cat making funny noise? - TCCoA Forums
post #1 of 18 (permalink) Old 10-29-2009, 06:22 PM Thread Starter
danalba's Avatar
at about 1200 or so rpms, i get a funny noise from the center cat or whatever that one is, i cant think of what its called right now, anyways, i get this funny like... metal vibrating sort of noise from it and not sure what it is. i checked it out and it almost looks like maybe there is a plate inside there jiggling around? is that right? any ideas?
MAC CAI/02 STANG MAF/SCT CHIP TUNED BY LONNIE
EIBACH 1.5 LOWERING SPRINGS- BILSTEIN GAS SHOCKS
90 SUPERCOUPE SIDE SKIRTS/REAR
18x9-FRONT: 245 REAR: 275
PI intake/PI cams
355 trac lok
new tune for swapped parts (93 oct)
no longer the owner.... but its still my child its just released into the world....
danalba is offline
post #2 of 18 (permalink) Old 10-29-2009, 06:33 PM
If there's stuff vibrating inside then the catalyst has broken up and needs to be replaced.
post #3 of 18 (permalink) Old 10-29-2009, 06:44 PM
I'm having the same issue, cats are bad, replace.
my question is, how do you know it's the third cat?? I can't get mine to do it unless the engine is under load, it won't do it when it's out of gear.
BigJohnny is offline
post #4 of 18 (permalink) Old 10-29-2009, 07:14 PM Thread Starter
danalba's Avatar
oh see mine in park neutral drive anything it makes a funny vibrating noise at about 1200.
now if its bad my question is will it affect performance if its bad or damage anything. im talking like drastic. obviously if it is not 100% its effecting performance somewhat
and its not really "stuff" im pretty sure it looks like a plate with codes on it or something...?
PI intake/PI cams
355 trac lok
danalba is offline
post #5 of 18 (permalink) Old 10-29-2009, 10:21 PM
Mine had that too, its some ID tag spot welded under the heat sheild that breaks loose. I was able to pull it out with needle nose pliers.
post #6 of 18 (permalink) Old 10-30-2009, 01:02 AM Thread Starter
danalba's Avatar
HAHAHAHHAHA THATS SO FUNNY! thats exactly what it is. i was going to do that lol thanks xr it fixed it?
PI intake/PI cams
355 trac lok
danalba is offline
post #7 of 18 (permalink) Old 10-30-2009, 06:51 AM
ok, well then I'm in a different spot. I had the same stupid tag fall off, I pulled it out but I'm still making the noise.
as I said it's only happening when the engine is loaded, and mostly only when it's cold (I guess something is expanding when it gets hot)
sadly, my problem goes beyond the stupid little tag.....but don't count your chickens, this is exactly what happened to me.
post #8 of 18 (permalink) Old 10-30-2009, 05:08 PM
cougar_fan's Avatar
BigJohnny, you're very right. I had the same symptoms and had to replace the cat. However, it gave me a perfect excuse to get my exhaust done. So props to you Johnny.
United States Navy - Honorable Discharge
Nashville Predators - ENOUGH SAID!
See what we've been up to:
http://forums.tccoa.com/forumdisplay.php?f=95
cougar_fan is offline
post #9 of 18 (permalink) Old 10-31-2009, 01:29 AM Thread Starter
danalba's Avatar
haha i was already in the process of redoing the exhaust the min. i thought it was a bad cat.. haha
PI intake/PI cams
355 trac lok
danalba is offline
post #10 of 18 (permalink) Old 10-31-2009, 02:28 AM
David_viny's Avatar
Are you sure its cat related? I know my car makes weird noises when in park and more in neutral. I'm like 95% sure its valve body buzz. Mine sounds like a fan blade hitting a stiff piece of paper, and oscillates high and low pitch.
Just throwing that idea out there.
1995 T-bird 4.6l - Eibach lowering springs, Cobra R hood, One 12" sub woofer, Alpine type-R front speakers. 16.249 @85.11mph 1/4 mile
2001 Pontiac Trans Am WS6 - Cam, headers, HPtuned by me.
David_viny is offline
post #11 of 18 (permalink) Old 10-31-2009, 12:50 PM
cougar_fan's Avatar
Well, mine would make rattling type noise but only under load. Generally between 1500 and 2000. The cats were non existent when we pulled them so I am pretty sure that is where my issue was coming from. The whole core off the cat, whatever it is called, was in pieces. When we shook them in our hands, it was like a marraca. But every since the exhaust change I haven't experienced any rattle issues. What do you mean by valve body buzz? I'm not sure I follow.
post #12 of 18 (permalink) Old 10-31-2009, 03:05 PM Thread Starter
danalba's Avatar
i pulled the plate out today. didnt work. still makes the noise. but i noticed just behind the plate. where it splits. that bracket or whatever it is, is not tightened and causing the noise by vibrating. the bolts look pretty rusted and ill address it later. can i just tighten it together? the exhaust is fine not hanging or anything and the exhaust is hardly flowing out it. but i am getting some kind of fluid maybe water coming out of that area??
PI intake/PI cams
355 trac lok
danalba is offline
post #13 of 18 (permalink) Old 10-31-2009, 04:48 PM
at this point it's fairly safe to say that you can tighten whatever you want, your cats are bad and that's what's rattling. just like cougar fan, and what I will likely find when I remove mine, yours have most likely burned out inside or broken.
I got some Magnaflow cats 94004 that I'm going to weld on to it when I get some time, money and figure out how I'm going to remove my others one and not **** up my exhaust.
post #14 of 18 (permalink) Old 10-31-2009, 11:28 PM Thread Starter
danalba's Avatar
its not the cat im 100% positive. when i move the loose piece around so it was like wedged tight the noise stopped..
PI intake/PI cams
355 trac lok
danalba is offline
post #15 of 18 (permalink) Old 11-01-2009, 05:56 PM
Chapter Director Coordinator
jamesD's Avatar
when my cat starts makin funny noises, i stop stepping on its tail
oh wait, i have a dog
sorry, had to spam
I bust ARP bolts by hand...
If Guns kill people, then...
...pencils miss spel werds
~Gun Owners of America
jamesD is offline
post #16 of 18 (permalink) Old 11-02-2009, 07:08 AM
he looks like he would prefer you NOT take a picture of him wearing that sweater
post #17 of 18 (permalink) Old 11-02-2009, 10:35 AM
jamesD's Avatar
camera makes a noise as it focuses, so he looked like wtf?
[/hijack]
jamesD is offline
post #18 of 18 (permalink) Old 01-03-2010, 04:22 AM
HGainiac's Avatar
I read your statement about the water, and it reminded me of something I just read,
I pinched this from another post, and in it J Miller said:
"The front cats are what is known as 2-way cats they convert HC & CO to water and CO2"
Not to prove the exhaust noob I am, but if your 'leaking' H2O from that area, I'd tend to think that somethings split/shot... I'd guess that water should get routed thru the system and burnt off or pissed out the tips, not leak out... But there are plenty of exhaust monsters around here that can address that far better than I....
Besides, all this just sounds like a good excuse to swap it all out an get rid of that crap!!!
HGainiac is offline
