Need a new CAT, dog ate my last one. - TCCoA Forums
post #1 of 13 (permalink) Old 09-28-2009, 12:43 PM Thread Starter
Jestkdn's Avatar
Send a message via AIM to Jestkdn Send a message via Yahoo to Jestkdn
Smile Need a new CAT, dog ate my last one.
Ok so not really. But I suspect the 3rd CAT went bye bye this morning. It sounds like it not firing on all cylinders almost. I give it gas and it takes a bit to catch up. Anyone know where I can get one that's California legal?
Thanks!
I am as mechanically inclined as Hellen Keller is with a Rubik's Cube!
Jestkdn is offline
post #2 of 13 (permalink) Old 09-28-2009, 12:49 PM
$138.94 from PerformancePeddler.com, Magnaflow P/N 41405.
You should check your plugs/wires first.
post #3 of 13 (permalink) Old 09-28-2009, 02:07 PM
95xbird's Avatar
Yup check your ignition system. But if not I have a whole Y assy from my car. Perfect.
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #4 of 13 (permalink) Old 09-28-2009, 02:45 PM Thread Starter
Jestkdn's Avatar
Step dad seems to think it might be electrical. Car runs fine on flat surface, there is a stutter when you start to give it gas. On incline it seems to sputter a little.
Not sure what this has to with it, but am getting uneven flow off of the mufflers out the back, right side is weaker then the left. According to him that is.
Jestkdn is offline
post #5 of 13 (permalink) Old 09-28-2009, 03:02 PM
sousa632's Avatar
Clean your MAF sensor!
John
1996 TBird LX 4.6
2001 Sable Wagon 3.0 Duratec
sousa632 is offline
post #6 of 13 (permalink) Old 09-28-2009, 03:10 PM
Nitemare's Avatar
If it's the stock exhaust then it doesn't matter, since it's basically fake dual exhaust.
Needs more stall.
Nitemare is offline
post #7 of 13 (permalink) Old 09-28-2009, 03:31 PM Thread Starter
Jestkdn's Avatar
Did that, no change.
Jestkdn is offline
post #8 of 13 (permalink) Old 09-28-2009, 03:52 PM
Nitemare's Avatar
Ok, so what have you done besides that to try to fix the problem?
Needs more stall.
Nitemare is offline
post #9 of 13 (permalink) Old 09-28-2009, 03:55 PM Thread Starter
Jestkdn's Avatar
Checked plugs and wires, cleaned MAF, cleaned K&N filter.
Jestkdn is offline
post #10 of 13 (permalink) Old 09-28-2009, 04:11 PM
Nitemare's Avatar
In that order? If so, clean MAF again. Check fuel pressure, change fuel filter, all those basic things that can affect engine performance.
How did you check the plug wires?
I assume no CEL?
Needs more stall.
Nitemare is offline
post #11 of 13 (permalink) Old 09-28-2009, 05:27 PM Thread Starter
Jestkdn's Avatar
I assume no CEL?
Sorry, no.
Checked plugs and wires, pulled plugs, looked ok, ensured that wires were secure.
Fuel Filter is 2 years old, if that.
I cleaned the K&N then the MAF.
Have a bit of a family emergency to deal with, so will have to work on care later. Thanks again for the responses.
Jestkdn is offline
post #12 of 13 (permalink) Old 09-28-2009, 08:51 PM
V8ThunderCat's Avatar
It's best to clean the MAF after cleaning the K&N and driving it a little. Oil from the filter is good at coating the MAF. I experience this a lot.
-Randy-
V8ThunderCat is offline
post #13 of 13 (permalink) Old 09-28-2009, 10:51 PM Thread Starter
Jestkdn's Avatar
What about an 02 sensor? Could one of them have gone out? Any way to test it?
Jestkdn is offline
