Does muffler location effect sound? - TCCoA Forums
post #1 of 37 (permalink) Old 06-18-2010, 09:47 AM Thread Starter
LOLA's Avatar
I have Thrush chambered muflers on my '97 4.6 in the stock location. I get a little sound from them but not a lot. I realize they are a cheap muffler and that might be part of it.
I'm thinking of upgrading to Magnaflow's. I can't remove the third cat as Missouir has visual safety inspections and I can fail if the third cat is removed. (BS if you ask me as the cats have nothing to do with safety.)
I know it's a Federal law that you can not legally remove them so no need for that debate.
I'd just like to know if I'd be wasting money if I was to replace the Thrush mufflers with Magnaflow's in regards to better sound given that they will be in the stock location.
LOLA is offline
post #2 of 37 (permalink) Old 06-19-2010, 09:08 AM
retrout's Avatar
The 3 cats and the 2 into 1 into 2 exhaust design (especially with all those bends in it) definitely limits how loud it can be even without mufflers, which is how people get away with running straight pipes on their Birds. Most of us prefer some sort of muffler to "shape" the sound. The straight-through design of the Magnaflow will make a different sound from a chambered muffler, but I don't know whether it'll be any louder.
retrout is offline
post #3 of 37 (permalink) Old 06-19-2010, 10:59 AM
Banned
91bluecoupe's Avatar
The "third" cat you are talking about is NOT a Catalatic converter it is a sound resonator and thus not regulated by law. GET RID OF IT. That should change your sound a bit.
91bluecoupe is offline
post #4 of 37 (permalink) Old 06-19-2010, 11:52 AM Thread Starter
LOLA's Avatar
It is a catalytic converter and NOT a resonator. Maybe on your '96 it's a resonator (and I highly doubt it) but on my '97 it is definitely a converter.
LOLA is offline
post #5 of 37 (permalink) Old 06-19-2010, 12:37 PM
Banned
105% It is a sound resonator not a cat. 96-97 had the same setup!
Think about this what effect do you think a cat would be 5 feet from the motor would be?
Check out this thread.
http://forums.tccoa.com/showthread.php?t=114556
post #6 of 37 (permalink) Old 06-19-2010, 12:54 PM
There is some good information in that linked thread bluecoupe.
There is a 3RD CAT and a Resonator on all 94-95 V8 MN12's The third cat sits in front of the resonator.
The 1996-1997 cars had the 8" resonator deleted which leaves them with a 3RD Cat. The third cat is not 5 feet from the engine it's more like 3 feet.
See this article for details and pictures.
http://www.tccoa.com/articles/mn12-t...st/exhaust.htm
Last edited by Trunk Monkey; 06-19-2010 at 01:07 PM. Reason: Update and correct my response
post #7 of 37 (permalink) Old 06-19-2010, 01:08 PM
Banned
My resonator was just before the rear axle.
100,000% sure.
but this is why I do not post on here much because there is ALWAYS someone to agrue ANY point.
I will leave you alone!
http://images.wrenchead.com/smartpag...e/MER/5791.jpg
post #8 of 37 (permalink) Old 06-19-2010, 02:09 PM
I think it depends on the year and the motor.
Sweetie's 1991 Cougar XR7 with the 5.0 HO has both a third cat, AND a resonator, in series.
What good does it do? It's part of the cleanup from the cat technology in the late 80's - early 90's. Did a secondary scrub.
The new exhaust (when I win the lottery ) will be all stainless, have a pair of high flow stainless cats feeding a 2in/2out stainless muffler, with stainless mandrel bent duals back to the rear. I'll start with a pair of 18" extensions, but might put mufflers in.
Further specifics? Gonna wait until I get started putting it all in there
RalphP is offline
post #9 of 37 (permalink) Old 06-19-2010, 03:54 PM
kpthefatty's Avatar
100,000% sure.
Dude ur pic shows no resonator for a 96-97. I own a 95 and was just under it. There are 2 cats right off the manifold. then into a THIRD CAT and then into a resonator. No resonator by the axle.
kpthefatty is offline
post #10 of 37 (permalink) Old 06-19-2010, 05:41 PM
As was stated earlier the resonator was deleted on 96-97 models.
post #11 of 37 (permalink) Old 06-19-2010, 06:04 PM
If you're wanting a louder exhaust note, the third cat/resonator/whatever will need to go. I'm only running two catalytic converters on both of my MN12's, and I've yet to hear a word about it during an inspection. You should have no issue passing Missouri's safety inspection with just the two front cats (stock or aftermarket).
post #12 of 37 (permalink) Old 06-19-2010, 06:13 PM
jnk3846's Avatar
Cat Anyhow i tried a couple different mufflers on the stock exhaust Flowtec Raptor Turbos = same as stock Flowtech Afterburner 2 chamber muffler =Little better than stock so i cut the mufflers and added Hooker Resonator Tips which gives out a nice sound.So i don't think just changing mufflers on a stock system does much.
jnk3846 is offline
post #13 of 37 (permalink) Old 06-19-2010, 06:39 PM
sousa632's Avatar
^^ EXACTLY how my 96 is. There is NO resonator after the 3rd CAT.
John
1996 TBird LX 4.6
2001 Sable Wagon 3.0 Duratec
sousa632 is offline
post #14 of 37 (permalink) Old 06-19-2010, 08:42 PM
Buckcreekbilly's Avatar
Since it's such a debate, i'll throw in my 2 cents. My 95 had the third cat and the resonator behind it. No debate on that because i personally cut them both out. As far as sound goes, yes muffler placement does make a difference. The more pipe after the muffler/s, the more rap to the sound.
95 Thunderbird LX 4.6
K&N cold air intake. True 2 1/4" duals, Xenon GFX. 3:55 Trac loc. Beefier trans, 2800 stall convertor, MkV111 aluminum driveshaft.
Buckcreekbilly is offline
post #15 of 37 (permalink) Old 06-19-2010, 10:44 PM Thread Starter
LOLA's Avatar
Thank you Rod.
When I was planning on removing it I called the place I have my cars inspected and asked if I removed the third converter if I would fail inspection and they told me yes.
I'm also on an Explorer/Mountaineer forum and one of the members which lives in KC close to me had removed both rear cats on his Explorer. He had his inspection done yesterday and passed.
Knowing this now I will save up and have duals ran on my Cougar. I know a place that will remove the third cat no questions asked.
LOLA is offline
post #16 of 37 (permalink) Old 06-19-2010, 11:30 PM
Earl's Avatar
i passed texas (burnet county) inspection with absolutely NO cats on my 2004 mustang
Earl is offline
post #17 of 37 (permalink) Old 06-20-2010, 06:35 PM
retrout's Avatar
When the Bird's stock exhaust finally needs to be replaced, I'll probably go for these pipes and these mufflers.
Unfortunately, I've just had the pleasure of completely rebuilding the front end and replacing all four tires, so that kind of used up all the fun money for a while....
Even after fifteen years, the factory exhaust pipes are still in good enough condition that I can't really justify doing violence to them just to make it noisier. Not even any rust to speak of.
Besides, I have my old 64 Fairlane to play with if I want to hear a noisy exhaust.
retrout is offline
post #18 of 37 (permalink) Old 06-21-2010, 11:00 AM
GRNDPNDR's Avatar
I hate to burst your bubble if ithasn't been already but on the 96 and 97 they are catalytic converters, all 3 of them. This is why I was able to get $49 a piece for 3 converters at the scrap yard when I cut them off.
It was the earlier years that had the resonators, but I am 100% certain that on the 96 and 97 there are 3 cats, NO resonator and 2 mufflers at the back, end of story.
Rest In Peace Mom.
GRNDPNDR is offline
post #19 of 37 (permalink) Old 06-21-2010, 09:42 PM
retrout's Avatar
The stock V8 exhaust consists of 2 primary cats, 3rd Y-pipe cat, a single pipe snaking back around the fuel tank, then another Y with 2 pipes from there with mufflers on the end. Up until 1995 there was an 8" resonator just behind the 3rd cat. The 96 and 97 didn't have the resonator.
This diagram was posted earlier in the thread.
This cat and this cat-back duplicates the stock system, except it'll flow way better.
But at those prices, I'd rather go with the Mandrel Exhaust Systems instead.
retrout is offline
post #20 of 37 (permalink) Old 06-21-2010, 10:36 PM
decipha's Avatar
In my experiences mounting the muffler closer to the engine/headers gives it a much deeper and more aggressive sound
supercoupin'
www.EFIDynoTuning.com
decipha is offline
post #21 of 37 (permalink) Old 06-22-2010, 02:08 AM
The more rap to the sound? Clearify please
mellbutler is offline
post #22 of 37 (permalink) Old 06-22-2010, 09:34 PM
TGJ
Baddest N/A NPI in Canada
TGJ's Avatar
These clips are of my car.
The first video is my current street setup. The Magnaflow mufflers are near the rear on an 45 degree angle compared to the stock location.
http://www.youtube.com/user/TGJaws#p/u/8/PA7_qQv4rZ0
This video is of my old race setup that I never ran. It has midmounted Dynomax Ultraflo bullet mufflers right behind the X-Pipe. I don't have those mufflers anymore and the next time I am at the track, I intend to run my current race exhaust which has no mufflers.
http://www.youtube.com/user/TGJaws#p/u/11/7ExDUuvtNSw
TGJ is offline
post #23 of 37 (permalink) Old 06-22-2010, 11:35 PM
mybird_91's Avatar
Send a message via Yahoo to mybird_91
on my mark viii, i have hollowed out the front 2 cats, i have cut out the stock mufflers and replaced them with 3 1/2" x 18" slant cut tips, tomorrow i will be cutting out the resonator which sits behind the 3rd cat and installing a flowmaster super 44 series. there is a bit of difference in sound when there is pipe to resonate in after the muffler(s)
1994 Chevrolet Camaro Z28
LT1 350
K&N Intake and Flowmaster Exhaust
1995 Lincoln Mark VIII
hollow front cats, 3rd cat still there, no resonator, replaced by a single 40 series flowmaster, 2 3"x18" tips out back. screamin demon coil packs, mallory pro wires, motorcraft platinum plugs. intake resonator delete.
mybird_91 is offline
post #24 of 37 (permalink) Old 06-23-2010, 08:09 AM Thread Starter
LOLA's Avatar
Thank you for the vids. I really like how it sounds with the Magnaflows in the stock location.
LOLA is offline
post #25 of 37 (permalink) Old 06-23-2010, 06:51 PM
TGJ
TGJ's Avatar
They are not exactly in the stock location, they sit on an angle. I cannot seem to find pictures of a similar system and don't have pics of mine.
TGJ is offline
post #26 of 37 (permalink) Old 06-24-2010, 12:06 AM Thread Starter
LOLA's Avatar
The shop mounted the Thrush chamber mufflers I have now at a 45 deg angle as well. By stock location I meant at the rear just before the bumper.
LOLA is offline
post #27 of 37 (permalink) Old 06-24-2010, 01:45 AM
mybird_91's Avatar
got mine done went w/ a 40 series and it sounds good not too loud at idle but nice rumble when i give it some throttle
LT1 350
post #28 of 37 (permalink) Old 06-24-2010, 09:29 AM
across281's Avatar
I have 2 high flow cats and dynomax race bullets mounted in the stock location on a 96 4.6, its sounds great but looks kinda ruhtarded
across281 is offline
post #29 of 37 (permalink) Old 06-28-2010, 09:48 AM
steves93tbird's Avatar
So here's a question. How many cats are on a '93 with the 3.8? Is it just the two singles off each manifold going into the resonator, then back to the muffler? Or is there something my untrained eye isn't seeing?
steves93tbird is offline
post #30 of 37 (permalink) Old 07-01-2010, 10:52 PM
mybird_91's Avatar
i had the same year car same motor and unfortunatly i cant remember i had duals ran with glasspacks....... by the way don't do that.
LT1 350
