Magnaflow 3" setup - TCCoA Forums
post #1 of 16 (permalink) Old 03-13-2010, 11:28 AM Thread Starter
CometGSR's Avatar
Magnaflow 3" setup
Guys,
I have a choice between two garages to do my 3" single exhaust. One of the garages doesn't handle Magnaflow 3 chambers, so I was wondering if someone had a part # for the part I need? How would this do with the stock cat or do you guys reccomend replacing that as well?
Thanks!
-=James
1995 Ford Thunderbird V8
SCT Tuned by Amercian Motorsport, Mustang PBR, FRPP 3.73 gears, Modified Trak-Lok, Steeda UDP, K&N Panel, 1990 SC Seats, 2.5" Single Exhaust/Magnaflow Hi-Flow Cats, Michelin Pilot Sport A/S +, Windstar wheels, RichardM Intake, Kenwood KDC-HD552U HD Radio, 2800 stall DirtyDog Marauder TC, J-MOD, 2002 Grand Marquis transmission, DynoTech Driveshaft, AeroForce Interceptor Scan Gauge, Griffin Super High Capacity Radiator, 180* Thermostat, Cobra steering wheel, 6000K HID, Clear Corners Getting a makeover Spring 2015
http://www.fordthunderbird.net - For Pics and more!
CometGSR is offline
post #2 of 16 (permalink) Old 03-13-2010, 01:30 PM Thread Starter
CometGSR's Avatar
So do I pick a Universal muffler with a 3" inlet?
http://cgi.ebay.com/ebaymotors/MAGNA...item45f11a5876
-=James
CometGSR is offline
post #3 of 16 (permalink) Old 03-13-2010, 01:32 PM
Where are you planning on putting the muffler?
Delete my account.
94 Thunderbird XX is offline
post #4 of 16 (permalink) Old 03-13-2010, 01:36 PM
Ok, I see. That's a rearmount type...built in big tip.
Might want to measure some things out under there. If you remember what size your stock rear muffs were, they seem a bit short to allow room for the inlet pipe to get in there, don't they? Remember how tight of a bend the inlet pipe was with the stock diameter pipe? A longer muff and 3" pipe might make this trickier than you might expect.
Delete my account.
post #5 of 16 (permalink) Old 03-13-2010, 02:37 PM Thread Starter
CometGSR's Avatar
Thanks, I will have to look at that. I am kind of a newb about exhaust, I never had a car with upgrading.
So this type would be for mounting elsewhere in the system? I think this is what my friend who is helping me said to get..
http://cgi.ebay.com/ebaymotors/Magna...item5632475c5a
-=James
CometGSR is offline
post #6 of 16 (permalink) Old 03-13-2010, 03:22 PM
Lots of things to look at. The one you linked is offset In and offset Out. How will that affect your fitment? You could just buy it and work it out somehow, or you could try and mock something up to resemble it before buying it.
Also consider whether the muff you want will need to be round, oval, etc. Pay close attention to the listed dimensions and figure out where it could go using those dimensions..
Also consider where you want the muff to be: under the cabin floor or under the trunk floor. Looking at pics of other members' exhaust setups you can see that the rectangle/oval shapes might fit better under cabin floors than round cans.
For example the highly-regarded Magnaflow DIDO muffler is preferred as a midmount, while others seem to work or fit best at the back of the car.
FWIW, I have a Hooker Aerochamber (3" center In, 3" center Out) mounted in place of the stock resonator as a "midmount" setup and 3" pipe after that.
Delete my account.
post #7 of 16 (permalink) Old 03-13-2010, 05:35 PM
Bradone's Avatar
Go true duals.
http://www.mandrelexhaustsystems.com...ird/Categories
[email protected] (engine/trans is stock)
Bradone is offline
post #8 of 16 (permalink) Old 03-13-2010, 10:22 PM
white 97 lx's Avatar
Originally Posted by CometGSR View Post
Guys,
Thanks!
I recommend replacing the cats with a straight pipe
white 97 lx is offline
post #9 of 16 (permalink) Old 03-14-2010, 11:33 AM Thread Starter
CometGSR's Avatar
Sure! Screw Al Gore!
-=James
CometGSR is offline
post #10 of 16 (permalink) Old 03-14-2010, 02:59 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
I am running a mid-mount magnaflow with tru-x core. I got the alumnized one rather than stainless because it was cheaper. Johnny Langton, JL, whatever you want to call him gave me the part number for the muffler years ago and it has worked great. I have a single 3" tailpipe complete with compression bends for all you haters. It dumps under the car before the rear control arm. I get tons of compliments on how good the car sounds. It would be much more quiet inside if I would extend the tailpipe to the rear of the car. I am actually thinking about going back to dual tailpipes again sometime in the near future.
-Rob
-Rob
Rob is offline
post #11 of 16 (permalink) Old 03-17-2010, 12:02 AM
tbird_boi82's Avatar
Send a message via AIM to tbird_boi82 Send a message via Yahoo to tbird_boi82
omg
Originally Posted by Bradone View Post
So after checking the site and seeing this im curious how legitimate is this site im so interested , i just about wet myself when i seen it was only 300 for the cats with x pipe private me let me know
97 4.6L
tbird_boi82 is offline
post #12 of 16 (permalink) Old 03-17-2010, 09:28 AM
Listening on 141.850 mHz!
Gonzalo Duque's Avatar
James - how about going with true duals like other guys have indicated? I have the mid-mount Magnaflow #11385 with the built in crossover, Magnaflow high-flow cats #94004, one on each side, and chrome NAPA tips with the angle cut on them. I got rid of the 3rd cat and the dual-in/dual-out Magnaflow muffler was installed in its' place. I got everything except the tips on the 'Bay. I have 2.25 pipes all the way. It sounds great!
Gonzalo Duque "Gonzo"
1997 Lincoln Mark VIII LSC 4.6L Cobra V8
1997 Thunderbird Limited Edition 4.6L V8 - gone.
Might be a 2005-2007 Jaguar XJ-8 L in my future.
Westland, Michigan - but I'm from central New Jersey!
http://www.hoodliners.net - My hoodliners I make!
Gonzalo Duque is offline
post #13 of 16 (permalink) Old 03-17-2010, 09:29 AM
Gl@re's Avatar
quite a few other people have gotten their setups from that place.
post #14 of 16 (permalink) Old 03-17-2010, 09:33 AM
I am one that has the True Duals from Mandrel Exhaust Systems & TM is another , Nice set up and it works great
post #15 of 16 (permalink) Old 03-17-2010, 02:06 PM Thread Starter
CometGSR's Avatar
I still haven't made my mind up yet. I think both have good points and bad. The link referenced earlier looks like a nice setup as well.
For the single exhaust, I am looking at a Magnaflow Stainless Muffler that is 14" Case Length , 5" think ,8" wide, model #14834. This mounts on the end of the system. Anybody have an idea is this fits or not?
-=James
CometGSR is offline
post #16 of 16 (permalink) Old 03-17-2010, 03:18 PM
r429460's Avatar
Dual exhaust, nuff said.
r429460 is offline
