straight pipes or mufflers?? - TCCoA Forums
post #1 of 26 (permalink) Old 01-04-2010, 12:09 AM Thread Starter
my 94 4.6 currently has all three stock cats with my mufflers removed and has 2.5' piping , its only loud during accelaration so i was thinking of removing my third cat and resonator...now will it make alot of differance from my current setup or barely noticable....or should i just remove all cats+resonator and throw in a flowmaster super 44 or 2 maybe idk??
the other mods i have are K&N air intake and air silencer removed with custom ram air.
94LXbirdy is offline
post #2 of 26 (permalink) Old 01-04-2010, 06:50 AM
BUCK's Avatar
Exclamation
If you are in "Location: Norwalk , CA" you better leave those Cats ALONE~! - Resonator is just a pipe with Muffler housing attached & go ride in a car for a day that DRONES like hell around 2K Rpm before you screw with that... You may want to consider finding something more constructive to maintain on your car.
BUCK is offline
post #3 of 26 (permalink) Old 01-04-2010, 08:12 AM
good questions here..hope someone can answer these....
post #4 of 26 (permalink) Old 01-04-2010, 08:19 AM
Two things to keep in mind:
1) If you remove the cats, in some parts of the USA, that's a pretty healthy fine due to defeating the emissions control aspect. Your choice.
2) The cats help extend exhaust life by heating the exhaust gas quickly past the acid point (hey, there's a REASON why my 2000 Malibu has 250Kmiles on it with factory exhaust! Between the stainless steel and the cats, plus the mileage I put on it, there's almost NO time it's blowing water out the back ... )
Counterbalancing both is that the cats ARE restrictive.
If you pull them, however, I'd look for some kind of muffler so that the local police don't flag you and pull you over every time you drive down the street ...
RalphP is offline
post #5 of 26 (permalink) Old 01-04-2010, 09:00 AM
beamerboy46350's Avatar
Send a message via Yahoo to beamerboy46350
Id say rather that just pull them replace them with new hi flow ones. Even better why dont you replace the exaust manifolds for headers. Ive always found that when doing exaust Its better to work from the front back. You will "feel" more starting with headers and hi-flow cats than any deletion or new mufflers
92 Cougar LS 5.0: Air Silencer delete, Flowmaster Cat-back System, Big 3,Cold Air Intake,
77 BMW 530i(no longer running will come spring)
02 Caravan SE(DD 4 kids)
beamerboy46350 is offline
post #6 of 26 (permalink) Old 01-04-2010, 02:01 PM
Tbird1997's Avatar
i had no idea cats extend your exhaust life.. guess im leaving mine alone til i can get high flow cats..
so if he took the resonator off and added some flows it would still have horrible drone? guess im leaving that alone too.
-Patrick
Tbird1997 is offline
post #7 of 26 (permalink) Old 01-04-2010, 03:34 PM
cougar_fan's Avatar
Stay away from straight pipes. Trust me, the drone is darn near unbearable. Save up and do it right. High flow cats, headers, etc . . .
United States Navy - Honorable Discharge
Nashville Predators - ENOUGH SAID!
See what we've been up to:
http://forums.tccoa.com/forumdisplay.php?f=95
cougar_fan is offline
post #8 of 26 (permalink) Old 01-15-2010, 07:29 PM
3.8 SC Cats and Resonator- Straight 2.5 out as purchased
Only time I hear the radio is at idle. Do it right the first time as I will be doing.
shoalcracker is offline
post #9 of 26 (permalink) Old 01-15-2010, 08:25 PM
Nitemare's Avatar
Ahh, that drone. I know it well: high flow cats and true dual straight pipe ending right before the gas tank. The closer to 2000RPM you are, the worse it drones, and it is extremely annoying.
Needs more stall.
Nitemare is offline
post #10 of 26 (permalink) Old 01-15-2010, 10:18 PM
cobra R Thunderbird's Avatar
Just have the 2 cats after manifolds or headers and go true duals with an X pipe and have the flowmasters at the back bumper.. Ull be very happy with that set up.. At this moment I still have factory cats and manifolds, and true dual pipe and flowmasters. It sounds great!! No drone! I'm adding an x pipe soon though
2001 GT BULLITT #00762 stock
post #11 of 26 (permalink) Old 01-19-2010, 05:49 AM
Warlockguitarman's Avatar
Send a message via AIM to Warlockguitarman Send a message via Yahoo to Warlockguitarman
i have kooks headers no cats, custom x pipe, no mufflers, i had borla but i cut them off and sold em, now it sounds awesome, turns everyones head and drops their jaws lol
96 pearl white 4.6 tbird: rebuilt npi block with pi heads, pi intake, crower stage 2 cams, shm high lift springs, L-MAF, 3.73's, marauder converter, jmod, kooks headers, xpipe, no cats, 2.5 in exhaust, no mufflers, a dyno tune, lots of interior work, 1 in drop with lots of new bushings, 18 in rims. 279 hp 319 tq. curently running 13.9 at 101 mph with a 2.1 60 time in 100 degree weather while having some nasty spark knock. Soon to have higher stall, aftermarket intake manifold, weight reduction, and hopefully a nice shot of the giggle gas.
Warlockguitarman is offline
post #12 of 26 (permalink) Old 01-19-2010, 08:44 PM
5oh Transformer
ZeroRain's Avatar
Send a message via AIM to ZeroRain
Well in my opinion id go with removing the third cat and adding some mufflers. I tried my 5.0 with only the first two and it was loud and sounded like a piece. Added some flows onto her and sounds great!
Zero
1996 Ford Thunderbird LX EFI Swapped 311 5spd "TT 5oh project"
1998 Ford Taurus SE 24v Duratec auto "DD"
1966 Ford Galaxy 500 352 Cruise-O-Matic "Restoration Car"
We don't just dream about fast toys, we build them!
ZeroRain is offline
post #13 of 26 (permalink) Old 02-02-2010, 03:10 AM
ogbird95's Avatar
if you ran straight pipes with an x-pipe and mufflers how many high flow cats would need to still sound meaty, but still be able to pass smog?
ogbird95 is offline
post #14 of 26 (permalink) Old 02-02-2010, 06:49 PM
No matter how much power, you still need back pressure from something in the exhaust. Almost all the good performance mufflers have almost a straight through design anyways and will give you a nicer sound overall. These companies do so much research and development to make a good product for power and sound, there really is no reason to not do 1 or 2 mufflers. Just my opinion after years of changing exhaust systems out.
tbirdsc14 is offline
post #15 of 26 (permalink) Old 02-03-2010, 12:42 AM
ogbird95's Avatar
Cool
thanks that was really informative
ogbird95 is offline
post #16 of 26 (permalink) Old 02-03-2010, 10:08 AM
Originally Posted by Warlockguitarman View Post
i have kooks headers no cats, custom x pipe, no mufflers, i had Borla but i cut them off and sold em, now it sounds awesome, turns everyones head and drops their jaws lol
Same set up here only I still have the Borla's on mine. I like it a little quieter but it still sounds very respectable and turns heads when I open the throttle up.
Here's a short video of mine... Just ignore that slight wine you hear, it's unrelated to the exhaust ...
post #17 of 26 (permalink) Old 02-03-2010, 11:25 AM
97Tbird4.6's Avatar
Trunk Monkey, that is music to my ears! Sounds Sweet.
97Tbird4.6 is offline
post #18 of 26 (permalink) Old 02-03-2010, 12:27 PM
Black_Cat's Avatar
Hey Ron...it looks like you need new rear tires....
2011 BMW X5 35i Premium Package
2009 BMW 535i ///M Sport Package
Black_Cat is offline
post #19 of 26 (permalink) Old 02-03-2010, 12:32 PM
Sounds great, but you need matching corner lights!
post #20 of 26 (permalink) Old 02-03-2010, 12:36 PM
Thank you.
Those were racing slicks I had on the car for running at the strip that day.
Thanks. LOL, yea, I have the matching corners I'm just to lazy to put them on.
post #21 of 26 (permalink) Old 02-03-2010, 01:11 PM
What video/audio?
I see the pic, but the bottom only has a red X in the corner. Is it just my computer or does anybody else have this problem?
post #22 of 26 (permalink) Old 02-03-2010, 01:17 PM
i can see the vid just fine..
post #23 of 26 (permalink) Old 02-03-2010, 04:46 PM
you probably have flash blocked
post #24 of 26 (permalink) Old 02-03-2010, 04:50 PM
Close, I had to update Shockwave and now I see it fine. Thanks for your help guys!
BTW, that sounds.......AWESOME!!!! I told Trunk Monkey b4 that he inspires me!!!
post #25 of 26 (permalink) Old 02-03-2010, 06:52 PM
Backpressure, schmackpressure.
There's some great info HERE that should be considered before blindly buying into that whole "needs more backpressure" theory.
....and is worthy of a sticky IMO.
Delete my account.
94 Thunderbird XX is offline
post #26 of 26 (permalink) Old 02-03-2010, 06:57 PM
cougar_fan's Avatar
Hmm . . . interesting information there.
