replacing o2 sensor - TCCoA Forums
post #1 of 20 (permalink) Old 07-01-2010, 08:06 PM Thread Starter
replacing o2 sensor
ok this is a dumb question, but is there any tips or tricks to replacing the o2 sensor in our cars?
hershy314 is offline
post #2 of 20 (permalink) Old 07-01-2010, 08:09 PM
chris g's Avatar
Send a message via Yahoo to chris g
I have'nt found any yet..
COLD AIR INTAKE, MN12 PERFORMANCE FRONT SUSPENSION KIT, SILVER PAINTED AVS WINDOW GUARDS, SILVER PAINTED DASH PANELS, 28% MIRROR TINTED WINDOWS, SUSPENSION TECHNIQUES 2'' DROP, TRUE BENDS CUSTOM 2.5'' TRUE DUAL EXHAUST. 2nd generation SC wheels.
chris g is offline
post #3 of 20 (permalink) Old 07-01-2010, 08:25 PM
The driver's side is pretty self explanatory, but the passenger side requires a LOT of patience. Most of the advice given here recommends an O2 sensor socket or even dropping the exhaust at the manifold, however I was able to get it out in half an hour or so with two different open end wrenches (the angle on them was slightly different).
post #4 of 20 (permalink) Old 07-01-2010, 08:38 PM Thread Starter
i was afraid i was gonna have to drop the exhaust. im replacing the one on the drivers side. couldnt for the life of me get my hand between the exhaust and body to unplug it. or get a wrench to get the sensor out......droping the exhaust could turn out bad....its all rusted and the bolts are all coroded and stuff.
post #5 of 20 (permalink) Old 07-02-2010, 12:37 AM
96dirtybird's Avatar
What I did was take a wrench, grinded out a "slit" into the box end of the wrench, had the passenger side out in 5 min. I can take a pix of that wrench if you need?
96dirtybird is offline
post #6 of 20 (permalink) Old 07-02-2010, 01:49 AM Thread Starter
i need pics of the sensor.....on my car its on the drivers side....everyone else is sayin its passanger side....im confused
post #7 of 20 (permalink) Old 07-02-2010, 06:50 AM
There are four O2 sensors. Driver and passenger side side upstream (before cats), and driver and passenger side downstream (after cats).
post #8 of 20 (permalink) Old 07-02-2010, 08:40 AM
For posterity - Before anyone goes crazy looking for the downstream O2 sensors on a Gen1 - at least through 1991, they don't have any downstream, just the upstream sensors.
Later MN12s did, though.
(I want to say it's the 5.0/4.6L swap when they changed - but that's an opinion, not based on knowledge. Anyone knowing the actual changeover, please let us know for sure.)
RalphP is offline
post #9 of 20 (permalink) Old 07-02-2010, 11:58 AM
All 94-97s with the 4.6L and 96-97s with the 3.8L had rear oxygen sensors.
post #10 of 20 (permalink) Old 07-04-2010, 02:08 AM Thread Starter
i decided not to install them, im only gonna have the car a couple more months. it still runs fine.
post #11 of 20 (permalink) Old 07-05-2010, 01:04 PM
sousa632's Avatar
Out of curiosity, I'd like to see that
John
1996 TBird LX 4.6
2001 Sable Wagon 3.0 Duratec
sousa632 is offline
post #12 of 20 (permalink) Old 07-06-2010, 12:05 AM
I've never had a problem using an oxygen sensor socket.
post #13 of 20 (permalink) Old 07-06-2010, 12:14 AM
Me too! You would think it would just "spread out" when you put a little pressure on it. Must be a good quality wrench!!!
~Rick
TCCoA Sig
post #14 of 20 (permalink) Old 07-06-2010, 12:51 AM
DLF
DLF's Avatar
I just use a Craftsman flare nut wrench, along with a rubber mallet.
My Web Site
DLF is offline
post #15 of 20 (permalink) Old 07-06-2010, 01:21 PM
Here's the pix, just a simple and cheap "Great Neck" brand from AutoZone.
post #16 of 20 (permalink) Old 07-06-2010, 04:43 PM
Thumbs up
Outstanding!!! Worked for you, right?
~Rick
TCCoA Sig
post #17 of 20 (permalink) Old 07-06-2010, 08:10 PM
It worked as if that tool should have been "designed" for that purpose, LOL! Let's just say it worked extremly well especially under the conditions. I was living in an apt complex, so all I had was my one small space to work with and a tiny hydraulic jack.
post #18 of 20 (permalink) Old 07-06-2010, 11:02 PM
Dude! Be careful!!! I certainly hope and pray you don't depend on that little bottle jack and crawl under your car without any sort of jack stands.
Please be safe, I had a friend from high school that had his Camaro sitting on blocks of firewood. He bought a tranny off me and was attempting to put it in alone. The car came down on top of him and he died of suffocation before his girlfriend found him in the garage.
~Rick
TCCoA Sig
post #19 of 20 (permalink) Old 07-07-2010, 10:25 AM
That was all in the past. I have a 2 car driveway house now w/metal ramps.
post #20 of 20 (permalink) Old 07-12-2010, 02:01 PM
steves93tbird's Avatar
When i did mine it was seized up tight in the manifold. Ended up taking an old impact socket and welding a tab too it. I'd cut the wires of at the sensor so i didn't have to worry about them. Slipped the socket on, took a long pry bar down from the top (under the hood) onto the tab, a couple good hits, and i was able to break it lose. Piece of cake from there.
steves93tbird is offline
