Mandrel exhaust system - TCCoA Forums
post #1 of 10 (permalink) Old 12-20-2009, 12:50 AM Thread Starter
across281's Avatar
if you replace the secondary catalytic converter on a 96 4.6 with an X pipe from mandrel exhaust will the car throw codes or anything that would prevent it from passing inspection?
across281 is offline
post #2 of 10 (permalink) Old 12-20-2009, 12:55 AM
Mgino96tbird46's Avatar
IIRC, it shouldn't. The third cat is not monitored by the computer. Do they do emissions testing in Texas?
Mgino96tbird46 is offline
post #3 of 10 (permalink) Old 12-20-2009, 08:40 AM
Aren't they different sizes? I think the stock pipes in that location are like 2 or 2-1/4" and the Mandrel exhausts X-Pipe is 2-1/2" and the X-pipe is made for a tru-dual system.
How do you plan to address that?
You can't just replace the secondary cat without replacing everything behind it.
post #4 of 10 (permalink) Old 12-20-2009, 10:22 AM Thread Starter
across281's Avatar
I dont think so the last time i got it inspected they just hooked it up to a computer and i guess i need to measure those pipes i didnt really think about that
post #5 of 10 (permalink) Old 12-20-2009, 10:27 AM
I think they hooked it up to a computer to see if it was throwing any codes. Thank god where I live in Virginia, they don't care about emissions.
post #6 of 10 (permalink) Old 12-20-2009, 01:30 PM
Texas Chapter Director
Send a message via AIM to speed95 Send a message via Yahoo to speed95
You wont need the 3rd cat to pass but you will need the front 2 to pass the visual if they check that. Once you cut off the 3rd cat any muffler shop around here can make the system fit your stock exhaust. The pipe sizes will be different but they will just use some reducers to make it work.
Welcome to the forum and when you get a chance check out the Texas chapter and introduce yourself in the Houston thread.
speed95 is offline
post #7 of 10 (permalink) Old 12-20-2009, 01:38 PM Thread Starter
across281's Avatar
will the shop charge a larger amount for reducers than autozone or someplace like that
post #8 of 10 (permalink) Old 12-20-2009, 02:09 PM
Im sure they will charge a little more. You should be able to buy the parts and take them with you. Then all they will do is charge labor.
speed95 is offline
post #9 of 10 (permalink) Old 12-20-2009, 02:25 PM Thread Starter
across281's Avatar
okay cool thats what im gonna do, by the way what do you think of the dorman control arms cause my bushings rotted and i gotta get new ones
post #10 of 10 (permalink) Old 12-20-2009, 02:30 PM
I got my arms at Advance. They use TRW and I havent had any problems since. If you have never done them and need pointers let me know I live on the SE side of town.
speed95 is offline
