mark exhaust in a bird? - TCCoA Forums
post #1 of 4 (permalink) Old 03-02-2010, 07:34 PM Thread Starter
msp252's Avatar
would someone be able to tell me if a mark exhaust like this one http://forums.tccoa.com/showthread.php?t=126969 will work for my bird
i know my pipes come down from the exhaust manifolds through a set of cats to a third cat but it only has one pipe coming out of it but then it splits in two at the end
this looks like the same set up but with two pipes coming out the rear
but i dont remember exactly how that transmission support thing works in there with it
is my exhaust welded to that support and what part of it
will the mark third cat work with my stock setup
msp252 is offline
post #2 of 4 (permalink) Old 03-02-2010, 07:56 PM
RCReevesPhotography's Avatar
The rear pipes will fit on any 92-97, you will however need to remove the Mark VIII mufflers as they are almost a foot longer then the mufflers on a T bird.
The mid cat can be made to work but it makes more since just to not use a mid cat.
"Dream like you will live forever, live like you will die today"
RCReevesPhotography is offline
post #3 of 4 (permalink) Old 03-02-2010, 09:22 PM
It's not worth anything to do this.
post #4 of 4 (permalink) Old 03-03-2010, 01:57 PM
dDUBb's Avatar
I have a Mark LSC Dual exhaust on my Tbird ( except I actually have a DOHC engine ) and cut the mufflers off to replace them with standard size for a Bird.
To use the stock mounting points at the transmission for the exhaust, you would need to use a Mark 8 Trans X-member and mount to the transmission.
dDUBb is offline
