Anyone running this system? - TCCoA Forums
post #1 of 14 (permalink) Old 07-22-2009, 11:53 AM Thread Starter
Briglad's Avatar
Found this Dynomax system on Jeggs... Any opinions?
http://www.jegs.com/i/Dynomax/289/17379/10002/-1
Also as a cheaper alternative, I just want to increase the rumble and tone, not necessarily make the car significantly louder. Anyone replace the rear mufflers with something like glass packs?
Brian
Current Ride: 97 Bird LX 4.6 Lawn ornament / Past Rides: 94 Bird LX 4.6 / 94 SHO / 86 bird 3.8 / 77 Ranchero GT 400M / Also many, many Rangers, a Tempo, a Sable and a pair of Windstars.
Briglad is offline
post #2 of 14 (permalink) Old 07-22-2009, 04:16 PM
I've had it on mine for years now, no complaints. I think a few people have swapped mufflers for something a bit louder. If you want loud, this system isn't it.
post #3 of 14 (permalink) Old 07-22-2009, 04:55 PM Thread Starter
Briglad's Avatar
I don't want loud.... Just a little rumble.
Brian
Briglad is offline
post #4 of 14 (permalink) Old 07-22-2009, 07:35 PM
the system sounds ALRIGHT at WOT. But it's pretty much stock when cruising and idle. And it's extremely quiet.
FunktasticLucky is offline
post #5 of 14 (permalink) Old 07-22-2009, 10:32 PM
i'm pretty happy with it. It is not loud at all, but a decent rumble.
Keith88lx is offline
post #6 of 14 (permalink) Old 07-26-2009, 12:40 AM
terraplane8's Avatar
It seems to get a little louder over time. I've used it twice. Took 5 years (with no snow/ice/salt) to rot a muffler out, Flowmaster kit took about as long, too.
Dynomax fits almost perfect, but you may need to trim a little of the right rear pipe section to keep the mufflers/tips from contacting the body. Easy fix with a sawzall and good blade. Had to do that both times.
Submariners do it deeper...
terraplane8 is offline
post #7 of 14 (permalink) Old 07-26-2009, 08:11 AM
X2 I have the same muffers and its a bit loader now that I have the true duals
And the muffers tuck up under the bumper very nice
post #8 of 14 (permalink) Old 07-26-2009, 09:25 AM
Traveler's Avatar
I've got a true dual system with a mid mounted Magnaflow. It sounded great till I had the other two cats taken off, then it got kinda loud. So recently I had a good exhaust man install a couple of 18" glasspacks at the very back, with SS tips. The glasspacks quieted it back down again, nice rumble but not farm truck loud. The neighbors appreciate it I'm sure.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #9 of 14 (permalink) Old 07-26-2009, 12:54 PM
I've been checking out year exhaust lately and have been thinking about doing the same thing. Do you have any sound clips?
post #10 of 14 (permalink) Old 07-26-2009, 08:04 PM
9730thwhtcat's Avatar
Send a message via AIM to 9730thwhtcat
Hey Joe..you have this system? I looked at this system also,I'm still researching for my set-up... How it compared to the stock 4.6?.....oh wait isn't your car a V6?
if your car has the 4.6 can I come by sometime and listen to it to compare?
Jason
9730thwhtcat is offline
post #11 of 14 (permalink) Old 07-26-2009, 09:24 PM
It's a slight rumble over stock at idle, you know it's different. You really don't notice much until you punch it. Yup, V6 but I'll try to help! Meet you at the Bubbling Brook some Sunday!
post #12 of 14 (permalink) Old 07-28-2009, 10:23 AM
post #13 of 14 (permalink) Old 07-28-2009, 02:47 PM
thanks! Yea, that definitly sounds good.
post #14 of 14 (permalink) Old 07-28-2009, 03:08 PM
Thank you Keith Also there is know dome noise with my system RobertP a MN-12 Guru believes its because of the 2.5 inch opening at the tips
