tune needed for gutted cats? - TCCoA Forums
post #1 of 20 (permalink) Old 08-01-2009, 12:56 PM Thread Starter
Gl@re's Avatar
my buddy is having someone gut his stock cats on his car. That will make his check engine light come on right? does he need a tune to turn something off? The car is registered and insured in ohio so he doesn't have to worry about an emissions test, but turning the check engine light off would probably be good.
post #2 of 20 (permalink) Old 08-01-2009, 01:49 PM
bob9646's Avatar
The rear O2s will need to be turned off if that's what you're wondering, I've heard of mil eliminators in mm&ff but I don't know of anyone that uses them.
From what I understand gutting the cats isn't particularily helpful performance-wise
Shipping out to basic training for the army on april 12th!
Bird is on serious down time
bob9646 is offline
post #3 of 20 (permalink) Old 08-01-2009, 09:49 PM Thread Starter
Gl@re's Avatar
well the other optoin for improving flow would be high flow cats but he doesn't really have the money for that.
post #4 of 20 (permalink) Old 08-01-2009, 09:58 PM
I'm not positive, but don't believe MIL eliminators (o2 sensor simulators) can be purchased new anymore. There was an article somewhere detailing the construction of them using a couple dollars worth of Radio Shack parts however.
coolhandzep is offline
post #5 of 20 (permalink) Old 08-02-2009, 09:18 AM Thread Starter
Gl@re's Avatar
i found instructions for constructing Ford MIL eliminators, but his car is a pontiac (sorry should have mentioned that) would they be different? i think it might be best for him to just get a high flow cat instead.
post #6 of 20 (permalink) Old 08-02-2009, 12:33 PM
bob9646's Avatar
There are front and back O2 sensors on that car then right?
o2 sensors are o2 sensors from what I understand, the ohms *should* be the same
High flowing cats are always your best bet. But the $$$
bob9646 is offline
post #7 of 20 (permalink) Old 08-02-2009, 05:28 PM
Stryker's Avatar
why not remove the sensors, have the cats gutted and put them back in???? I honestlt do not think it is worth the trouble and your exhaust is gonna smell and it's really bad for the environment with very little to gain. It's your buddy's choice but i would save my money for high flows instead.
Mods: The usual stuff... 3.73 Gears, J-mod, catless mandrel 2.5" true duals, Marauder Converter, Eibachs, Xcal2 and Phoenix Gold Audio, chrome 18's, etc. etc..
I joined the dark side...
2002 Mustang GT, FRPP Aluminator with Tork Tech MP112 intercooled S/C at 17PSI, with all the supporting mods.
Stryker is offline
post #8 of 20 (permalink) Old 08-02-2009, 06:39 PM
bob9646's Avatar
Originally Posted by Stryker View Post
why not remove the sensors, have the cats gutted and put them back in???? .
That will throw a bad cat code
bob9646 is offline
post #9 of 20 (permalink) Old 08-02-2009, 06:43 PM
bob9646's Avatar
Hey, if this guy wants an extra 1/2 hp at redline who cares about nature?
bob9646 is offline
post #10 of 20 (permalink) Old 08-02-2009, 07:24 PM Thread Starter
Gl@re's Avatar
isn't your system catless?
post #11 of 20 (permalink) Old 08-02-2009, 07:27 PM
CDW6212R's Avatar
There is a company which makes pipes that look like cats. They are a straight pipe with heat shields around it.
_________
Don
91 Mark VII LSC SE, Griggs and MM suspension soon
98 Mountaineer, A4WD, Big brakes - 12.75" x 1.25" rotors
CDW6212R is offline
post #12 of 20 (permalink) Old 08-02-2009, 11:32 PM
Is your friend's Pontiac a 4 or 6 cylinder? If so I would forget about removing the cats. It will sound like garbage for nothing in return. I'm not saying v8s gain anything from going catless, they just have a chance of not sounding terrible sans converters.
post #13 of 20 (permalink) Old 08-03-2009, 01:42 PM
MIL eliminators delay the o2 signal, and make it smaller, so it looks like a rear o2 signal.
Search, you can find the diagram; Summit used to sell them.
Google looks promising:
http://www.google.com/search?hl=en&s...&aq=f&oq=&aqi=
post #14 of 20 (permalink) Old 08-03-2009, 03:29 PM
Clueless Poster
v8_superbirdy's Avatar
Send a message via AIM to v8_superbirdy Send a message via Yahoo to v8_superbirdy
you'll lose power with gutted cats..... search it on the forums. with gutted cats it disrupts the flow and creates turbulance.
my other ride is an ambulance!
1997 V8 sport - first car - sold 6/7/10
2006 silver mustang gt premiumcustom made grill, frpp shorty headers, pypes cat back exhaust, hurst billet pro shifter,
v8_superbirdy is offline
post #15 of 20 (permalink) Old 08-03-2009, 03:54 PM
CDW6212R's Avatar
Lose power, not loose. Yes gutted cats create turbulence, basically no gain.
_________
Don
CDW6212R is offline
post #16 of 20 (permalink) Old 08-03-2009, 04:49 PM
Clueless Poster
my bad typo fixed.
post #17 of 20 (permalink) Old 08-03-2009, 04:56 PM
Nitemare's Avatar
If the cats are clogged up, I can see gutting them as a cheap fix.
Needs more stall.
Nitemare is offline
post #18 of 20 (permalink) Old 08-03-2009, 07:11 PM
IMO if one absolutely has to gut the cat as a "cheap fix", you should at least ram a proper sized straight pipe through it from the outlet to inlet and fasten it there.
The "gutted cats sound like crap and hurt power" saying is indeed true. Been there, done that, won't do it again.
Delete my account.
94 Thunderbird XX is offline
post #19 of 20 (permalink) Old 08-05-2009, 04:13 PM
What model/year Pontiac is your buddies car? I picked up an MIL elim. for my 00 Grand Prix Gt, wasn't horribly expensive.
Jay
FordMan77 is offline
post #20 of 20 (permalink) Old 08-05-2009, 04:42 PM Thread Starter
Gl@re's Avatar
it's an 01 pontiac sunfire... i know i know this probably isn't going to do much for him anyways but he wants to do it anyways.
we went to radio shack and got all the parts needed to make a MIL eliminator using the specs i found using google, so we'll try that first. it's going to be a couple weeks before he gets it done anyways.
