Older GM converters (the big round ones) are supposed to flow less than current Magnaflow (carsound) replacements, but our stock ones are the same style as Magnaflow. I would cut it off behind the stock cats and go to town with a 2 in 2out magnaflow (with x core) midmount, or whatever you like. Glasspacks are even cheaper. I think with an X-pipe glass packs at the rear would sound decent, but it's hard to work with the sound of 4 & 6 cylinder cars. I had mid-mount flowmaster 40 with pipes out the rear on my 3.8 cougar, and it sounded ok for a 6 cylinder. If I could go back, I would have tried my current magnaflow tru x muffler on the 6 cyl.
-Rob
-Rob
Rob is offline
post #8 of 35 (permalink) Old 06-25-2009, 09:56 PM
SignofTheCat94's Avatar
Send a message via MSN to SignofTheCat94 Send a message via Yahoo to SignofTheCat94
It all depends on what is cheap for you. If you can, cut the stock off after the factory cats. Summit sells "header extenders" that have the s-bends for about $35 a pair. Add a set of 3 bolt flanges for headers (Summit again, for under $20 and they go all the way down to 2.25" pipe, iirc). Use an X core mid mount muffler (about $100 at Summit) and add a set of mandrelbentexhaust.com's intermediate pipes ($150 shipped). All that's left is to run some 22 to 24" strait pipes/tips/whatever and a couple of hangers. It's actually pretty easy to set up; my current set up is very similar to this but with a true X pipe and dual chambered mufflers. I haven't had time to weld it all up and add tips yet, but it sounds nice, if a bit droney. If I were doing it all over again, I'd just use a Magnaflow X core DIDO muffler and spare the hassle of the X pipe. I can't promise it, but if you're interested in a complete "cat back", I'll probably have mine off to weld this weekend. I can take some pictures and do a quick shade tree "how to" write up. My components, including stainless steel tips, ran around $320 for a true dual 2.5" mandrel bent system.
Mods? Do the ones in the garage waiting to go on the car count?
Many thanks to my fellow Veterans; I am honored to be a part of your ranks.
SignofTheCat94 is offline
post #9 of 35 (permalink) Old 06-26-2009, 01:33 AM
those prices are for the aluminized pipe though right? I don't wanna change out my exhaust or fix holes.. I'm going with the stainless exhaust.
post #10 of 35 (permalink) Old 06-27-2009, 11:18 PM
That is all aluminized pipe, etc. I thought about going stainless, but the cat sleeps in the garage and doesn't play in the snow anymore. After weld up, I'm going to use hi temp paint on everything. I've killed a chunk of my budget with home improvement and working on a (let the razzing begin) Chevy minivan. I am saving the rest for the new paint job....
post #11 of 35 (permalink) Old 06-28-2009, 08:14 PM Thread Starter
sdavis872's Avatar
Could I yank the resonator and muffler, and replace the resonator with a glass pack? It's a 2" pipe right? 18" long? Is it straight or is there an offset?
post #12 of 35 (permalink) Old 06-29-2009, 12:16 AM
Personally I don't like the sound of Glass packs on these cars... But that's just me. I still think Borla's are the best way to go. But that's my opinion. I'd go do a little searching. Maybe goto youtube and check it out different exhausts. You could also try Streetfire. Especially with a 3.8L and not a 4.6L. And no you're car isn't going to sound like a Stang. Just FYI.
post #13 of 35 (permalink) Old 06-29-2009, 09:43 AM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
i once got a $20 glasspack of summit, had it mid-mounted and ran single pipe split to duals at the pumpkin. no rear muffler. it sounded ok. then i replaced the glasspack with a spintech sportsman muffler. they are not cheap, btw. sounds much better. its been mistaken for a v8 many times. i even fooled some of my gearhead buddies into thinking its a v8.
2014 GT
1990 300ZX TT
big mike is offline
post #14 of 35 (permalink) Old 06-29-2009, 11:12 AM
I think this post belongs in this thread as well...
Originally Posted by Stryker View Post
Cheap power? let me know when you find it. everything costs money and you will not have a GOOD sounding exhaust for cheap(unless you know someone to cut you a deal). cheap exhaust is cheap sounding....and it makes your car look cheap. enjoy the drone.
If I had a V6 and a limited budget here's what I'd do.
http://forums.tccoa.com/showthread.php?t=120195
post #15 of 35 (permalink) Old 06-29-2009, 01:56 PM Thread Starter
sdavis872's Avatar
I want to leave all cats in place, though Nebraska doesn't check, I'd just rather not worry about it. What if I replaced the resonator with a glass pack, then replace the stock muffler with a Borla or Magnaflow? I want something that will be "quiet" when just cruising along, but will get loud when reved up (4,000 rpm +).
I have looked at that before, but like I said, I want to leave all cats in place and don't like that dual tip thing. Also, would I need to upgrade to 2 1/4" pipe, all I have is a V6 and I don't think it's making enough power to need the bigger pipe.
post #16 of 35 (permalink) Old 06-29-2009, 08:04 PM Thread Starter
sdavis872's Avatar
Any thoughts on the above idea? Glasspack to replace resonator then maybe a Super 44 in the back? How loud do you think that would be? I want something that will be quite under 3,000 rpm, but will by 4,000 will be pretty screaming, or growling I guess. Something deep sounding, at least for a V6. If I wanted to go 2 1/4 from the cats into a 2 1/2 then split again into a 2 1/4 or just 2, would I have to take the 3rd cat out?
post #17 of 35 (permalink) Old 06-29-2009, 09:04 PM
CDW6212R's Avatar
I have a 4.0 V6 that I finally changed exhaust on last year. I kept a resonator(2.5") instead of a tiny muffler, a resonator quiets more than the small straight through mufflers you are looking at. My exhaust was OEM two 2.25" pipes into one muffler, and out to a resonator and 2.25" tail pipe.
I wanted to try an Edelbrock SDT chamber muffler, hoping for a quieter muffler. The only choice for 2.25" dual in has a 3" outlet, so I ran that to a 2.5" resonator and 2.5" bent tail pipe.It works well and is as quiet as most any aftermarket muffler, but still louder than stock.
Go with the biggest pipes that will fit, if the cost is basically the same. The mufflers all take up the same space, but the pipes can be made bigger usually for the same cost. If I knew that I would retune my truck sooner, I might have done more, forward and bigger. I was replacing a rusted and noisy muffler.
_________
Don
CDW6212R is offline
post #18 of 35 (permalink) Old 06-30-2009, 01:30 PM Thread Starter
sdavis872's Avatar
If I could get mine to sound like this I'd be satisfied
post #19 of 35 (permalink) Old 06-30-2009, 01:35 PM
Gl@re's Avatar
when i put my flow master on mine i noticed a big improvement in acceleration i think there might have been something wrong with the stock muffler though
14.8 @ 95
post #20 of 35 (permalink) Old 06-30-2009, 01:35 PM
Tbird1997's Avatar
thats the vid i was talkin about (the first one). pretty easy to do, all he did was straight pipe it but leave the cats alone, and dualed it like the stock v8 exhaust. then hes got some minor mods like tune, cai, and underdrive pulleys
-Patrick
post #21 of 35 (permalink) Old 06-30-2009, 01:46 PM Thread Starter
sdavis872's Avatar
That wasn't very exciting. Take another video and actually rev it up some.
post #22 of 35 (permalink) Old 06-30-2009, 01:50 PM Thread Starter
sdavis872's Avatar
What I'm thinking of now is just a straight pipe to replace the resonator then a SI/DO muffler instead of a Y-Pipe so I can make it a dual exhaust. What mufflers sound good on V6 Thunderbird? I want something deep, as close to a V8 sound as I can get. I know it will never sound the same but as close as possible. Something that will really open up when the engine is rev'd, but will stay quite while at idle and just driving around.
post #23 of 35 (permalink) Old 06-30-2009, 02:06 PM
Motorboatin' SOB
big mike's Avatar
deepest i have heard. it's kind of like a quiet diesel.
2014 GT
1990 300ZX TT
big mike is offline
post #24 of 35 (permalink) Old 06-30-2009, 04:51 PM Thread Starter
sdavis872's Avatar
What is the deepest you've heard?
post #25 of 35 (permalink) Old 06-30-2009, 05:17 PM Thread Starter
sdavis872's Avatar
If I cut out the 3rd cat and replaced it with a DI/SO Muffler, and then placed a 3rd high flow cat after that, would that make everything legal? After that I'd maybe add a SI/DO Muffler so I can have dual exhaust, unless it sounds good with just the one then maybe I'll just Y-Pipe it.
post #26 of 35 (permalink) Old 06-30-2009, 08:37 PM
CDW6212R's Avatar
For a V8 sound you should avoid removing stuff that makes the exhaust quieter, or makes it louder.
As you go to a smaller muffler or a louder muffler, it is far harder to get a V8 or deep low sound. So avoid the tiny mufflers or straight through mufflers, and keep as much of the cat/resonator stuff that you can. Make it bigger, that's fine, make the pipes bigger, but try not to let the total sound get too loud. As more of the sound does get through, the smaller engine V6 high pitched character is more obvious.
_________
Don
CDW6212R is offline
post #27 of 35 (permalink) Old 07-01-2009, 05:46 AM Thread Starter
sdavis872's Avatar
Huh. I want it louder than it is now, thats for sure. And I'd like it to be some what loud. What is the best muffler for getting a low deep sound?
post #28 of 35 (permalink) Old 07-01-2009, 08:11 AM
Motorboatin' SOB
big mike's Avatar
that video that i posted.
2014 GT
1990 300ZX TT
big mike is offline
post #29 of 35 (permalink) Old 07-01-2009, 04:18 PM Thread Starter
sdavis872's Avatar
People need to rev it up more in their videos. Personally, I like the one I posted better than the SC, maybe if the SC actually rev'd the engine instead of just tapping the pedal I would like it more.
But my question remains:
And another is:
What are the usual characteristics of the sound of a glasspack? Specifically on my application.
post #30 of 35 (permalink) Old 07-01-2009, 08:20 PM
A glass pack on 6 might sound a bit off. You could try a some sort of turbo muffler; I've heard them on Chevy 3.8's and they sound deeper than stock. The one I heard was a thrush turbo (the $30 one) on a later model monte carlo. It didn't sound bad; moderately loud, but not annoying and most importantly not farty. You get into a decent Dynomax/Thrush fairly cheap, but I'd advise painting anything not stainless steel.
