removable mufflers? - TCCoA Forums
post #1 of 8 (permalink) Old 09-20-2009, 07:46 PM Thread Starter
Gl@re's Avatar
removable mufflers?
can you make your mufflers removable? i want to be able to use them for every day driving, because i like it quiet, but take them off when i go to the track... i'm not expecting any big boost in power, but i hated being so quiet lol.
post #2 of 8 (permalink) Old 09-20-2009, 08:02 PM
Buckcreekbilly's Avatar
You could use cutouts or header flange connectors (undo the 3 bolts and then hang rear of exhast on the bottom bolt). When it's time to go home, you bolt em back up properly.
95 Thunderbird LX 4.6
K&N cold air intake. True 2 1/4" duals, Xenon GFX. 3:55 Trac loc. Beefier trans, 2800 stall convertor, MkV111 aluminum driveshaft.
Buckcreekbilly is offline
post #3 of 8 (permalink) Old 09-20-2009, 08:04 PM
95xbird's Avatar
Cutouts are the way to go. They are right on the downtubes in your case probley after the primary cats due to the stock exhaust.
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #4 of 8 (permalink) Old 09-20-2009, 09:15 PM Thread Starter
Gl@re's Avatar
Definitely going to do those, they have cutouts on summit for $28 a piece, and they can just be clamped on, so i should be able to just cut some piping out and slide those on and tighten the clamps. The only info i can't seem to find anywhere, is what is the size of the stock piping on my 97 LSC? Also what kind of saw would be best for cutting the exhaust?
post #5 of 8 (permalink) Old 09-20-2009, 09:16 PM
95xbird's Avatar
I think the Downtube pipes are 2inch
Its slow, Really.
LS1 KILLER
95xbird is offline
post #6 of 8 (permalink) Old 09-20-2009, 09:26 PM Thread Starter
Gl@re's Avatar
oh, i hope not, they don't seem to come in 2".
post #7 of 8 (permalink) Old 09-20-2009, 09:33 PM
Cut with a small grinder and cutting wheel, around a 4". If not, small handled hacksaw will work.
post #8 of 8 (permalink) Old 09-22-2009, 11:35 PM Thread Starter
Gl@re's Avatar
anyone know for sure the size of a 97 LSC's exhaust piping? i would be installing these right after the first to cats, but before the third correct?
